Old 03-24-2015, 08:35 AM   #1
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
Low RPM in idle when warm
Ok guys, any help would be appreciated, I'll try to be brief:
The bike was serviced by me (with the help of an inmate) 3 weeks ago.
Model 2010 F800GS, 39000km, the bike has an accelerator module. It run great before the service.
1. Oil and oil filter (Semi synthetic Castrol power 1 GPS 10w 40)
2. Air filter (went from OEM to K&N BM-8006)
3. Spark plugs (went from OEM to iridium NGK DCPR8EIX (6546))
4. Rear brake pads
After the service I choose to DELETE adaptation values with the 911 with the accelerator connected. I know it wasn't recommended for the changes I had done but I thought it wouldn't hurt. I thought that, worse case, it would take some time to get back to where I was.
After 2 weeks I took off the accelerator module and I re-deleted all adaptation values in hope that this was the source of my problems.
Symptoms:
The bike runs great and pulls happily when the throttle is not at 0%.
It also idles as it should when warming up, until the 3rd temperature bar lights up at the panel.
From the moment the 3rd temperature bar comes on, when I roll off the throttle, the bike sputters and almost stalls for 2-3 seconds then finds its pace. I also notice that the idle sits at about 1100rpm, not 1250rpm (when warming up it sits at the correct rpm).
I have taken everything apart once again and I can't find something done wrong on the service. The accelerator module has been removed, and will remain like that until the bike can gather enough new adaptation data, it idled worse when the module was on, general operation was smooth and as expected.
I am thinking about the idle actuator, could it be a bit worn out and the adaptation data had calibrated for the wear, and now without the data it produces the problem?
Next step will be to re-fit the old air filter, it wasn't too dusty, and I have blown it so I want to see if the air filter (+ no adaptation data) is causing the issue.
Could it be the spark plugs?
Can anyone think of solutions or tests I should do?
Sorry for the long post, I hope I gave enough info for you give your opinion.
BMW F 800 GS 2010 - My Brunhilde
New toys to brake!
Road Rush (Romania, Serbia)
Peloponnese Peninsula on two Africa Twins
9 countries in 15 days - Tserts.eu
tserts is offline   Reply With Quote
Old 03-24-2015, 09:52 AM   #2
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,421
Did you recalibrate the idle air controller with the 911?
Leaving it all behind 2014
Pura Vida my Ass.
Reaver is online now   Reply With Quote
Old 03-24-2015, 01:41 PM   #3
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
No, this is a recalibration of the actuator valve, right? I will do it on Thursday, tomorrow is a national holiday so I'll spend it with the kids..
By the way I put the OEM filter back on, same deal...
New toys to brake!
Old 03-26-2015, 03:59 AM   #4
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
Here is a video showing the issue. Turn the volume a bit up, it was a bit windy but you can hear the knocking sound it does for a couple of seconds when returning to idle. It starts to be noticeable at about the 1 minute mark..
New toys to brake!
tserts screwed with this post 03-26-2015 at 04:13 AM
Old 03-26-2015, 04:18 AM   #5
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
I performed the actuator calibration as well, now all that is different from before the service are the 2 spark plugs, and the fact that all adaptation data has been wiped.
Next step is to install the recommended sparks (NGK DCPR 8 E) instead of the iridiums.. That is a cheap test so I will do that. Could it be a faulty spark? The coils seem to not be at fault, as they were working fine since before the service.
New toys to brake!
Old 03-26-2015, 04:51 AM   #6
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,479
Can't hurt to run some injector cleaner thru her. partial clogs will give bad idle scenarios.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is online now   Reply With Quote
Old 03-26-2015, 09:29 AM   #7
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
Update:
I changed sparks again, put the recommended long-lasting NGKs and the problem is still there... Re-checked everything, both physically and with the 911 and everything seems to be as it should...
The only thing that is left is the oil filter, which is not OEM. It is a bit shorter than the OEM, and I hope that, if it has reduced flow, it could starve the upper end for seconds from oil, resulting in the knocking sound I hear.. I will change it tomorrow.
If that doesn't fix it, I am out of ideas..
New toys to brake!
Old 03-26-2015, 09:35 AM   #8
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
Can you recommend any particular product? Preferably one that would be available across the pond... I have never used such products... If it can't hurt I will give it a try...
New toys to brake!
Old 03-27-2015, 03:23 AM   #9
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
OEM filter is fitted, and the problem persists.. I am out of ideas..
Could it be the idle air hoses having a crack I cannot see?
New toys to brake!
Old 03-28-2015, 12:32 AM   #10
dpm
Oddometer: 203
did you open and clean the idle actuator?
dpm is offline   Reply With Quote
Old 03-28-2015, 01:05 AM   #11
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
If by clean you mean push the metal cylinder back and wipe the deposited debris from the rod and the piston, then yes. I didn't take it apart...
New toys to brake!
Old 03-28-2015, 01:54 AM   #12
tserts OP
Chaotic Neutral
tserts's Avatar
Oddometer: 2,717
This is today's video, it seems to be getting a bit better, but it might be wishful thinking on my part...
New toys to brake!
Old 03-28-2015, 07:21 PM   #13
rideslikeoldman
Oddometer: 66
See if you can find Chevron Techron. If that doesn't help, no other injector cleaner is going to.
rideslikeoldman is offline   Reply With Quote
Old 03-29-2015, 04:20 AM   #14
dpm
Oddometer: 203
This side of the Pond, either a Lubro-Moly product or (if you have access, it's pretty much trade-only) Forte.
Old 03-29-2015, 09:34 AM   #15
Indy Unlimited
Oddometer: 1,479
You can try and locate some Sea Foam or any automotive fuel injector cleaner over the pond.
Current Stable:
Times are GMT -7.   It's 05:19 PM.
