Old 01-21-2011, 03:49 PM   #196
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,647
Originally Posted by Brown Dog View Post
I've been studying up on these Bergs
I Love the Extra 55cc's over the little 530 EXC.
Does the 70 Degree Aux Sub Frame 1gal Tank have its own filler neck & cap,
or does it fill from the stock 2.2gal tank ?? It fills from the stock tank.
Pics installed ?? [ive seen the 70degree website] TL is installing one as we speak on his 570S...TL we need pics.
Does the 570 S have a Wide Ratio Tranny comparable to the EXC box ?? TL would be the guy to answer that question since he's a 2 Berg garage. Where ya at TL?
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 01-21-2011, 04:37 PM   #197
nobrakes
nobrakes's Avatar
Oddometer: 3,369
Mostly likely. The gear ratios of the FE450 are identical to those of the 08+ EXC's. I suspect the 570 is the same, but don't have a manual in front of me to check for sure, but I'd be mildly surprised if they were different. I think you can download the manual from the Husaberg web site to compare.
Its habits that make us, and habits that break us.
'12 KTM 350 EXC-F
'12 Beta EVO 2
nobrakes is offline   Reply With Quote
Old 01-21-2011, 04:47 PM   #198
nobrakes
nobrakes's Avatar
Oddometer: 3,369
Actually, nevermind, I just noticed that the same manual covers both the 450 and 570, so they both have the same gear ratios, and are the same as the 08+ KTM EXC 450/530.
So the answer to your question is yes.
'12 KTM 350 EXC-F
'12 Beta EVO 2
Old 01-21-2011, 05:44 PM   #199
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,963
AWESOME Tranny for True 50/50 Dual Sporting
... 570, so they both have the same gear ratios, and are the same as the 08+ KTM EXC 450/530 ...
I love the lower 1st & 2nd with 5th & 6th [taller compared to the close ratio]
I miss my old 525 EXC Wide Ratio Tranny
Tarheel Wheeler or TL,
Can you can fill both tanks at the pump thru the main tank cap ??
Thanks Guys for your replies
Brown Dog screwed with this post 01-21-2011 at 05:50 PM
Brown Dog is offline   Reply With Quote
Old 01-21-2011, 05:54 PM   #200
Brown Dog
Brown Dog's Avatar
Oddometer: 1,963
Originally Posted by tahoeacr
210 watts.
Thats 60 more watts than the 530 & only 14watts less than my 690 Enduro
Im sure the EFI uses a little of that wattage over a carb
I noticed the Bergs come with a 7 amp/hour battery compared to a 4a/h on the 530
Its gotta be better for aftermarket add-ons with these two Features
Old 01-21-2011, 06:08 PM   #201
Tarheel Wheeler
Around
Oddometer: 3,647
You fill both at the pump thru the main Berg tank fill cap. I'm told it takes a little longer since it has to run thru the fuel line.
Old 01-22-2011, 10:19 PM   #202
twotyred
Practising Recedivist
twotyred's Avatar
Oddometer: 2,204
Sometimes the question of durability is asked.
A couple of weeks ago I was down at my local KTM shop ('Berg Dealer as well!!). I was having a bit of a chat with the owner who was performing a routine service on a well used 09 570 'Berg. The body work is well scraped, showing signs of a hard trail use and a few falls. The gear lever is very well worn and the brake lever shows signs of solid hits with hard objects (trees & rocks etc)
This bike has just over 12,000ks on the clock and the engine has never apart. The owner also has a set of motard wheels and regularly like to chase sport bikes through the twisties near where I live - this would be good fun indeed!!
This gives me great confidence in the durability of my own FE450 - I clearly don't ride as hard as this guy and his bike has withstood the flogging he has given it!!
If you succeed at first...don't look surprised!!
More enthusiasm than ability!!
twotyred is offline   Reply With Quote
Old 01-25-2011, 10:47 AM   #203
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
durable,,,,150hours of being stupid and clumsy ...thats right...landed on those damn rocks...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 01-25-2011, 06:36 PM   #204
TLtrials
TLtrials's Avatar
Oddometer: 274
Winter time calls!
Hey TWheeler and BDog,
Just got back last night from a Colorado Ski trip.
I have been running really low on wrenching time and have not started the install of the 70 degree tank on my FE570S. From reading the instructions it fills from the main tank. I hope to get it completed in the next few weeks, I am waiting on a fan kit to come in so I will only have one tear down.
I have never rode a 525 EXC, so I can't say that the gearbox is the same. I have barely ridden my 570 since I got it, but it feels like it will pull much harder than my 09 FE450. I understand that the gear box on the FE450/570 are the same, I think they may be the same as the XCWs.
I did drop the front sprocket to a 13. I want to ride it some before I change the rear 42, just to figure out the right sprocket for D/S duty. I suspect a 45 to 48 may be the size, but I don't think that I want to go as low as a 50 for highway work.
TLtrials is offline   Reply With Quote
Old 01-25-2011, 06:57 PM   #205
Ink
Slave to the Needle
Ink's Avatar
Oddometer: 125
Originally Posted by Tarheel Wheeler View Post
What springs do you need? I know a guy with a set of 4.8/8.0s that is looking to sell.
I really dont know what I need yet, i think I need .48 up front and 8.4, but I need more info/knowledge before I buy.
Ink is offline   Reply With Quote
Old 01-26-2011, 10:33 AM   #206
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,610
The FX 450 has different ratios from the FE570
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 01-26-2011, 04:13 PM   #207
Tarheel Wheeler
Around
Oddometer: 3,647
Call or email Bart Hayes at Genuine Dirt Racer Products. They'll hook you up with springs over the phone, or you can package up your stuff and send it to them. Also had good luck with Trail Tricks in the past, but Bart and GDR are seriously good with Bergs. TL can attest to GDR's reputation.
Old 01-26-2011, 05:28 PM   #208
TLtrials
TLtrials's Avatar
Oddometer: 274
WP Suspension
TW is correct, the guys at GDR have been great on the WP suspension and they are a Husaberg dealer too. They recently got the hook with WP, here is the press write up:
"Genuine Dirt Racer products, subsidiary of Powersport Grafx LLC, announces that they are now the US representative for WP suspension Austria Gmbh.
The creation of WP Racing USA is a great next step for the future of our company."
Old 01-26-2011, 05:37 PM   #209
Brown Dog
Brown Dog's Avatar
Oddometer: 1,963
Originally Posted by TLtrials
Hey TWheeler and BDog ...
OK We want pics & comments TL
Old 01-26-2011, 05:49 PM   #210
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,432
+1
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime is offline   Reply With Quote
Times are GMT -7.   It's 10:04 PM.
