12-26-2012, 12:48 PM
#1006 |
Oddometer: 491
No worries! Sprockets are the simplest and cheapest too.
12-27-2012, 07:38 AM
#1007 |
Living the Dream....
Oddometer: 2,097
One thing I don't want a taller 1st gear... that makes to tougher on the tight rocky trails when riding out west.
The F800gs Snatchy Throttle Fix Boost your Beamer...BMW efi GS Power Controller - l Now the Juice NEW!TheJUICE
12-27-2012, 07:57 AM
#1008 | |
Oddometer: 2,097
On our last trip my friend and I compared fuel consumption at every stop on a 5 day ride... and found no difference... this trip was mostly highway riding... not alot of on / off throttle movement.
![]() ![]() Trip before....Colorado / NewMexico I was using about a 1 to 2 tenths of a gallon more on fill up when riding out on the trails in Colorado. I will be the first to say I am not hard on the bike at all... I ride a medium pace... Average with 5 riders. ![]() ![]() Quote:
12-27-2012, 10:26 AM
#1009 |
Oddometer: 128
New owner question.....
Where can I purchase a spare tube for my bike and what is necessary for a tube repair change???? I'm new to tubed tires, so I have no idea what I need. So far I have: Cruz Tools tool kit Slime air Pump I need: Bars to break bead and get tire off wheel Lubricant? Spare Tube I have no idea where to purchase a spare tube or which one I need. I have K60's on bike now. I know a 21" tube will work on front/back, but I am not sure where to get or any other info. Any help would be great |
12-27-2012, 10:31 AM
#1010 |
Amusing Myself Again
Oddometer: 609
When you had your tires changed you could have (should have) gotten new tubes as well. I always ask for the old tubes back as they just get thrown out. You can go to any bike shop and they'll know what size you need. Mail order??
Life is a rollercoaster........and I'm not strapped in!
12-27-2012, 10:40 AM
#1011 |
Oddometer: 128
Yeah, never occurred to me until it was too late... The local shop is not far, so It's not a big deal. But, sometimes online ordering is cheaper/more convenient...
12-27-2012, 02:23 PM
#1012 |
NoMoTDM still Gary
Oddometer: 3,761
I recommend you do a few tire changes in the comfort of your garage. I can't count the number of pinch flats I went through until I learned the tricks of the trade. Good practice when there is no tire shop nearby.
Breaking the bead on the rear is a chore. See if you can do it with your tire irons. I could not until I got a long one.
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
12-27-2012, 05:00 PM
#1013 | |
Oddometer: 453
What he said. It never really clicks, regardless of what you read, until you try to do it yourself. Also, before you even think about taking any tires off to practice, make sure you have PLENTY of extra tubes. Not just one! I read these to start... http://www.advrider.com/forums/showt...ht=neduro+tire http://www.clarity.net/~adam/tire-changing-doc.html Then I went out in the garage on a day that I had nothing else to do, and started swapping tires and tubes on my KLR. The first time you will be learning how to take your wheels on and off and redoing the chain tension. I did the front first (its easier I think) and had no issues once I figured out how to get the tire on and off. I then did the rear. I pulled the rear, swapped tires and couldn't get it to inflate. Put a hole in the tube with a tire iron. Went to Cyclegear, got ONE tube. Went home and promptly put a hole in that tube. However, the leak was slow enough that I had got it back on the bike and chain tight when I realized it was losing air. Went back to Cyclegear and bought the last remaining tube they had in the size I needed. At this point, I'm peeved and in a hurry. I furiously speed the tire on and off and put another hole in that tube. I contemplated setting the garage on fire at this point. It had been a long time since I've been that pissed in the garage. Went to Walmart and bought a patch kit and used that and carefully put the tire back on. The following week I got my tubes in I had ordered, swapped to a new tube carefully with no issues. Point is, you need to practice in the garage, so you know what you are doing if you have an unexpected flat. Good luck!
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams 2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa DSJ's Shenanigans |
12-27-2012, 05:20 PM
#1014 |
Oddometer: 210
Is there a link for the $75 Accelerator plugin?
12-27-2012, 08:23 PM
#1015 |
NoMoTDM still Gary
Oddometer: 3,761
Good question: When I bought mine, I got it straight from the manufacturer: http://www.sol2.be/Performance/ENG/Order/index_BMW.html
Since then North America got turned over to a vendor in South Africa? The short version, that works just as well, is not available from the vender and Mark won't sell here.
12-27-2012, 11:37 PM
#1016 | |
Oddometer: 128
#1017 | |
Oddometer: 128
12-28-2012, 07:54 AM
#1018 |
Oddometer: 453
Its not bad once you figure it out, no need to dread it. Just think about how much money you'll be saving and knowing that the job was done right. Good luck!
12-28-2012, 01:40 PM
#1019 |
Oddometer: 491
I suggest using a piece of cut up tubing that you can put between your rim and tire when using irons unless you want to scuff up your rims. This method has worked much better than rim savers for me but it is user dependent I guess. Also talc up your tube. Some people say it doesn't matter but I have had issues in the past. If it is wet out just roll with it until you can do a proper fix.
12-30-2012, 06:41 PM
#1020 |
Oddometer: 24
This is a damn good thread and I have read every page. Thank you all.
