Old 11-24-2010, 10:48 AM   #31
Wildman
In my castle
Wildman's Avatar
Oddometer: 18,129
Originally Posted by Hardroad
Your the greatest. Thanks for starting the stupid question thread. I don't have a service manual yet and looking for torque values. Maybe someone can post the ones they know.
Hardroad
Go to the F650/800GS Thread Index", look under "Maintenance & Servicing" and click on "Torque Values"
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 11-24-2010, 11:00 AM   #32
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,771
Originally Posted by Al Tuna
and the engineering idiots can hand was there bikes.
Very constructive
EnderTheX is offline   Reply With Quote
Old 11-24-2010, 11:11 AM   #33
phideaux
phideaux's Avatar
Oddometer: 3,358
I pressure wash my bikes the real trick is if your a hamfist don't do IT!
If you don't fit in then you might be ADV qualified.
^^^^^^^ That is some of the best North Cobb grammar I have ever witnessed! What the heck's wrong wid chu?
Iron Butt Association No. 22913
Mrs. Phideaux to her octogenarian friend when the granny wants to know if she can sit on one of my bikes:
"It's Okay, they only fall over when HE'S on them."
North GA Tag-O-Rama Map
Georgia Tag-O-Rama Map
phideaux is offline   Reply With Quote
Old 11-24-2010, 11:16 AM   #34
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,968
Originally Posted by EnderTheX
Very constructive
You left out the stickers. Don't blow your stickers off.
Al Tuna is offline   Reply With Quote
Old 11-24-2010, 11:19 AM   #35
Al Tuna
PUI... Deal with it
Al Tuna's Avatar
Oddometer: 13,968
Busted
Old 11-24-2010, 11:25 AM   #36
Hardroad
Oddometer: 142
Thanks for info on Torque Values
Hardroad
Hardroad is online now   Reply With Quote
Old 11-24-2010, 11:26 AM   #37
Hardroad
Oddometer: 142
Torque Settings
Thanks for the info.
Hardroad
Old 11-24-2010, 12:00 PM   #38
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,771
That's actually very true, how could I forget stickers?!
Seriously though, don't blow off your stickers, especially your inspection sticker!
Old 11-24-2010, 11:56 PM   #39
Wildman
In my castle
Wildman's Avatar
Oddometer: 18,129
I'll try this one, someone double check my work here though...
Don't spray:
- directly on the sides of either wheel hub, at the bearing seals
- into the exhaust
- into the intake
- directly on the edge of the tail light
- directly on the edge of the instrument cluster
- directly into the chain grooves
- directly into the shock dust wiper
- directly into any button
Basically you don't want to spray into O-rings or into the exhaust or intake.... Most of these that I said "directly" you can spray from 3 feet away so it isn't pressurized, just don't get real close.
Old 11-25-2010, 09:38 AM   #40
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,747
Originally Posted by Monstaman
I have not got an 8 yet but can anyone tell me the parallel length on the fork tube machining that will allow the fork to be bought up through the triples to lower it, I am vertically challenged thus I am curious to find this out, many thanks Andi.
So....I guess no one knows how to answer this question, Monstaman. Maybe try explaining your question a little better. I'm not exactly sure myself what you are asking: "parallel length of the fork tube machining" ? ? ?
Help us understand what you are wanting to know more specifically.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 11-25-2010, 09:43 AM   #41
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,747
Next question....maybe not so Stupid:
Anybody had any problems from an aftermarket engine guard mounted to the motor? I don't see another way to do it. All the options seem to bolt to the engine case (lower portion). Doesn't make me feel warm and fuzzy to look at mine mounted down there that way.
Not that I ever fall down....but it could happen, maybe. I guess.
HF
p.s. Nobody has a photo of HF down.
Old 11-25-2010, 10:15 AM   #42
itsatdm
itsatdm's Avatar
Oddometer: 4,976
HF
If I understand what he is trying to say is, how far can you raise the fork in the triple clamps. The forks have a wasp like shape below the upper clamps. When mounted according to BMW specs, there is about 18mm below the upper clamp before the fork tube narrows. You can go higher but the top clamp will not have full contact.
itsatdm is online now   Reply With Quote
Old 11-25-2010, 10:53 AM   #43
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,061
Yeap that is what I wanted to know, I would be looking to bring the forks up through the triples a bit to help with lowering a bit, obviously can't go to far as it will bugger the geometry.
So yeap need to know how far down the effective flat spot if you like extends down the fork leg from the top and bottom clamp or the parallel or square length machining on the fork tube so the top and bottom triple will bolt back onto nicely before the taper on the leg.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 11-25-2010, 11:00 AM   #44
LaPorte
LaPorte's Avatar
Oddometer: 503
Monstaman
I am vertically challenged also. If you look at the top of the forks you will see a grove on the fork tube showing what I thought was the max you can raise the forks in the clamps. I have gone another 1/2" past the line. At that point, if you were to use all of your fork travel the front fender and brake lines would just be touching the under side of the bike's Radiators and such. Raising your fork tubes any higher and you could cause problems.
LaPorte
If you don't know where your going don't lead!
LaPorte is offline   Reply With Quote
Old 11-25-2010, 11:19 AM   #45
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,061
Originally Posted by LaPorte
Monstaman
LaPorte
Heya LaPorte, many thanks, how far is that line below the tripe clamp or how much have you lowered yours overall?
Does it make much difference to the handling?
Times are GMT -7.   It's 11:40 AM.
