Old 11-19-2010, 04:20 PM   #1
CCjon OP
HighHorse Rider
Oddometer: 491
TIG welding experts, advice wanted
I have a 2002 1150GS Adventure. A side seam on the catalytic converter has opened up about 1 1/2 inches long. I could ignore it but after several hours of riding, the hot gas blowing on my left heel is bothersome.
Talked to an aircraft welder who says he can TIG weld it if we lay the bike on its side. When I said something about removing the gas tank to disconnect the battery to protect the computer, he says he would clamp the ground(?) wire to the cat near where welding and there should be no problem. Says it would be a short loop with little if any current going thru the bike.
What do you say? Would you TIG weld your Cat this way?
Thanks for your opinions. Always valuable on this site.
CCjon
PS Inmates, before you tell me to dump the Cat and get a Y pipe, I tried that. Got too much vibration in the handlebars so went back to the Cat.
CCjon is offline   Reply With Quote
Old 11-19-2010, 04:27 PM   #2
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 11,254
should be doable, as long as no oil or nastyness on the inside of the busted seam, ubless the heat cycling over time has made that stainless fatigued.
for sure disconnect the electronics though, the TIG welder most likely has a HIgh frequency arc starter. Typically they wont hurt anything, but it would suck it fried some non-robust component inside the brain box.
"A little inaccuracy sometimes saves a ton of explanation."
- H. H. Munro (Saki) (1870-1916)
mouthfulloflake is offline   Reply With Quote
Old 11-19-2010, 04:42 PM   #3
hasenwerk
hasenwerk's Avatar
Oddometer: 863
+1 on that - takes a minute to disconnect the negative terminal on the battery.
David Marshall - Quesnel, BC, Canada
1997 BMW R1100 GS (4 Sale) / 2006 BMW F650 GS / 2009 Suzuki DRZ 400S
and a bunch of 4WD Volkswagens!
hasenwerk is offline   Reply With Quote
Old 11-19-2010, 04:43 PM   #4
RMR
REALLY confused
RMR's Avatar
Oddometer: 29
Cry
I agree with the previous post. most decent welders have a HF starting circuit to help establish the arc. Personally, I would remove the cat entirely before welding on it, as disconnecting all the electrics seems to be a bit of a bother.
the only other item that comes to mind, would be to match the filler material to the exact type of stainless used in the cat. I don't know where to start finding that out though...
RMR is offline   Reply With Quote
Old 11-19-2010, 05:17 PM   #5
JurgenB
daily rider
JurgenB's Avatar
Oddometer: 309
+1. Take the cat off. That way you may also be able to clamp the cat nicely so that the seam ends match up and you don't have a gap to bridge.
Disconnecting the battery is not enough. Welding stainless may be tricky - may have to experiment. Not sure what exactly the material is, but it's highly heat-resistant.
Jürgen
Morrison, the Red Rockies
2004 R1150GS Adv
2004 K1200RS Last of the great bricks!
The farmer will let GS riders cross his pasture for free. The bull charges.
JurgenB is offline   Reply With Quote
Old 11-19-2010, 05:27 PM   #6
BobbySands
JockeyfullofBourbon
BobbySands's Avatar
Oddometer: 5,669
I second the removal of the cat.
1. it's easier than laying a 550 pound bike on its side.
2. it'd be easier than welding it in position. This means less to a skilled TIG welder than your run of the mill welder.
3. Grounding as near to your work as possible is always a good idea, and should, in theory, protect your electronics. But as the Motronic is so expensive and finicky, why risk it?
4. I know a dozen or so good TIG welders. A high-freq machine is only needed for aluminum. Many of them never touch the stuff. But you can always ask. None-- exactly none of the 6 machines we have on the job at this moment are high-freq as we are only welding stainless and carbon.
5. as Jurgen said, if the high freq machine was going to fuck with your electronics, disconnecting the battery is not enough.
do yourself a favour and remove the cat.
6. The repair on stainless should be a snap.
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
BobbySands is online now   Reply With Quote
Old 11-19-2010, 05:57 PM   #7
mouthfulloflake
Not afraid
Oddometer: 11,254
we always used HIgh Freq starters doing a286, hastelloy, airplane stuff.
the scratch start contaminated the weld too much to pass Zyglo, and Xray, not to mention hard arcs, and arc " breaking" led to cracks.
