Old 04-22-2012, 08:55 AM   #766
RexBuck
Oddometer: 1,054
Originally Posted by Frosteboy View Post
Interested in knowing more about clutch play and how to measure it. I was reading a thread where a clutch went out and they were talking about the play. I've been off road a lot more lately and want to make sure I'm taking care of my 2010F800GS. Thanks.
Previous posts showed the technique from the manual.
The important thing is to check it often, particularly if you are being hard on it. I was in Mexico recently and riding the clutch a lot in very slow traffic - slower than 1st gear speed. Also some off pavement but I think my own bad riding habits had me riding it more than I needed. Finally noticed a little slipping in a hard acceleration - no gap at the clutch lever. Adjusted it out to the max which gave me 2.5mm and lasted for another 7000 km till I got home. I am guessing I would have had a little more play at that point if I had been more diligent and adjusted it before it started slipping.
www.rexbuck.com - RexBuck's Latin America
Information on travelling in Latin America.
Includes links to ride reports to Mexico and to South America
RexBuck is offline   Reply With Quote
Old 04-22-2012, 09:35 AM   #767
itsatdm
itsatdm's Avatar
Oddometer: 4,919
The important part is that you have some. I didn't measure mine, just set like I normally do. Turns out it was 5mm. Not enough to let the connecter on the clutch arm to fall out, but enough to accomodate the clutch plate heat expansion that can occur if you slip the clutch a lot.
The original BMW recommendation was 1mm, which is not enough if the clutch gets hot.
Some riders thought the little adjustment under the clutch lever was the adjuster for the cable. It is not.
If you are a worrier just push the lever away with your hand and then pull the lever back. You should feel the freeplay. If you have some, don't worry about it.
itsatdm is online now   Reply With Quote
Old 04-22-2012, 09:35 PM   #768
Frosteboy
Frosteboy
Oddometer: 21
Thanks for the clutch advice! :) Ive got some play and I'll let her rip.
Frosteboy is offline   Reply With Quote
Old 04-24-2012, 10:08 AM   #769
HappyHighwayman
Oddometer: 283
My ABS seems to come on fairly regularly. I typically in city riding use the front brakes only, and I find when I ride over rough or loose ground it seems to kick in in situations where I never needed it on non-ABS bikes.
Is this likely a sign I am using too much front brake, or squeezing too hard?
HappyHighwayman is offline   Reply With Quote
Old 04-24-2012, 11:11 AM   #770
epicxcrider
epicxcrider's Avatar
Oddometer: 645
I think it's because the abs is quite sensitive and minor wheel speed variations can trigger it. Happens to me too but just let up on he brakes in the rough stuff and you won't notice it anymore.
epicxcrider is online now   Reply With Quote
Old 04-24-2012, 11:13 AM   #771
HappyHighwayman
Oddometer: 283
This is what I'm finding...I practically know when it's going to go into ABS mode, everything feels loose for a second. Is this dangerous?
I'm not even yanking the brake.
Old 04-24-2012, 01:02 PM   #772
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 656
Not unless you are descending down a steep slope with loose rocks, mud and gravel
I wouldn't worry, it sounds like your are getting a handle on the ABS response. A learning curve for sure.
You should try to lock it up on a gravel road...it's nice not having the front wheel slide out.
Damn I wish all roads were dirt.
2011 White F800GS, 30,000 km's
Toronto to Maine and back, Toronto to Boston -The Long way, To the Dragon, 2days TCAT
tofire409 is offline   Reply With Quote
Old 04-24-2012, 01:04 PM   #773
HappyHighwayman
Oddometer: 283
So far it's all city riding occurring under 20 MPH.
Old 04-24-2012, 01:11 PM   #774
Hudson
Hudson's Avatar
Oddometer: 36
I'm short
2012 F8GS... Against dealer recommendation I have been mounting the bike by standing on the foot peg and then throwing my leg over. I am just not tall enough or limber enough to mount it from the ground without hitting my knees on eight different bits or looking like I am molesting the poor thing. Question: am I going to bend my side stand if I keep this up?
Thanks.
Safe Journey,
Hudson
Newport News, VA
"They both savoured the strange warm glow of being much more ignorant than ordinary people, who were only ignorant of ordinary things."
-Terry Pratchett
Hudson is online now   Reply With Quote
Old 04-24-2012, 01:12 PM   #775
HappyHighwayman
Oddometer: 283
Do you do it while it's on the side or center stand?
With the center stand on, the dealer recommended mounting it as you do with no issues... I wouldn't worry about it.
Old 04-24-2012, 09:19 PM   #776
sorebutt
Oddometer: 1,890
I get on mine all the time by steping on the peg with the side stand on firm ground. If I was a ballet dancer I could raise my leg over my head and swing it over the seat. Instead on soft ground I have to raise my leg with both hands to get it over the seat.
sorebutt is offline   Reply With Quote
Old 04-24-2012, 10:56 PM   #777
heirhead
Oddometer: 578
2004 f650gs Dakar
Hello,
Getting a 2004 650gs Dakar. Any problems on 650 that are common that would help a new owner.
Many BMWs, never a 650. Thanks in advance for any advice or suggestions.
2004 with 569 miles on it. Rode to store, ( grocery ), and not much.
Thanks,
Heirhead
heirhead is online now   Reply With Quote
Old 04-25-2012, 06:29 AM   #778
JRWooden
Oddometer: 4,262
The sidestand and sidestand bracket on the twins was re-designed and beefed up about a year into production I think....
I tried whining to get the beefed up version and was not successful. If you have an early model bike I would take care if mounting it on the sidestand ... centerstand ... I agree ... can't see an issue there ... except now you have to get the bike of the centerstand while you are on it .... I've never practiced that maneuver ...
Old 04-25-2012, 08:02 AM   #779
tofire409
tofire409's Avatar
Oddometer: 656
It's a two up maneuver, with the passenger hanging off the back and the rider (with arms stretched out as far as possible) guns it and hopes for the best
Disclaimer:
Not a recommended procedure.
If attempted... good luck to you and your passenger
Old 04-25-2012, 10:04 AM   #780
JRWooden
Oddometer: 4,262
UMMMMMMMM maybe I'll pass on that ....
Times are GMT -7.   It's 10:53 AM.
