10-22-2012, 09:29 AM
#2896 |
Safari Scramble!!!!!
Oddometer: 3,193
The cylinder looks pretty normal to me. I see cross hatching in the cylinder which should be there from the factory. The rings on the piston will not scrub the entire cylinder so you will see a difference at the top and the bottom. The side of your piston looks pretty well scuffed up. do both sides look that way or just one? if its one or one worse than the other it could be because of the thrust side...the side that sees more cylinder wall loading based on the rod angle/movement.
Edit: I see the matching scuffing on the cylinder wall. You might have someone check the cylinder bore and taper. If you are doing new rings you will want a fresh hone (anyone?).
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
10-22-2012, 01:09 PM
#2897 | |
Oddometer: 93
I have ~100mi on the HDB guards. I took off some Acerbis guards, and it doesn't feel a whole lot different. The vibes are about the same as my former Yamaha WR250x. The Vibranator was what I was thinking about. Since I threaded/tapped my bars for the HDB guards, I wanted something that would work seamlessly with the current setup. |
10-22-2012, 02:49 PM
#2898 | |
New Sheriff in town
Oddometer: 5,408
People say I'm not a people person, I say how can I be a people person when I hate people. -Joe R 09 FE 570 11 990 ADV |
10-22-2012, 04:36 PM
#2899 |
Oddometer: 53
Cylinder honing or replating
Since I want to keep this bike forever, I don't wanna cheap on my cylinder. It's crazy to by a new OEM cylinder + piston + crankshaft for about 2500$ here in Canada with all the taxes.
Do you have a good mechanic or place that can fix my crankshaft + replate my cylinder + fix a new piston and ring kit into that for a lot less than brand new ? |
10-23-2012, 02:01 AM
#2900 |
Oddometer: 4,900
Yeah, get in touch with Travis at Thumper Racing.
info@thumperracing.net For $3200 you can even get a 660 kit with a billet stroker crank and bigger bore cylinder. ![]()
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
10-23-2012, 04:24 AM
#2901 |
Lost but laughing.
Oddometer: 4,562
There are a few complete motors for sale in Australia.
http://www.advrider.com/forums/showp...&postcount=127
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. |
10-23-2012, 05:15 AM
#2902 | |
Oddometer: 53
Now that's interesting... I sent an email to this guy... On the picture, there's a black boot or something near the starter... What's that thing ???
10-23-2012, 06:49 AM
#2903 |
Oddometer: 1,120
Looks like they cut off the intake boot and just left the end on top of the transmission. It is not going thru the engine case so it probably just sitting there in the picture.
Current Stable: 2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS 2007 Husqvarna TE610 , 2003 KTM 525 MXC |
10-27-2012, 11:40 PM
#2904 |
High Roller
Oddometer: 5,126
First day out on my new 11' FE390
![]() My new best friend ![]() This bike is a hoot! I put 4.8 hours on it today so first oil change tomorrow. Looking forward to a whole new kind of riding. |
10-28-2012, 03:31 AM
#2905 |
Keep On Keeping On!
Oddometer: 1,855
Can anyone tell me what the output is of the stator for a 2010 390. Did a search and could only find info for the 570, which looks like it is around 200w.
“Do not be afraid; only believe.” |
10-28-2012, 03:58 AM
#2906 |
Oddometer: 4,900
Exact same parts.
10-28-2012, 09:06 AM
#2907 |
Beard Bros Racing
Oddometer: 10,149
The stator is a KTM unit right? 200w is plebty to run a bigger light,,well depending on what else your running.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8"If you french fry when you shoulda pizza'd,your gona have a bad time".
10-28-2012, 09:13 AM
#2908 | |
Oddometer: 4,900
But in the end every Husaberg part is made by KTM anyway. ![]() PS: Big lights are out! Get yourself a Squadron LED (or two if you are running Baja) and enjoy all the light you will ever need with less draw than a normal halogen bulb.
10-28-2012, 10:44 AM
#2909 |
Mosquito bait
Oddometer: 5,486
so, silly question time....
oil level... check it cold or hot after running the engine a bit? If I set it cold halfway up the sightglass, it disappears after running a bit. Takes quite a while for all of it to get back down to halfway. Like a few hours.
"There isn't any secret," he said. "It's all very obvious." |
10-28-2012, 10:49 AM
#2910 | |
Oddometer: 4,900
