Old 04-14-2012, 08:31 AM   #721
abnslr
rides a motorcycle
Oddometer: 228
Outlet direct-to-battery
Originally Posted by Tonopah View Post
The powerpoint on the F650GS twin (and F800GS) near the ingnition key can be easily wired directly to the battery -- theyby avoiding the canbus. I did that (had the dealer to that) so I would not have any problem with heated gear. No warranty problems but this is a US bike in the US.
That looks like a good idea in this case. It lacks the flexibility for expansion that comes with an extra fuse block, but BMW can't point to any non-standard or aftermarket equipment that way.
When I have a chance I'm going to ask the local dealer here too. If they're the ones I'm going to be dealing with then I should probably know their interpretation of the warranty policies.
abnslr is offline   Reply With Quote
Old 04-14-2012, 11:42 AM   #722
HappyHighwayman
Oddometer: 278
Is the 600 mile service a real thing or just something recommend by the dealer to get a couple hudred extra bucks out of me? :)
HappyHighwayman is offline   Reply With Quote
Old 04-14-2012, 11:49 AM   #723
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
check the key bolts for tightness... not every (genuine) BMW service checks this.
(moment values in RepROM).
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 04-14-2012, 12:00 PM   #724
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 654
Plus...I believe that it's also an oil and filter change, fluid check, clutch cable free play check and I want to say they "flash" the memory so you get better fuel milage (at least mine did).
I also have a thing about going to the dealer when there is warranty involved...less questions if there is an issue and there is "good will" that the better Dealers will give. Not that I want to EVER test my theory
Joel Wisman may be able to better comment on this.
Damn I wish all roads were dirt.
2011 White F800GS, 30,000 km's
Toronto to Maine and back, Toronto to Boston -The Long way, To the Dragon, 2days TCAT
tofire409 is offline   Reply With Quote
Old 04-14-2012, 12:02 PM   #725
HappyHighwayman
Oddometer: 278
I don't mind taking it in. My dealership treats me really well, and I took the opportunity to buy a cover while I was there. Also they give the bike a professional cleaning after every service and my bike really needs it after the thousands of bugs I killed last weekend ;)
Additionally I am having them install some engine guards, metal skid plate, aux headlights (fender mounted) and fuse box and relay.
Old 04-14-2012, 12:09 PM   #726
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
of course I did mean those bolts as an extra check, which is not always performed :)
and in case of BMW, we have warranty + coulance or how is it called in EN.
Old 04-15-2012, 06:08 AM   #727
Kevin-
Oddometer: 19
Looking for a thread about how to break in a new bike it was posted up a few weeks back but i cant find it.
Cheers
Kevin- is offline   Reply With Quote
Old 04-15-2012, 10:36 AM   #728
alpi
alpi's Avatar
Oddometer: 76
Cheers
I noticed there's a variety of opinions regarding the engine break-in procedure ranging from the "see factory recommendations" to "drive it like you stole it"... and there's an even more interesting variety of results. I found the most interesting opinions in this thread, beginning with #7856. The one thing that stuck with me was: "the key is no constant speeds and no lugging" & "increase rpm as the engine loosens up", which somehow seem to make a lot of sense, especially if attempting to "level out" all gears uniformly...
'07 G650 XCh (and '04 recumbent bike)
alpi is offline   Reply With Quote
Old 04-15-2012, 08:45 PM   #729
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
The 600 is VERY important to the longevity of the bike, the only issue is most dealers do the minimum when the 600 is the best time to go over the bike with a fine tooth comb and find things that otherwise would be a problem down the road.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 04-15-2012, 08:47 PM   #730
HappyHighwayman
Oddometer: 278
Got the bike back, all shiny, tuned up and washed. I had them remove the F800GS decals with a hot air gun.
I had them install the crash bars, skid plate, LED headlamps (fender mounted), fuse box with relay and SW-Motech GPS mount with Garmin powered mount.
I think they must have gone over the bike with a fine tooth comb because of the finale status report took him 5 minutes to go over with. Needless to say everything is a-OK.
Old 04-16-2012, 02:12 AM   #731
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
Originally Posted by joelwisman View Post
the 600 is very important to the longevity of the bike, the only issue is most dealers do the minimum when the 600 is the best time to go over the bike with a fine tooth comb and find things that otherwise would be a problem down the road.
+1
Old 04-16-2012, 09:11 AM   #732
supertorro
Oddometer: 23
Mirror stalk respray
Hi
Yet another noob here.
Anyone know if the mirror and stalk can be taken apart? I've noticed some rust bubbling up underneath the paint, so I'd like to take it apart to properly clean and respray.
Thought I'd ask here before I went about with usual ham fisted approach, that would ultimately result in my breaking the mirror and replacing with some aftermarket bits.
thanks
supertorro is offline   Reply With Quote
Old 04-16-2012, 10:23 AM   #733
HappyHighwayman
Oddometer: 278
The dealer has told me twice now that if squeeze the front brake, some of the rear brake is automatically engaged (linked braking). However, I've found no reference to linked braking online for the F800GS and the manual says nothing.
Does it have linked braking?
Old 04-16-2012, 10:27 AM   #734
epicxcrider
epicxcrider's Avatar
Oddometer: 645
No I don't believe it does
Old 04-16-2012, 10:32 AM   #735
HappyHighwayman
Oddometer: 278
Kinda pisses me off that the dealers would be wrong about this. I mean, it's a pretty major feature...they must have literally pulled that fact out of their ass.
Times are GMT -7.   It's 03:22 AM.
