Old 01-17-2014, 07:52 AM   #1876
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Where's your nearest Canadian Tire?
http://www.canadiantire.ca/en/pdp/mo...-0111518p.html
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 01-17-2014, 08:11 AM   #1877
Pete7874
Pete7874's Avatar
Oddometer: 409
LOL! Yeah, no CT around here.
The reason I liked the BatteryMINDer one is that it's temperature compensated.
2013 F700GS
Pete7874 is offline   Reply With Quote
Old 01-17-2014, 08:16 AM   #1878
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Bells and whistles.
When it's cold out and you start the bike it pours the amps into the battery regardless of temps or it's condition.
I'm sure the Engineery types have their reasons but to me it's.......marketing.
Old 01-17-2014, 08:29 AM   #1879
Pete7874
Pete7874's Avatar
Oddometer: 409
Nothing to do with starting the bike. When in winter storage, if the battery is stored in unheated area, it requires higher charging voltage. Otherwise, it is being undercharged.
Is it marketing? Maybe..
2013 F700GS
Old 01-17-2014, 03:41 PM   #1880
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
You're kinda missing the point but this could get like an oil thread.
The colder it gets, the less a battery self-discharges. My concern is freezing. As long as you're not paying a high premium for this geeky technology, whatever. I'm not paying more for a charger than I did for the battery. Feels like "protection" money.
Maybe I DO need an RR protector.
Old 01-18-2014, 07:17 AM   #1881
Pete7874
Pete7874's Avatar
Oddometer: 409
Over 4 months time while the bike is sitting in 40F garage, it certainly still discharges. A non-temp compensated charger is not going to keep it topped up where it needs to be, under such conditions.
The one I'm looking at is same price as the one you linked to from CT.
2013 F700GS
Old 01-18-2014, 07:35 AM   #1882
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,767
Sure it will discharge since the bike consumes .01 whilst off (starting to dig that voltmeter )
Loutre is offline   Reply With Quote
Old 01-18-2014, 09:42 AM   #1883
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
40F! That's a heated garage. Or a large beer fridge.
I'm talking well below freezing temps where a discharged battery will freeze and die. I'd have to see a study that shows a 95% charged battery in storage has a much shorter lifespan than one at 100%. Yeah but I wouldn't read it anyway. Important thing is to charge it once a month or leave it on a tender. Taking it indoors is worse than a cold garage.
Anyway, I noticed my 2012 battery has a VIN # decal on it. Could BMW not be believing all the warranty claims on the crap batteries they install?
Old 01-18-2014, 11:20 AM   #1884
UpST8
turnin gas to noise
UpST8's Avatar
Oddometer: 7,246
Bar Over
What is the best way to bar over the F800GS engine? Here trying to check valves and I have the front wheel removed at this time for repair. Thanks!
WHERE AM I RIDING
cRAzY
UpST8 is offline   Reply With Quote
Old 01-18-2014, 11:23 AM   #1885
Pete7874
Pete7874's Avatar
Oddometer: 409
Are the factory batteries known for failing early?
2013 F700GS
Old 01-18-2014, 12:16 PM   #1886
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
The battery in a 2008 Honda motorbike I had before my F8 had a battery failure like almost like clockwork on its 1-year anniversary... It read 12(ish) volts when tested, but as soon as it was put under load (starter motor) it dropped to about 4 volts. It was replaced by the dealership with another OEM battery and 3 years later when I part-exchanged the bike, it was still going strong.
My F8 (2012 model) sounds a little bit tired when the temperature drops below freezing but so far it has fired up instantly for the past 2 years. BMW use the same battery suppliers as other brands so I think it’s just luck of the draw really... unless there is an electrical issue which is draining the battery of course, such as leaving a GPS plugged in which the computer mistakes for a trickle charger for example.
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 01-18-2014, 01:15 PM   #1887
UpST8
turnin gas to noise
UpST8's Avatar
Oddometer: 7,246
The best way found via my local BMW Service Tech is bike on center stand, plugs removed, transmission in 5th and use rear wheel while a helper eyes the timing marks on the timing gears.
WHERE AM I RIDING
cRAzY
Old 01-18-2014, 04:25 PM   #1888
Bayner
Oddometer: 1,609
I do it this way too.
Bayner is offline   Reply With Quote
Old 01-20-2014, 05:31 AM   #1889
scatch
adventurer/dreams
scatch's Avatar
Oddometer: 7
Stupid questions
OK, maybe it has been covered before, but has anyone reused their head gasket over again after checking their valve clearance. At $80. + it sure is tempting, you would think BMW would have made them like the RT's where you just clean them extra careful and replace. And if you have, how much gasket seal and any problems with leaks. Thanks.
scatch is offline   Reply With Quote
Old 01-20-2014, 06:18 AM   #1890
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
You're talking about the valve cover gasket on a valve check right?
By all means reuse the valve cover gasket. The original gaskets all leaked on the top left side and did no matter how mant times you changed it. The new style is improved and came out in 2010.
Anyway, if it's not leaking now it's probably a new design. It only seals splash oil so it's not going to leave you stranded by suddenly letting go. A tip tho....use new silicone on the LH side in the corners of the half moons where the gasket does a sharp 90 degree turn in 4 places. Clean out the old sealant and put just a dab in there. When it does start leaking you'll have lots of time to prepare. Wunderlich sells Athena gaskets much cheaper than the Dealer does. They hint it's the same MFR. I bought the whole engine kit.
Times are GMT -7.   It's 10:20 PM.
