Old 04-04-2012, 09:08 AM   #2011
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,648
Originally Posted by Florida Lime View Post
I actually just did this, but have not run much through the bike yet.
Wouldn't the partially clogged injectors affect normal running also ?
FL, Check out some of the youtube stuff on applying voltage to injector and reverse washing.
Question for all you smart Bergers out there...Why run a DOT tire for DS instead of something like a the stocker Bridgestone? I've heard that there is essentially no difference in the tread wear, and that it really boils down to a manufacturer paying for a certain tire in it's line up to be DOT certified.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 04-04-2012, 11:44 AM   #2012
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,115
No. My bike had basically the exact same symptoms as yours when I bought it 2 years ago. It had sat on the the showroom floor for a while and when I picked it up (late winter) it immediately had trouble starting. It would take about 6 or 7 cranks to finally start. If I shut the bike off for less than 30 seconds or so, it would immediately start back up without trouble. If it sat around for a minute or longer, then it would require multiple cranks again to start up. The bike ran great once started, all the time. It was under warranty and the dealer went through all the usually BS stuff: checked valve clearances, checked battery, ECU swapped for new one with competition map thanks to KTM USA, bla bla bla. I figured all along it was the injector but they didn't listen to me. Dealer finally swapped in a new injector, and voila, it's been fine since
When clogged, injectors can get stuck open or closed. In my experience, it's usually stuck open, which causes extra fuel to leak into the cylinder, essentially flooding the cylinder. That's why it takes multiple cranks to fire: it has to clear the extra fuel out so ignition can occur. It starts immediately after shutting the motor off because the injector doesn't have enough time to flood the cylinder.
The decompression apparatus on the cam has been known to cause problems in a few 'Bergs, but usually those will have trouble starting all the time, and the starting is usually easier when rolling the bike while in gear (gets to a certain point in the cam profile where the bike will start easier, or something like that). If it's valve clearance, it will consistently have trouble starting when hot, and usually start fine when cold. If it's the fuel pump, you would be able to hear that the pump is not running when you hit the start button (usually after overheating the pump), and it will only start after letting the bike site for a while to cool down.
Mark
'11 KTM 250 XC (dual sported)
'05 KTM 450 EXC (dual sported)
OhioPT is offline   Reply With Quote
Old 04-04-2012, 01:21 PM   #2013
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,500
My starting problem sounds exactly as you described yours. Good info.
Thanks Mark.
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime is offline   Reply With Quote
Old 04-04-2012, 01:31 PM   #2014
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,115
Thanks Mark.
No problemo. Let us know when you get it sorted out.
Mark
Old 04-04-2012, 01:32 PM   #2015
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,322
Originally Posted by Tarheel Wheeler View Post
Ride Blue!
Thank you, makes some sense now. I just pictured needing a big jug of sta-bil....
On the list.
I just got back from the dealer, valves are in spec at 50 hours/1800 miles. intake was right in the middle, exhaust was at 15, still in spec.
Chain was severely stretched, causing the rubbing. Must have gotten the guys old chain or something. I'm just very happy I can still run the best tire for me and my local environment, a D606.
More HusaPorn, my GPS mount and adjustable headlight brackets. With this super bright non DOT HID light I needed to be able to dip it down when riding at night on pavement.
I love this bike!
Lost Rider screwed with this post 04-04-2012 at 09:45 PM
Lost Rider is offline   Reply With Quote
Old 04-05-2012, 09:16 AM   #2016
McLeod
Oddometer: 429
Did I read in here somewhere that the KTM LC4 rims would fit the husaberg?
If that is true then would the rear wheel off my KTM 640 standard fit?
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 04-05-2012, 09:19 AM   #2017
cross-country
cross-country's Avatar
Oddometer: 1,717
Yep, they will. I've done it.
cross-country is offline   Reply With Quote
Old 04-05-2012, 09:42 AM   #2018
McLeod
Oddometer: 429
Just flip it around and stick the Axle in?
I know what I am doing tonight when I get home! Cush Hub here I come!
Now I have no reason for the 450 not to be my main bike!
Old 04-05-2012, 10:44 AM   #2019
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
On the list.