BUT, his welder might work at a different type shop, I was just putting it out there.
Old 11-19-2010, 07:07 PM   #8
sbrownn
SlowMo
Oddometer: 418
Ac/dc
When I change from welding aluminum to stainless the major change is to go from AC to DC. Most of the other settings do not change at all if the materials are of similar thickness; perhaps reduce the current for stainless.
sbrownn is offline   Reply With Quote
Old 11-19-2010, 07:33 PM   #9
jsb223
ADV Rookie
jsb223's Avatar
Oddometer: 1,003
Take the cat off...
Find someone with real stainless welding experience.
TIG is not required, a MIG setup with a gas and wire change and
someone with real stainless welding experience can get the job done.
The thinner the material...the more experience they'll need.
That is someone with real stainless welding experience.
R1150GSA
DRZ400S
DRZ400E
jsb223 is offline   Reply With Quote
Old 11-19-2010, 07:47 PM   #10
drtlvr
Oddometer: 9
Thumb
yes take the cat off,I weld stainless at Burger Boat co,I would use 316L for welding the cat,that will not rust,you can do some major damage to the electronics even if you remove the battery, if I was close to you you I would weld it for you,but I'm leaving tomorrow to deliver a yacht and won't be back for 3 weeks.
drtlvr is offline   Reply With Quote
Old 11-19-2010, 07:58 PM   #11
fxstbiluigi
aka Road Monster
fxstbiluigi's Avatar
Oddometer: 10,634
Send a message via Yahoo to fxstbiluigi
Ground as close as possible to the weld. Disconnect the Neg. Term. on the Bat.(just to be sure nothing goes thru the $$$$) anyone capable with a TIG should be able to do the job in position.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 11-19-2010, 08:06 PM   #12
rxcrider
rxcrider's Avatar
Oddometer: 973
if you want to be sure...
remove the CAT or spend more time disconnecting all electronics. Just disconnecting the battery (both ends) may not be enough. Just ask the digifant (nearly motronic) box out of my dad's VW Vanagon back in the day - it wasn't too fond of him welding a split in the side where a fork lift attacked it.
'95+'95+'96 BMW R1100RS/RSL
'99 Husky WR250
'98 Honda XR 70
AMA, OMTA (ohio organization), BRC, BMWMOA
rxcrider is offline   Reply With Quote
Old 11-20-2010, 07:31 AM   #13
CCjon OP
HighHorse Rider
Oddometer: 491
TIG welding Cats
Thanks for the input guys.
The consensus is to remove the Cat and weld worry free. That's what I'll do.
With the table lift, removing and re-installing the Cat is easy job.
Many thanks
Ride safe
Old 11-20-2010, 04:32 PM   #14
G B
Oddometer: 31
Where I work we repair and sell big truck, when welding on them we disconnecting the battery (both ends) and connect the battery cables together so we do not burn the computers in the Can-Bus system. By using this method we do not have a problem.
G B is offline   Reply With Quote
Old 11-20-2010, 06:38 PM   #15
weldpro
Oddometer: 51
You are forgetting about changing the HF from continuous to start only. I am sure this is just an oversight though, and you know this just forgot to omit it!
To the original poster I would have no problems (ABSOLUTELY ZERO!) doing it the way the guy said he would however.......I would charge you more than if you brought it to me as just the part. My real concern would be if gas might leak out (from the gas tank or carbon can) during the job, and I could not see it whilst I was working with my helmet on.
As long as the current is not going through any circuits there will be no problems. The same goes for bearing assemblies as they will arc across if the circuit is through them, and ruin the bearings.
I see in this thread that folks who work for someone else tend to have shop policy's that say they must do this & that blah blah. Well if I had any employee other than myself doing the more complicated work then I would have some sort of "procedure" for an employee that would not share in the liability if they screwed up the job! I have tons of experience with working around electronics (even canbus), and I have yet (knocking on wood) ever had anything go wrong. Having the responsibility to have to repair or replace all those expensive parts is a huge motivator to never not know exactly what I am doing.
Hope this helps,
Richard
www.stubbswelding.com
1150gs,Husky TE630,crf450r(#101),450exc(#115p)
weldpro is offline   Reply With Quote
Times are GMT -7.   It's 08:19 PM.
