Old 07-18-2012, 05:48 PM   #871
seaswood
seaswood
seaswood's Avatar
Oddometer: 136
Send a message via Yahoo to seaswood Send a message via Skype™ to seaswood
Originally Posted by JRWooden View Post
Yeah... there is a stupid tool .... but there are options:
http://f800riders.org/forum/showthre...p-Removal-Tool
Thanx I totally missed someone had just asked same question.
I got it off just did not sound nice.
The nipple near the front brake reservoir I assume is used to purge air from system once system is flushed
1200GSA /7/2
seaswood is offline   Reply With Quote
Old 07-18-2012, 05:58 PM   #872
HappyHighwayman
Oddometer: 269
What mileage interval do you guys typically lube your chain at?
HappyHighwayman is offline   Reply With Quote
Old 07-18-2012, 06:49 PM   #873
JRWooden
Oddometer: 3,445
No problem!
The front master cylinder on the ABS bikes has the bleed screw.
For non-ABS it's not there ...
I've had issues getting the air out of the front system a few times...
I need to read the manual again, I think it basically says bleed the caliper, bleed the master, repeat...
Some folks have had good luck tying back the front brake lever overnight which seems to help bleed the system...
Old 07-18-2012, 09:15 PM   #874
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 574
For the first 12k, I lubed it every 600 miles with some lube from orilyes. The stock chain lasted about 15k miles. I am now on a DID X Ring, and I am trying the dupont multi use dry teflon wax from lowes. I am doing thins thenever the chain gets pretty dirty. So, like every 1k of street, a little more often if offroad, and if I ride through heavy rain. The process I have been using for this is simply just wiping it off with a cloth (which is very easy and far less mess than an oil) and then spraying it down again.
They dont use salt on our roads here, so I see very little rust on the chain, though my trip to Idaho last weekend, riding in the rain on Teton Pass, chain and sprockets got pretty rusty.... I must not have had much wax on it....
For what its worth.....
Ryan
XOVERLAND.COM Our vendor thread HERE
Season 1 Done!! HERE 6 Full Episodes Free on our website!!!
If you like it, "Like" us on FaceBook
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 07-19-2012, 07:37 PM   #875
CheckerdD
CheckerdD's Avatar
Oddometer: 1,071
I aim to lube (and clean) the chain every 500 miles or so. Sometimes more sometimes less. I got 17k miles on the first chain and it most likely would have gone quite a bit more, but I did not want to try it for a South American trip. I am about 15k miles on the second chain and it hardly seems used. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 07-19-2012, 10:09 PM   #876
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 440
Stock chain lasted 24k lubed once every 1000 miles or so.
Seemed fine, but changed it anyway.
New DID with Supersprox goes wonky within 600 miles.
Wonky = feels like the tranny is failing! Weird grinding sensation at launch.
Chain gets stiff links until lubed, then no problem
Oh well, now I lube every week (between 450-550 miles).
BTW the motor runs better then ever @ 26k!!!
Loving this rig.
Cheers,
S..
RIFF RAFF
Industrial Tiki Purveyor
rediRrakaD is offline   Reply With Quote
Old 08-01-2012, 09:56 AM   #877
epicxcrider
epicxcrider's Avatar
Oddometer: 585
Looking to replace the super-sweep OEM bars with some Pro-Taper Pastrana bars. Will the EVO bar accept threaded inserts, or should I go with the Contour?
I need to keep using handguards for dirt nap protection, so looking to see what others have done.
Old 08-08-2012, 01:32 PM   #878
peripateo
peripateo's Avatar
Oddometer: 33
What can I expect from the stock tires on the 2012 f800gs on gravel? I plan to ride well-maintained forest service roads.
peripateo is offline   Reply With Quote
Old 08-08-2012, 01:49 PM   #879
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 512
I find that they are ok...a bit squirrelly and nowhere near as nice as proper knobs.
Damn I wish all roads were dirt.
Current ride : 2011 White F800GS, 9500 km's
Past ride : 2006 KLR with 41,000 kms -gone to a good home-
Toronto to Maine and back
Toronto to Boston -The Long way
tofire409 is offline   Reply With Quote
Old 08-08-2012, 02:07 PM   #880
HappyHighwayman
Oddometer: 269
I have zero off-roading experience and I was able to ride some gravel without too much issue. Make sure to turn off ABS and use the back brake...unless you have off-roading experience in which case ignore whatever I'm saying.
Old 08-08-2012, 03:18 PM   #881
machinebuilder
Oddometer: 692
which stock tire? I believe they use the lowest bid,
My 09 came with Pirelli Scorpians, my best advise is to burn them off quick and get some good tires.
It's not that they weren't ok its that they weren't good at pavement or dirt.
I can recommend the Hiedenau K60's, for a 50/50 tire they really are good at both
2009 BMW F800GS NON ABS
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table.......seen on a T Shirt
machinebuilder is offline   Reply With Quote
Old 08-08-2012, 03:22 PM   #882
HappyHighwayman
Oddometer: 269
I got some Scorpions too and I find them just find for the road.
Old 08-09-2012, 05:42 AM   #883
machinebuilder
Oddometer: 692
Maybe I should rephrase my comment.
For the riding I do here in East TN, there are much better tires available than the scorpions. YMMV
Old 08-09-2012, 06:02 AM   #884
4TooMany
4TooMany's Avatar
Oddometer: 233
I wouldn't expect much. I personally believe that the only reason BMW puts street-oriented tires on the bike is for the lawyers. In the brochure I have for the 2012 F800GS, there is only one picture of the stock tires. All of the other pictures of the bike show some kind of more off-road oriented tires. And that's a BMW brochure! I think the brochure is BMW's way of saying: "Sorry, the lawyers made us do it". The TKC80s or the Heidenaus are still good enough on the road, and they're WAY better off. I had the dealer swap the tires before I even picked up the bike.
Oh, here's the rather cool brochure: http://www.bmw-motorrad.co.uk/media/...S-Brochure.pdf
4TooMany is offline   Reply With Quote
Old 08-09-2012, 02:25 PM   #885
peripateo
peripateo's Avatar
Oddometer: 33
Well my bike is a 2012 and I'm not sure what type of tires come on it maybe Battlewings? (I will be picking it up next weekend). So how many miles can I expect to get out of those tires before I need to replace them?
Times are GMT -7.   It's 01:26 AM.
