Old 09-08-2014, 02:55 PM   #2086
ChicoProf
ChicoProf's Avatar
Oddometer: 246
Laugh Ozzie's BMW
Originally Posted by ibgary View Post
What dealership? If it's close I'll go there.
Iron Horse in Tucson Az, let me use there lift, there tools and ask questions. I tranny did I melt down and they didn't have time to replace it. Best dealership I've ever been in.
Sent from my HTC One_M8 using Tapatalk
Ozzie's BMW in Chico, California. They've been great all the way around. Price break on my F700 and accessories, but good to work with even if they hadn't helped me out price-wise.
2014 BMW F700GS
2009 Kawasaki Super Sherpa
Lots o' bicycles
ChicoProf is offline   Reply With Quote
Old 09-09-2014, 09:52 AM   #2087
Defconfunk
I need to get out more
Defconfunk's Avatar
Oddometer: 223
I've tried searching, and found nothing on this.
Is there a way to put the F650GS on a spool style rear wheel stand? I have a spool style stand from my SV650, and it worked very well, so I'd like to reuse it.
Yes, I can get a centre stand, but that is money I won't have before winter storage time (buying the bike was more than I should have spent).
The dealer suggested using a pad style stand, while that is an optionsn, I have a stand I like, so if there is a spool that fits on the BMW I'd like to investigate that.
Edit: I really am a n00b, I can replace the spool type contacts with pad contacts on the same wheel lift for $15.
2010 BMW F650GS "Amelia"
2005 Suzuki SV-650N "Belle" [sold]
2003 Kawasaki ZZR-250 "Socks" [sold]
Bruised and Battered, but Smiling and Victorious. - Me
Pictures
Defconfunk screwed with this post 09-15-2014 at 08:23 AM
Defconfunk is offline   Reply With Quote
Old 09-15-2014, 07:31 AM   #2088
Piki42
Oddometer: 114
lowered F700GS damping and suspension
Hey folks,
Thought I'd continue on with this thread rather than creating a new one...
This is a topic that has been discussed at length; however, I've had a hard time getting a clear sense of how best to set the suspension and damping settings for my lowered F700GS when I'm riding with a pillion and luggage. I'm heading off on a long trip in a couple of days and really need to get this right
I've read the manual, done a search on the site, the internet and looked at the BMW MOA and F800riders forums and now have notes that prescribe very different solutions
The manual states that I should turn the preload knob all the way to its max setting and the damping one turn away from max. That seems a bit high based on what I've read elsewhere. I know that I'm supposed to be doing this based on feel but it'd be good to have some sort of ballpark if that's at all possible.
Any tips on how I could figure this out? Is going with the manual settings the safe option?
Piki42 is offline   Reply With Quote
Old 09-16-2014, 06:32 AM   #2089
Pete7874
Pete7874's Avatar
Oddometer: 412
Yeah, but that's for the non-lowered suspension.
The way I read it, the manual does not show what it should be for lowered-suspension. The only value they give for a lowered suspension is for one-up without load.
Maybe they don't expect you to ride your lowered F700 with two-up and luggage? After all, max payload for a lowered F700 is only 309 lbs. How much do you, your passenger, and cargo weigh when fully geared up?
2013 F700GS
Pete7874 is offline   Reply With Quote
Old 09-16-2014, 06:52 AM   #2090
Piki42
Oddometer: 114
We weigh around 260lbs all in with luggage etc. No 2-up on the lowered F700 would be a bit of a weird restriction if true.
Old 09-16-2014, 01:07 PM   #2091
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,751
Originally Posted by FredRydr View Post
Is this true? The F650GS twin and F800GS frames are the same.
Fred
Originally Posted by Loutre View Post
There you go Fted. All the same frames have the same colors. The odd man out is the 8GS's rear frame which has none in common (as is the 8GSA but for other obvious reasons).
F800GS (-2012):
Front frame: 46 51 7 676 539 (black) / 46 51 8 529 961 (Grey)
Rear frame: 46 51 7 694 996
F800GS (Present):
Front: 46 51 8 530 960
Rear: 46 51 8 531 590
F800GSA:
Rear: 46 51 8 523 352
F700GS:
Rear: 46 51 7 694 996
F658GS:
Front: 46 51 7 676 539 (black) /46 51 8 529 961 (Grey)
Quoted for posterity since the thread has been moved. Could be of use to someone.
