Old 07-19-2013, 08:55 PM   #1546
FBR
Oddometer: 436
I try to fill it slow, but if I forget the gas squirts back up through the vent holes soaking me and my bike. gonna take a lil more practice to get it right I guess. I never have a problem with my other bikes so it'll take some getting used to.
FBR is online now   Reply With Quote
Old 07-20-2013, 07:10 AM   #1547
The Island
Im lost.
The Island's Avatar
Oddometer: 222
Experienced this yesterday. Got gas all over my seat and fuel tank. It was if the only air escape to the tank was the little holes around where one sticks the fuel in causing a wicked beautiful display of water works.
The Island is offline   Reply With Quote
Old 07-20-2013, 07:12 AM   #1548
moe.ron
Pig. Can. Fly.
moe.ron's Avatar
Oddometer: 3,083
I fill by sound, if you listen you can hear when the tank is full. Sounds silly but works every time with no mess.
"There's a force in the universe that makes things happen. All you have to do is get in touch with it, stop thinking, let things happen, and be the ball." - Ty Webb
moe.ron is offline   Reply With Quote
Old 07-21-2013, 12:27 PM   #1549
ADVCanuck
ADVCanuck's Avatar
Oddometer: 71
Originally Posted by Bumbobee View Post
Nice, that's what Was looking for, except for me I just wanted to do it directly on the luggage mounting hardware...
Hmmm - it seems to me that the only place to be concerned about is addressed by the GL heat shield?
Robin
"Wherever you go, there you are" - Jon Kabat-Zinn
ADVCanuck is offline   Reply With Quote
Old 07-25-2013, 09:36 AM   #1550
azkick-n40
Oddometer: 7
2 washers in beak area - where do they go?
I took off my tank and beak to put on some Denali's and there are 2 washers that I have no clue where they go when reassembling. Any help would be greatly appreciated.
Brian
azkick-n40 is offline   Reply With Quote
Old 07-25-2013, 01:59 PM   #1551
The Island
Im lost.
The Island's Avatar
Oddometer: 222
Brian
Stick them in your took box for a time when you loose a washer or two.
Old 07-25-2013, 02:31 PM   #1552
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,462
I took off my tank...
I presume you mean the cover over the airbox. On my 2009 F800GS, none of the six machine screws use washers there. The beak is held in place by a long and a short machine screw underneath on both sides, none of which use washers.
Are the washers black plastic or stainless?
If it makes you feel any better, I just finished reassembling the plastic bodywork on my bike only minutes ago, and there is one leftover Torx machine screw, the type used for virtually all the panels on the bike.
Fred
FredRydr is offline   Reply With Quote
Old 07-25-2013, 03:36 PM   #1553
Shooby
Anti-Cager
Shooby's Avatar
Oddometer: 1,012
Originally Posted by dannyboydesigns View Post
So, I got a new 13 F800Gs and I was out in the mountains of western Montana, way over my head I should mention and the bike bucked me like a horse. Crash bars saved the upper front from total demo but still some scratches. Any way to touch them up? Or should I keep them as a reminder of my skill level?
Same here, 3 months ago, going down a steep service road, popping over a water bar, except didn't "pop over" as expected... Right side, above crash bars, even put some nice "texture" on the lower right corner of the fairing. Picked up the bike and thought, "good , got that over with, now I dont have to worry about it". My ankle, however, is still complaining.
I call it "Trail Patina". Also makes it easy to pick out of the crowd in a Starbucks parking lot.
Shooby is offline   Reply With Quote
Old 07-25-2013, 04:16 PM   #1554
azkick-n40
Oddometer: 7
Fred
Yes I mean airbox (sorry multi-tasking when posted) and the washers are black plastic. No clue where they came from. BTW, this is on a 2011 F800GS.
Old 07-25-2013, 05:55 PM   #1555
Bayner
Oddometer: 1,624
There are some washers in the rubber grommet/nut assembly that the windscreen mounts to. You could check that if you had it off.
Bayner is offline   Reply With Quote
Old 07-25-2013, 06:27 PM   #1556
FredRydr
FredRydr's Avatar
Oddometer: 2,462
That's my suggestion as well. The machine screws that attach the windscreen to the two brackets mounted on the fairing (at the bottom left and right of the windscreen) use black plastic washers. I wonder why BMW saw the need for washers only on those two, and not the other four?
Fred
FredRydr screwed with this post 07-25-2013 at 07:04 PM
Old 07-26-2013, 08:51 AM   #1557
MKorn
2whl Addict
MKorn's Avatar
Oddometer: 752
Has anyone figured out a good way to fill the tank without giving your seat and fairing a gas bath? Son of a.....
I use a flashlight (i'm old and blind) and keep a watch on the progress as i fill. Just a habit from the DRZ that goes from half tank to full in seconds cause of the tanks shape.
Always looking for a place to ride !
13 F800GS
09 Concours 14 ABS (sold)
02 Nighthawk 750 (sold)
06 DRz 400s
MKorn is offline   Reply With Quote
Old 07-26-2013, 09:25 AM   #1558
azkick-n40
Oddometer: 7
Fred
I bet that is the location. Are the washers used as spacers between the fairing and the bracket?
Brian
Old 07-26-2013, 12:29 PM   #1559
FredRydr
FredRydr's Avatar
Oddometer: 2,462
Mine are between the plastic screen and the heads of the screws.
Fred
Old 07-26-2013, 05:52 PM   #1560
Full Power
Oddometer: 1,603
Originally Posted by soph9 View Post
what is the best chain lube for the Alaska type roads like the Dempster, Dalton and Robert Campbell highways?
......Motor oil, SAE 50
Sounds kinda old fashioned, but that is what I use, and it works well.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Times are GMT -7.   It's 03:39 PM.
