Old 09-27-2012, 11:40 AM   #976
BillACK
Oddometer: 18
Originally Posted by 4TooMany View Post
No they don't... they teach you to use the engine cut-off switch. :)
Whats the difference between the engine cut-off switch and the kill switch?
BillACK is offline   Reply With Quote
Old 09-27-2012, 11:52 AM   #977
4TooMany
4TooMany's Avatar
Oddometer: 321
No difference. Just that the MSF doesn't call it a "kill" switch.
MSF RiderCoach
2012 BMW F800GS Trophy
2011 Suzuki DRZ-400S
4TooMany is offline   Reply With Quote
Old 09-27-2012, 02:47 PM   #978
itsatdm
itsatdm's Avatar
Oddometer: 4,858
Just get in the habit of using the key. I usually put the kickstand town, remove my helmet and gloves.
If you have a direct wired GPS and forget, you could wake up on a frosty morning in a remote place with a dead battery.
itsatdm is online now   Reply With Quote
Old 10-06-2012, 07:53 PM   #979
mischief
misadventurer
mischief's Avatar
Oddometer: 528
Hey guys, I have a weird "gnashing" noise coming from the front end. It happens about 20 mph no matter what gear, accelerating or decelerating. The last time I had the front wheel off the bearings were fine and there isn't any side to side play, Nothing seems to be loose or binding and it only happens at or about 20 mph, has me stumped.
Also if one of you high fender guys would let loose of the stock fender, mine is cracked at one of the axle mounting points and I would be interested in buying your old one
Thx for any input
Christi
"I have this moment and no idea when it will end" - Andrea Gibson
"The adventure begins when the plan turns to shit." I don't know who said that first but I like it 'cause my plan turned to shit a long time ago
mischief is offline   Reply With Quote
Old 10-07-2012, 02:21 AM   #980
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
AFAIK there is.
Using the key should be more gentle to the engine and maybe other stuff.
also, the kill switch is too vulnerable construction for daily use I think. And -- as others mentioned -- you cant but just the switch itself.
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 10-07-2012, 02:53 PM   #981
4TooMany
4TooMany's Avatar
Oddometer: 321
Originally Posted by Hicks View Post
AFAIK there is.
My answer of "no difference" was between a "kill switch" and an "engine cut-off switch". They're just two ways of saying the same thing.
MSF RiderCoach
Old 10-07-2012, 10:50 PM   #982
CaliKarl
CaliKarl's Avatar
Oddometer: 573
Thanks for all your help for answering all my stupid questions. Now, I have one more for you. What is the cheapest, simplest way to get HID headlamps? Just switch the old bulbs with HID ones, or purchase one of the severly expensive kits from the likes of Adventure Designs? Thanks again.
"being alive is a crock of shit" - Kilgore Trout
CaliKarl is offline   Reply With Quote
Old 10-07-2012, 11:24 PM   #983
PatrickM
Oddometer: 356
Kit. The kit is the bulb, igniter and ballast. You'll swap out the bulb with the HID one, plug in your existing wiring harness to the ignitor and then follow the wiring from the ballast back to the new HID bulb.
Something around $35 should do just dandy in your low beams. http://www.ddmtuning.com/Products/DD...rcycle-HID-Kit
You may not want to swap out your high beams because if you use them to flash, well HID's take a few seconds to warm up so defeats that purpose.
PatrickM is offline   Reply With Quote
Old 10-08-2012, 05:44 AM   #984
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
aha ok ;)
Old 10-31-2012, 06:50 AM   #985
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Are there any fatbar options with different rise and pullback versus the stock bars which come with the same type of interior threaded bar ends as the OEM? I'd switch to Pro Taper Evo but I've become addicted to my Kako cruise lock which screws into those big OEM threads.
I've been looking at the bars on the 1200GSA and they look & feel a bit different than the F8 bars......might do the trick. Anybody tried that swap?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 11-01-2012, 05:09 AM   #986
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,201
My oem bars were bent in an off. Didn't want to buy the same but yes to throttle lock. Used helicoil inserts to recreate. I had a thread but Apple nuked all pics.
This should give you a good idea of how I kept it.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 11-01-2012, 05:23 AM   #987
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Sweeeet idea! Love Helicoils and didn't even think of it. What size did it require? And just to be certain, are you also using the Kayko? You didn't say exactly.
HF.
Old 11-02-2012, 09:04 AM   #988
Sutherngintelmen
around the bend
Oddometer: 1,201
HF.
Size was m12 x 1.75. I used longest in the kit, I think 28m. This fits the oem hand guard fastener. Expect a loose fit insert to bar (you could epoxy if you like) but snug when finished with hand guard fasteners.
My throttle lock is the Wunderlich fit with oem hand guards.
Old 12-21-2012, 11:55 AM   #989
dirtysouthjacket
dirtysouthjacket's Avatar
Oddometer: 538
Had my new to me '11 F800GS a few months now and got two stupid questions.
1. Why when my front wheel is in the air does the wheel flop to the right (I'm going from memory, but pretty sure it is right) every time. Its consistent to the same side every time and will do it even with the handlebars pushed all the way left initially. I think I read that maybe it was a tight brake line? I've tried finding the thread again but can't seem to remember where I saw this. Any concern here?
2. Also, I think I saw in one of the throtte threads a vague comment about the new 13's having a different map that helps with the throttle behavior. I think there was also a mention that older bikes could get the same type of flash to help? Any truth to this or should I just be looking at one of the throttle upgrades already discussed?
Thanks!!!!
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams
2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa
DSJ's Shenanigans
dirtysouthjacket screwed with this post 12-22-2012 at 07:30 AM
dirtysouthjacket is offline   Reply With Quote
Old 12-21-2012, 07:50 PM   #990
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,337
You didn't say whether you had a 658 or a 800. Difference being one has a single disc and the other has twin discs. There isn't a standard as far as I know as to what side the bars will turn. On a single disc setup, the wheel will tend to fall to the caliper side as it's heavier. On a twin disc it will fall equally on either side. HOWEVER, the clutch cable and the brake line will tend to throw both bikes bars to the right. It's difficult to get a good feel for the steering bearing tightness on these bikes but as I've come to experience, if the wheel falls hard to the right and bounces back toward centre rather harshly then it's too loose. It will bounce a bit but less so on a 800. I took "her" 658 out for a ride and the steering felt too light so I adjusted it to spec and it felt much better. The front tire was also worn out which made it feel loose as well. If in doubt have someone check it.
I know nothing about the latest programming.............
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Times are GMT -7.   It's 07:52 PM.