That chain must have been properly shagged. When they are worn badly, they will flop around side to side, hitting the tire and flap like yours was. What most KTM owners suggest as far as proper chain tension, remove the shock, and run the swing arm through its arc and check the tension. This will me more accurate than the suggested way of checking tension. Once you have done this, you will now have a point of reference. Congrats on the new bike.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 04-05-2012, 02:33 PM   #2020
Pitster
miniac
Oddometer: 348
Just listed my 2010 570fe in the flea market if anyone is looking for a clean burg!
www.pitsterpro.com Pitster Pro, Mini Bikes, Pit bikes and Play bikes, Side x Side, ATV
www.nomadrider.com Adventure luggage and gear
Pitster is offline   Reply With Quote
Old 04-05-2012, 05:57 PM   #2021
mikecarpenter
Oddometer: 53
Competition map
I'm picking up a new FE570 tomorrow and when I asked the selling dealer about installing the competition map he said no problem, I charge $70 for that. After all my searching I can't find where anyone had to pay the dealer for the map. I have no qualms about paying for a service as long as every other dealer isn't doing it for no charge.
mikecarpenter is offline   Reply With Quote
Old 04-05-2012, 07:42 PM   #2022
hillwalker
hillwalker's Avatar
Oddometer: 34
I would weigh that cost against what it would cost to send to a dealer out-of-state to get flashed. I may have to do that (not all dealers will do it / know about it). If the dollars are close between the two options, might be a wash.
hillwalker is offline   Reply With Quote
Old 04-06-2012, 04:44 AM   #2023
Tslapper
Tslapper's Avatar
Oddometer: 6,772
I'm loving this machine. That being said, I had one hell of a bad luck night.
Turning a 180 in the woods, setting up for hill climb, give it and fall over. WTF!
I managed to wrap 5 feet of heavy wire around my right rear axle and swing arm. It tightened down and snapped the brake line. Got it unwound and decided to continue the ride. Was only about another hour of daylight anyway.
Hit a river crossing and found a big f'n hole with a boulder on the other side. Bounced off, went over. I hit the kill switch just before the tank went under. Got the bike upright about immediately. Friends helped me drag it on shore and we stood it up, no water out of the exhaust. I put it in 5th gear and rocked it a few times then thumbed the starter. There was hydro lock. I rocked it a few more times and finally she spit and started turning over. It eventually started and I rode the mile back out of the shit hole we were in. Guess it's broke in now.
So, the reason for this whole sordid story was to ask about flushing the motor. It's not my first drowning and I know what to do but is there something I should pay special attention to when I do flush it? I have a 2011 FE570.
Tslapper is offline   Reply With Quote
Old 04-06-2012, 05:15 AM   #2024
Wander4Days
Where am I?
Wander4Days's Avatar
Oddometer: 134
map switch
Correct me if I'm wrong, but isn't this the same map that can be switched with an aftermarket map switch? if so, why not buy a switch for about the same price and have all 3 maps available on the fly?
here's Sicass's for $79 and Hsaberg's for $35
http://sicassracing.com/store/switch...mapping_switch
http://offroadboss.com/Berg_accessories.htm
Wander4Days is offline   Reply With Quote
Old 04-06-2012, 07:18 AM   #2025
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,479
The FE570 is not like other dirt bikes. if you put the airbox under water you get water in the piston and gear box.
Not hard to deal with.
First check oil level so you don't have too much water in it to blow your cases or bend your crank. Drain some if necessary. remember oil floats water is on the bottom.
Take the seat off and remove the filter. Make sure you get the water out of the vent to crank area and if needed stand the bike up with the throttle opened to let the water drain back out of the airbox and intake.
Next crank a few short pulses to help push the water out of the piston or put it in gear and try and roll it out.
The try and start it with brief periods with the throttle cracked slightly to help dry the plug.
Don't over crank. Do a few seconds once a minute and in a few minutes she should start up.
The squeeze the water out of the air filter and reinstall it and the seat after it has gotten running.
When you get back to base camp you need to do 4 oil and changes and one filter change. until the oil has not more milky look.
Don't ask why I know. Damn pesky beaver ponds forced me to cross up to the handlebars a few times.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 04-06-2012 at 02:20 PM
Indy Unlimited is offline   Reply With Quote
Times are GMT -7.   It's 02:12 PM.
