Old 09-13-2012, 05:30 PM   #946
xxxshiftxxx
Oddometer: 205
Originally Posted by grndzr0 View Post
What tires are you running?
Ryan
Stock Rims
D606 up front and Kenda Big Block on rear.
xxxshiftxxx is offline   Reply With Quote
Old 09-13-2012, 09:07 PM   #947
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
Originally Posted by xxxshiftxxx View Post
Stock Rims
Is it kosher to by fork seals off ebay?
http://www.ebay.com/itm/FRONT-FORK-SEALS-2009-BMW-F800GS-F800-GS-/250740001163?pt=Motorcycles_Parts_Accessories&hash=item3a6144c98b&vxp=mtr
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 09-15-2012, 02:22 AM   #948
CaliKarl
CaliKarl's Avatar
Oddometer: 578
I did.
"being alive is a crock of shit" - Kilgore Trout
CaliKarl is offline   Reply With Quote
Old 09-15-2012, 02:25 AM   #949
CaliKarl
CaliKarl's Avatar
Oddometer: 578
My bike has been vibrating horribly lately. The dealer said it's a result of a faulty exhaust gasket. First, what's an exhaust gasket? I don't see such a thing in the Hayne's manual. And the exhaust is horribly loose, rotating about where the springs are. I checked the subframe and engine mounts, and they seem okay. Thanks for the advice.
Old 09-15-2012, 07:27 AM   #950
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
I'm guessing they are referring to the flange gasket between the header pipe(s) and the cylinder. Sounds like you ought to remove the exhaust and inspect (everything). Then reinstall and tighten up from the front working toward the back end.
Is the header pipe loose, or the muffler? Which part wiggles the most? There are only a few attachment points, so it shouldn't be hard to debug it. Are the springs holding the muffler still tightly stretched?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 09-15-2012, 08:07 AM   #951
scottie.holmes
Oddometer: 8
I have new GSA. Once buddy told me if you are going to ride the dirt, drop front and rear pressure to 20 psi for better traction. just looking for feedback, does this make sense to others??
scottie.holmes is offline   Reply With Quote
Old 09-15-2012, 09:03 AM   #952
itsatdm
itsatdm's Avatar
Oddometer: 4,869
lowering tire pressure gives a bigger footprint for better traction and allows the tires to absorb some of the bumps instead of transmittiing them to you.
Too little air can result in a damaged rim if a solid object is hit at speed.
I question the need to go to extremes on bikes as heavy as the F800 or 1200 bikes. In the first place, riders are really less likely to ride them in extreme conditions and secondly the heavy bikes are already applying more downward force on the tires, compared to a light bike.
I do not know just how strong your rims are, but I have dented my F800gs rims running at 22lbs and now keep them above 28lb because of it.
What works is going to depend on the terrain and how fast you ride.
itsatdm is online now   Reply With Quote
Old 09-15-2012, 11:29 AM   #953
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
I run 25 front and 20 rear with the K60's and 25 front with the TKC 80.
Have been through plenty of nasty rock gardens and never bent a wheel. (other than small dents and dings, none of the huge bends that seems like alot of people post)
I ran lower on the front a few times, but hitting rocks a high speed felt like it would "jar" the bike a bit, running 25 lbs helped a bit (in my head anyway!!!)
It is noticeable better traction on the front running at 25 vs 36 though. And the street feels lots better running 36 instead of 25.
So yea it is typical to change pressure depending on where you are riding.
Ryan
Old 09-16-2012, 09:54 AM   #954
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
I was very surprised while attending a RawHyde event that Jim mentioned the same 20lb advice.
On a F800GS I run 27 psi, not only to save the rim but also avoid pinched flats or a tear in the tire.
No - it does not make any sense to me on these larger, front heavy bikes.
modeselector is offline   Reply With Quote
Old 09-20-2012, 06:52 PM   #955
Bear Creek West
Oddometer: 199
Does my bike have inner tubes?
Figured this was the quintessential noob question....
I have a new 2012 800GS Trophe with stock scorpion tires - will I discover tubes in the tires?
The sidewall is marked "Tubeless". Just bought a set of conti knobbies to swap over but not sure if I'll also need a new set of inner tubes...
Thanks in advance.
Bear Creek West is offline   Reply With Quote
Old 09-20-2012, 07:31 PM   #956
BMW_BIKER_KEITH
BMW_BIKER_KEITH's Avatar
Oddometer: 395
You have Tubes...
2010 Lava F800GS...AKA "Dirty Harry"
1998 R1200C Classic Black...AKA "Dick The Cruiser"
BMW_BIKER_KEITH is offline   Reply With Quote
Old 09-21-2012, 01:08 AM   #957
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,685
Originally Posted by BMW_BIKER_KEITH View Post
You have Tubes...
+1
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 09-21-2012, 01:09 PM   #958
Bear Creek West
Oddometer: 199
Thanks lads!
Originally Posted by Loutre View Post
+1
Old 09-22-2012, 06:34 AM   #959
Leap of Faith
My hand to the devil
Leap of Faith's Avatar
Oddometer: 29
Eek Kill switch?
O.k, here it goes. should I be using the kill switch or the key to turn off my engine? On my older bikes I have always used the kill switch but when I read BMW manual it seems that the state for use on an emergency. Help!
Long days and pleasant nights.
Leap of Faith is offline   Reply With Quote
Old 09-22-2012, 10:10 AM   #960
sorebutt
Oddometer: 1,801
You should turn the key off. Hitting the kill switch still keeps the rest of the system active. You can run your battery down if you leave the bike with the ignition switch on.
I've ridden with a guy that always used the kill switch on an older bike that kept the light on. I've had to push start him several times when his battery ran down.
sorebutt is offline   Reply With Quote
Times are GMT -7.   It's 09:48 AM.
