Old 11-25-2010, 05:04 AM   #1
Migs OP
Migs's Avatar
Oddometer: 165
Deactivate the ABS while moving? F800GS
Friends:
Is there some way to deactivate the ABS while moving? Are there any special tricks related to ABS on the F800GS?
Migs
"I consider myself a road man for the lords of karma"~Hunter S Thompson
"He who is not afraid will always be safe." -Lao Tzu
"Do not be bothered by anything."-S. Suzuki
Migs is offline   Reply With Quote
Old 11-25-2010, 05:38 AM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 53,450
You must STOP, press and hold the ABS button till the brake light glows red and then continue. There's no need to turn the engine off. When you want to re-activate it, you must stop, press the button again and go.
The ABS wheel sensors must not be sensing a rotating wheel in order for this to work, that's why you must stop. I have never seen any bike with switchable ABS where you can turn it off while the bike is in motion as a factory setting. On the SuperTenere 1200 since it does not have an ABS switch, someone made one, so you can turn it off at any time.
Old 11-25-2010, 05:48 AM   #3
Migs OP
Migs's Avatar
Oddometer: 165
Thanks GB! My ideal would have been to figure out a way to turn it off on the go. Because I forget sometimes. (Most of my riding is off road or dirty slimy road).
Migs
Old 11-25-2010, 06:00 AM   #4
GB
Mod Squad
GB's Avatar
Oddometer: 53,450
Migs
you can't, without triggering a brake fault code and cutting into the bike's harness, such as running a switch to one of the ABS wheel sensors.
Old 11-25-2010, 06:46 AM   #5
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,168
Not exactly true, GB. On the F twins you only need to slow to <5 mph to disengage the ABS. It's in the owner's manual, and I've verified this myself a few times now. Granted, it's often easier to just come to a full stop. But you don't have to.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 11-25-2010, 07:05 AM   #6
GB
Mod Squad
GB's Avatar
Oddometer: 53,450
Well, since the speedo doesn't exactly show speeds at or below 5 mph, the bike is basically nearly stationary and barely self balanced, might as well put a foot down, disengage it and ride off
Old 11-25-2010, 07:53 AM   #7
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,587
Hey, do you have to be in neutral?
For some reason, I've done it a million times and I can't remember if I ever tried it while in gear (stopped or moving), mostly habit for me to put it in neutral when I come to a stop for ABS....
EnderTheX is offline   Reply With Quote
Old 11-25-2010, 11:09 AM   #8
Migs OP
Migs's Avatar
Oddometer: 165
I read somewhere that all you have to do to be in permanent non-ABS is to cover up one of the ABS sensors (like with Duct tape). Anybody tried this?
Old 11-25-2010, 12:10 PM   #9
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,587
Pretty sure this won't work...
1. These sensors are very close to the ABS wheel so something like duct tape might interfere and you could damage the sensor.
2. They are Hall effect sensors so they work by detecting the moving metal in the sensor wheel that is mounted to the hub. While these sensors do have to be close to the metal to work, something non-metal between them and the metal wheel should not affect the sensor. These are not optical sensors that you can fool with tape.
Old 11-25-2010, 04:09 PM   #10
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,168
Nah, pull in the clutch, hold down the ABS button, and off you go!
David
David
--Curly
Old 11-25-2010, 07:59 PM   #11
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,587
David
Sweet!!!
Old 11-26-2010, 06:23 AM   #12
JRWooden
Oddometer: 3,434
I have heard of people unplugging the rear sensor to disable it.
The connector is under the seat near the rear spring on the twins.
I have not tried this myself.
Old 11-27-2010, 08:18 AM   #13
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 937
I know of an easier way.
Its about $1000 USD cheaper, too.
bxr140 is offline   Reply With Quote
Old 11-27-2010, 08:34 PM   #14
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 978
Isn't there a fuse specifically for the ABS?
David
'07 VFR800, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Alaska Trip Report
MTrider16 is offline   Reply With Quote
Old 11-27-2010, 10:02 PM   #15
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,168
Nope, no fuses on the F-twins. But I believe that JR is correct. There's a connector under the seat that when unplugged disables the ABS.
David
David
--Curly
Times are GMT -7.   It's 08:36 PM.
