08-21-2012, 10:35 PM
#901 |
NoMoTDM still Gary
Oddometer: 3,763
Make sure both sides of the stand are flat on the ground when you start. It was a pain at first because I had more weight on one side than the other. It is easier to access the foot lever if you lift up the passenger peg. I grab the close side bar of the passenger peg and lift up while pushing down on the foot lever.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
08-22-2012, 12:54 AM
#902 |
Oddometer: 26
A lot of discussion about putting a bike on the centre stand went on here
http://f800riders.org/forum/showthre...e-centre-stand |
08-22-2012, 01:23 AM
#903 |
Oddometer: 18
Stupid Q nr ....... Is the Lava Orange colour of the 800 GS only for 2010 models? I love the colour, but would prefer a new model
08-22-2012, 09:33 AM
#904 |
Oddometer: 640
Available on the 2011's also. The fastest color BMW offers . . .
08-22-2012, 09:38 AM
#905 |
Oddometer: 274
The F800GS is too tall for me to take OFF the center stand the way I would on my Yamaha FZ6 (i.e. sit on it and scootch forward). I need to grab the rear luggage hand and the handlebar, put down the side stand and push it off the center stand. ALways freaks me out a little, though if it "falls" it's going to land on the side-stand and not dall.
08-22-2012, 01:47 PM
#906 | |
Adventure-Junkie
Oddometer: 1,704
I can tell the difference between a full and empty tank- that's for sure. Anyone masted the center stand take off yet... I saw a buddy do it once- was kind of awesome.
"Because FYYFF, that's why!" Oh, and- No matter how good life is, It never ends well. |
08-22-2012, 02:32 PM
#907 |
Oddometer: 36
Yeah, that's much easier when you have both sides of the center stand touching! Got it and thanks for the advice.
08-23-2012, 04:44 AM
#908 |
Oddometer: 550
I'm having trouble keeping pressure in my front brake. Changed the fluid 250 miles ago, which got the pressure back, but it's gone again. I'm guessing it's because the cap won't completely close; won't 'click' into place. Does this sound right? It's not leaking, but rather, not 'locked in'. My reservoir, and guard, took a big hit 2 months ago. No damage was done; at least nothing visible. Thanks.
"being alive is a crock of shit" - Kilgore Trout |
08-23-2012, 05:12 AM
#909 | |
Cosmopolitan Adv
Keep the smile on your face! An Otter on the road: From Lille to Limoges in 12 Days An Otter on the road: I'm coming up so you better get this party started! |
08-23-2012, 05:41 AM
#910 | |
Oddometer: 255
Perhaps you mean the brakes are feeling "spongy"? That's usually a sign of air in the brake lines, but as long as you bled them properly when you changed the fluid, that shouldn't be happening. Brakes (especially the front) aren't something to leave to chance. It sounds to me like the best bet is to have your dealer take a look. Or at least someone who's more versed in braking systems.
MSF RiderCoach 2012 BMW F800GS Trophy 2011 Suzuki DRZ-400S |
08-23-2012, 10:36 AM
#911 |
Oddometer: 3,482
If this is an ABS-equipted bike there are two bleed screws - on on the caliper and one on the master cylinder.
It is sometimes difficult to get all the air out of the system. Some folks have reported that tying the front brake lever in overnight helps (tying it in the position it is in when you apply the brakes) |
08-23-2012, 02:09 PM
#912 | |
Oddometer: 550
08-23-2012, 02:12 PM
#913 | |
Oddometer: 550
08-23-2012, 02:18 PM
#914 |
Oddometer: 255
It's possible that's the problem. There may be air trapped there that won't bleed out through the nipple on the caliper. Though it seems curious then that it gets better when you bleed the brakes then worse again.
08-23-2012, 03:25 PM
#915 | |
Oddometer: 3,482
If BMW didn't think that extra bleed screw was needed they would not have put it there... I've not seen a "twin" that without ABS installed, but on at least other BMWs the non-ABS bikes do NOT have a bleed screw on the master cylinder ... just the one on the caliper ......... so there is something going on there ... Try tying in the lever overnight ... you've got nothing to loose there ...??? Otherwise you might need to take the master cylinder off and get it to a machine shop? A good shop should be able to remove the busted bleed screw. If you decide to go that route I'd buy/take a new bleed screw with you that way the machinist will have the dimensions of the replacement part which may help him/her select the most correct EZ-out or whatever their tool of choice would be... |
