Old 06-07-2011, 06:53 PM   #751
PABiker
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
Dealer replaced my pump with a new one today, hopefully that will take care of it.
'06 KTM 950 Adventure
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 06-07-2011, 08:57 PM   #752
KayaKTM OP
Day trippin'
KayaKTM's Avatar
Oddometer: 405
Seriously i was just getting ready to post this exact same thing. i should have my tank back on Thursday and be ready for the weekend.
2004 KTM 950A
2010 Berg 390 (Tagged)
Religions change; beer and wine remain. Harvey Allen
KayaKTM is offline   Reply With Quote
Old 06-08-2011, 07:54 PM   #753
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,226
Well after 3 hours of disassembley, head scratching, and internet searching I now have found all of the connectors needed for my fe450 light/horn install. Just have to install the rear brake switch and finish mounting everything.
Is there some trick to adjusting the front brake light switch? Seems like it will only go off with the lever dialed out to its most extreme outer position.
Seth S
Husaberg tank for sale: HERE
Seth S is online now   Reply With Quote
Old 06-08-2011, 11:13 PM   #754
dave_t08
dave_t08's Avatar
Oddometer: 57
2010 fe?
Has anyone had any issues plating a FE? I found a good deal on a leftover 2010 and was curious if the title is like other KTM models (no mention of OHV). I live in FL and they don't allow u to register dirtbikes if the title is designated offroad only. FL. doesn't inspect or require emission test so I think I will be fine if the title wording is correct. Any thoughts would be greatly appreciated.
dave_t08 is offline   Reply With Quote
Old 06-09-2011, 04:59 AM   #755
Seth S
Seth S's Avatar
Oddometer: 3,226
I should find out today or tomorrow morning whether my 09 will be an issue. The 09 MSO does say offroad use only. Believe the 10's are the same with the 11's possibly being different.
Seth S
Old 06-09-2011, 06:49 AM   #756
PABiker
Anywhere but here
PABiker's Avatar
Oddometer: 3,671
My MSO listed the bike as a "Motorcycle" and not "OHV" so all I had to do is walk in to the notary, pay the tax, register it, and walk out with a plate. Then I installed the Sicass DS kit, got it inspected, and that was it.
Same thing I did with my 250.
'12 Suzuki DR650SE
Old 06-09-2011, 06:57 AM   #757
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
What's written on the MSO has to do with which state you bought the bike in.
NY issued titles say "Off road use only" MA say nothing apparently. I had a NY MSO, so I had to jump through a few very minor hoops but I have a plate.
Just say'IN
crankshaft is offline   Reply With Quote
Old 06-09-2011, 06:59 AM   #758
crankshaft
crankshaft's Avatar
Oddometer: 13,783
When I put the lighting kit on my 570, it was a treasure hunt for sure
Sorry I missed your call, I could have walked you through it.
Just say'IN
Old 06-09-2011, 06:59 AM   #759
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,363
No issues plating my second one.
You must be the original name on the Certificate of Origin to register in NC if bought new. Found that out the hard way on my 1st Berg. Not an issue if the bike already has a title.
Yes they register just like a KTM. I've heard of some Bergs coming with a "Off Road Only" title. That's a non starter in NC.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler screwed with this post 06-09-2011 at 07:40 AM
Tarheel Wheeler is offline   Reply With Quote
Old 06-09-2011, 07:06 AM   #760
crankshaft
crankshaft's Avatar
Oddometer: 13,783
Yes they register just like a KTM. I've heard of some Berg coming with a "Off Road Only" title.
Hey Greg, how goes the battle? Stateside or running around? I had the pleasure of riding all last weekend with McGilkey Watching him burn all the little bike guys on the SE is more fun than should be legally allowed
Just say'IN
Old 06-09-2011, 07:41 AM   #761
Tarheel Wheeler
Around
Oddometer: 3,363
Around...Tell Mike I said hello. He is a hoot to see on the SE.
Old 06-09-2011, 07:51 AM   #762
dave_t08
dave_t08's Avatar
Oddometer: 57
Thank you...
For the reply's. I'm surprised I can buy a leftover Husaberg cheaper than a leftover KTM. I was originally going to buy a KTM 450 xcw but may do a deal on the Husaberg if everything works out.
Does anyone know if the ergonomics are the same between the Husaberg 450 and the KTM 450 (seat to peg)?
Old 06-09-2011, 08:11 AM   #763
Tarheel Wheeler
Around
Oddometer: 3,363
Ergos are different...ask Crankshaft.
Aftermarket stuff for the Berg (plastic, etc) is more expensive than KTM. Much more aftermarket support for KTM. Still like the Blue KTM better than the Orange one.
Tarheel Wheeler screwed with this post 06-09-2011 at 08:29 AM
Old 06-09-2011, 08:36 AM   #764
dave_t08
dave_t08's Avatar
Oddometer: 57
Ergos
That might be an issue I'm 6'2 (long legs). I saw one extra gallon of fuel cost $500
Old 06-09-2011, 09:06 AM   #765
nobrakes
nobrakes's Avatar
Oddometer: 3,317
The seat to peg difference is probably a little less on the 'berg. I just checked the chassis specs for a late model KTM vs an FE450, and while they don't list the seat-to-peg measurement, the seat heights are the same between the two, but the ground clearance is a little bit more on the 'berg by about 0.4 inches. So that would tend to imply that the seat to peg distance on the 'berg is a tad shorter than that of the KTM, probably about .4 inches, or less than 1/2 inch.
Of course, the flip side of that is that the 'berg gives you a little bit more ground clearance.
You can probably find some aftermarket stuff to lower the pegs if you found that to be a problem.
“It’s habits that make us, and habits that break us.”
'12 KTM 350 EXC-F
nobrakes is offline   Reply With Quote
Times are GMT -7.   It's 07:00 PM.
