Old 11-23-2010, 10:18 AM   #1
S.Ark_Rider OP
KLR n00b
S.Ark_Rider's Avatar
Oddometer: 22
KLR Passenger Peg Extensions
Anybody know of a good way to make the passenger pegs on a 08+ KLR longer? I have some of those bash gaurds/luggage supports over the rear plastics of my KLR and the g/f cant get her feet on the pegs...
Are there any longer aftermarket pegs i could buy? Anybody make something??
Any info will be appreciated!
S.Ark_Rider is offline   Reply With Quote
Old 11-23-2010, 01:30 PM   #2
danketchpel
Oddometer: 2,551
I took a quick look at mine and it looks like two possibilities.
1. Add a spacer block behind the foot peg bracket and the frame with longer bolts.
2. Use and extended foot peg that fits in the stock bracket. It might take a little searching to find a drop in extended foot peg, but I ran across several potential options on a quick google search. Most are Harley oriented but some could work.
Here's one potential choice.
13 MG Stelvio NTX, 09 Duc Sport Classic, 02 Speed Triple
13 Husky Terra 650, 00 Suzi DRZ400-S
danketchpel is offline   Reply With Quote
Old 11-29-2010, 03:02 PM   #3
S.Ark_Rider OP
KLR n00b
Oddometer: 22
Originally Posted by danketchpel
I1. Add a spacer block behind the foot peg bracket and the frame with longer bolts.
Hadnt thought of that. Thanks!
I was hoping that someone has already had this problem and knew which replacement pegs to get, but this sounds almost as easy and even cheaper
Old 04-08-2013, 08:12 AM   #4
Snowbird
Oddometer: 552
Question Thread bump
To the OP, did you find a solution? I have the same problem, possibly due to the gaurds.
On my newly acquired 2009 bike, the pivot point for the passenger foot peg is welded to the mounting bracket. The easiest solution I can see is some longer foot pegs from another motorcycle; all I'd have to do is pull the pivot pin and make the switch.
Anyone know of a inch or so longer foot peg?
Snowbird is offline   Reply With Quote
Old 11-24-2014, 11:40 AM   #5
kallehof
kalle
kallehof's Avatar
Oddometer: 111
My girlfriend said the same. So here's what I did.
I have brush guards on my 1999 KLR 650 that I mount Dirt-Bagz saddle bags to and they stick out about an inch. So she asked me to extend the foot pegs out about an inch. The mounting point for the front pegs (.975") are are a different size than the passenger pegs (.755") so it's a bit difficult to just buy pegs from a catalog as they only list front pegs.
My first idea was to buy extra front klr peg mounts and weld the bracket on to the passenger peg mount. But I like that the passenger pegs retract and stay up then not in use unlike the front pegs that have a spring them to keep the down all the time.
Another solution may be to use SW-Motech foot pegs and order the correct a hinge adapter and add spacer between the adapter and foot peg. But the pegs are $175 and I would still need to fabricate a spacer. Here's a blog post by Lawritz Mann (http://klr650adventures.blogspot.com...foot-pegs.html) and the pdf instructions for installing the pegs (http://static.twisted-throttle.net/m...11_10200_s.pdf) .
My solution was to buy "Moto Solution foot Peg Wideners" $27 on Ebay and weld them to the stock passenger peg. They come with a 1.2" ID. The rubber on the peg and a ringed washer press against the mounting bracket to hold the peg in place. So I wanted to retain a bit of the rubber on the peg. I cut the rubber off at the second line on the stock peg which established peg wideners are mounted and made the pegs 1 1/4" wider.
Hope it helps.
Kalle Hoffman
San Francisco, CA
kallehof screwed with this post 11-24-2014 at 11:55 AM
kallehof is offline   Reply With Quote
Old 11-24-2014, 02:51 PM   #6
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,043
http://pacblueconcepts.com/product-info/#RP_content
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 11-24-2014, 04:00 PM   #7
SFMCjohn
13
SFMCjohn's Avatar
Oddometer: 905
Hope it helps.
Kalle Hoffman
San Francisco, CA
Pretty neat, and reasonably cheap, too ... Lisa will be happy, I predict!
see you around the campfire,
-- John A
caryandjohn.blog: Baja, KLR, & '73 Tiger Ride Reports
San Francisco Motorcycle Club, Est. 1904
Let's Ride!: BAARC and Old's Cool Ride Reports Index
IBA#'98onaEX500
SFMCjohn is offline   Reply With Quote
Old 11-28-2014, 03:43 AM   #8
Snowbird
Oddometer: 552
It turned out that I just went to the hardware store and bought some spacers and longer mounting bolts to move the pegs out. The spacers moved the entire foot peg bracket outward along with the pegs. The brackets are now on the outside of the guards. the spacers fill the void where the brackets once were. It was so simple that I wondered why it took me so long to come up with it.
Times are GMT -7.   It's 12:59 PM.