Loutre is offline   Reply With Quote
Old 09-16-2014, 07:08 PM   #2092
FORM64
Oddometer: 24
Power Devices on F800GS
Powering devices: Is it ok to add a multi-port USB hub that plugs into the factory power outlet next to the key? I would run USB cables to devices in the tank bag or possibly bar mounted. Don't know if I'd keep the hub in the tank bag or mount it under some plastic. Probably charging iPhone, Garmin, GoPro, Cardo. What's the best setup? Thanks.
-Scott
FORM64 screwed with this post 09-16-2014 at 07:24 PM
FORM64 is offline   Reply With Quote
Old 09-16-2014, 10:19 PM   #2093
sarathmenon
Oddometer: 992
-Scott
You are limited to a total of 5A draw before the electronic fuse kicks in. Which should be fine for a iphone, ipad and a go pro battery all drawing in parallel. If you are planning to route it cleanly to the handlebars, the more pricey and involved solution would be to use the GPS power socket.
For your use case, go with the burns moto powerlet -> usb cable and see if it doesn't work out great.
sarathmenon is offline   Reply With Quote
Old 09-23-2014, 07:33 PM   #2094
mattlikesbikes
Oddometer: 203
Can somebody point me towards a good front tire? Last winter I got stuck in an ice storm and laid the bike down a bunch of times before I got clear of some black ice. All slow, easy falls, no lasting damage. Well a little damage to my ego and my confidence. I am less confident in the stock tire. Is there something more aggressive than the battlewing but decent for 90% road?
2009 F 650 GS - Lava Orange
mattlikesbikes is offline   Reply With Quote
Old 09-23-2014, 09:52 PM   #2095
germandiazm
Oddometer: 19
Small solar panel for trickle charge?
Hi everyone,
I'm looking into getting a flexible or portable solar panel to charge smartphones and the likes when out camping. Something in the lines of http://www.goalzero.com.au/shop/cate...olar-panels/20?
My questions are:
What would be the smallest size (voltage or wattage) solar panel I could use to trickle charge my 700gs? trying to kill 2 birds with the same stone here.
Do I need a charge controller? Can someone recommend me one?
Can it be done through the power-let port next to the ignition key?
The basics for this are probably been mentioned in the forum somewhere, but I couldn't really understand all that, just looking for the simplest and smallest solution to trickle-charge the bike while away for extended periods of time.
2014 F700GS Silver
germandiazm is offline   Reply With Quote
Old 09-24-2014, 03:54 AM   #2096
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
Originally Posted by germandiazm View Post
I'm looking into getting a flexible or portable solar panel....
You might want to search the Equipment subforum, or at least post there for a much better response.
Fred
FredRydr is offline   Reply With Quote
Old 09-24-2014, 04:12 AM   #2097
GREWUPIN_D11
GREWUPIN_D11
GREWUPIN_D11's Avatar
Oddometer: 135
This is the only commercially available tire I know of that's good for ice. http://www.smithspowersports.com/catalog_product_detail.asp?cat_8676_product_162644 3.Mitas_Trelleborg_Front_Spike.htm Not good for much else, though. ALL other front tires, regardless of tread and rubber compound, have generally the same very poor capability on ice. Therefore, live with the fact you're going to have to go very slow, and fall down from time to time.
GREWUPIN_D11 is offline   Reply With Quote
Old 09-24-2014, 05:21 AM   #2098
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 655
+1
Been there, picked the bike, kept the feet and speed down. I was off road but still ice sucks
Damn I wish all roads were dirt.
2011 White F800GS, 30,000 km's
Toronto to Maine and back, Toronto to Boston -The Long way, To the Dragon, 2days TCAT
tofire409 is offline   Reply With Quote
Old 09-24-2014, 08:04 AM   #2099
mattlikesbikes
Oddometer: 203
Thanks for the info, though not really the question I am asking. Ice is a rare thing and something I am not going to mess with again anytime soon. I am looking for a year round tire that has more grip than the battlewing. I know it is more nerves than traction, but I want something that is more rugged on the front that can bite a little better. The roads in Houston are likely worse than the roads in Iraq at this point, so looking for something that does ok with gravel/sand on slab. Something like a Metzler Enduro?
Old 09-24-2014, 11:00 AM   #2100
Captain Excellent
+ll+
Captain Excellent's Avatar
Oddometer: 191
Heard an off hand comment recently that Hidenau offers a K60 tire with a winter rated rubber compound. It's called the K60 M+S Silica (SiO2). It's not a 90/10 tire, but might be worth further research to see if it fits your needs. Check http://www.reifenwerk-heidenau.de/mo...pic=48&lang=en
Captain Excellent is offline   Reply With Quote
Times are GMT -7.   It's 08:08 PM.
