Old 03-07-2011, 05:48 PM   #31
Bayner
Oddometer: 1,599
Originally Posted by YetiGS View Post
He says it's doable. I'm going to send him close up pictures of the connectors when I get home so he can cross-reference them against his supply of BMW connectors and then make up a switch to test. I'll keep y'all posted.
If I was going to try it, I'd look to do the same. Make a switch that just plugs between the stock connectors. No warranty issues, no wiring troubles.
If the computer isn't constantly checking for continuity or has no minimum absolute voltage trigger, you could run into a problem where the brain box assumes the front wheel is locked because it is not seeing a varying signal when you trip a brake switch. I would assume that would not be the case since we are no longer in 1988.
Another effective solution would be to place a switch in the power supply to the ABS pump (if equipped), maybe even the valving depending on how it's wired.
Shielded wiring typically has a metal mesh below the outer plastic skin to reduce electromagnetic interference.
Bayner is offline   Reply With Quote
Old 03-07-2011, 07:19 PM   #32
MonsterJ
I have motopsychosis
Oddometer: 262
Yeti, your bypass switch will be shielded as well, right? Having been an electronics tech on aircraft for 15yrs believe me when I say if something isn't shielded and it should be, expect nothing but headaches and abnormal behavior. A cell phone in your pocket would place it about a foot away from this connection and could really wreak havoc on the inductance signal coming in from the wheel sensor resulting in unpredictable behavior with the ABS while it's on or while you think it's off.
-Nooner
Temple, TX -> Cape May, NJ -> Mobile, AL -> ECity, NC -> Kodiak, AK -> Mobile, AL -> Sacto, CA -> Cape Cod, MA -> New London, CT -> San Francisco, CA -> Juneau, AK (summer of '13) -> where to next?
MonsterJ is offline   Reply With Quote
Old 03-07-2011, 07:51 PM   #33
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
slow pokes... what do you think I've been doing all night?
p.s. - http://www.maxbmwmotorcycles.com/fic...8&rnd=03192010
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 03-07-2011, 08:59 PM   #34
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,575
It sure doesn't look like shielded wiring does it?
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 03-07-2011, 09:20 PM   #35
Bayner
Oddometer: 1,599
No it doesn't look like it is. I think the wires would look a bit thicker than that.
edit:
I looked in the Haynes manual and it doesn't indicate shielded wiring for anything but the CANBUS. Of course, who knows how accurate that is...
Bayner screwed with this post 03-07-2011 at 09:26 PM
Old 03-08-2011, 08:57 PM   #36
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
Yeti and I are working on finding the parts. We found one side and just need the other. I would offer two kits. One with a connector to a switch on the frame below the seat or you can just buy the connectors with wires alone and wire it to your own switch anywhere you want on the bike.
Please be patient as I'm on the road for most of March.
Burnszilla is offline   Reply With Quote
Old 03-08-2011, 09:10 PM   #37
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 646
This won't mess with the computer? I had a problem with my rear ABS sensor (got hit pretty hard and didn't work after) and it messed with other things, I remember the turn signals not turning off, can't remember what else.
I'll have one if you do.....
bodhizafa is offline   Reply With Quote
Old 03-08-2011, 09:21 PM   #38
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
We will research and test everything before going to market with this. I don't want to break anyone's bike and be sued.
Old 03-09-2011, 07:03 AM   #39
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
with the ABS unplugged the auto-off turn signal feature does not work... weird I know...
Ben
My Photo's
Old 03-09-2011, 07:42 AM   #40
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 646
Lets cross our fingers and hope this works out
Old 03-09-2011, 11:43 AM   #41
jessehere
Ridin'
jessehere's Avatar
Oddometer: 782
It would be easy to shim out the abs sensor on the front wheel with a few washers. That would fault out the abs. I think the speedo reads the rear wheel sensor. (IIRC) I did it on my F650gs Dakar. It doesnt take much, as the abs sensor gap is very tight. I think it is like 0.4 mm
All you would need is some small washers and a torks driver. easily reversable
jessehere screwed with this post 03-09-2011 at 12:02 PM
jessehere is offline   Reply With Quote
Old 03-09-2011, 05:36 PM   #42
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,685
ABS swutch
Sounds great. Would love to be able to switch the ABS off for a whole day at a time!
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 04-18-2011, 01:37 PM   #43
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
I may have found the matching connectors. Finding out from 'my guy' if they are the correct ones and if I can purchase them.
Can someone find a good switch that can be easily mounted for this? Or provide me with the diameter of the frame tube below the seat.
Options: Frame tube mount below the seat? Forward mount near the gauges?
Old 04-18-2011, 04:24 PM   #44
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
From what i have noticed, the auto off blinkers only work over a certain speed. I am assuming that the blinkers use the ABS wheel sensors to tell how fast you are going.
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 04-18-2011, 05:01 PM   #45
Burnszilla
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
I hardly use my signal lights when dirt riding.
Times are GMT -7.   It's 01:09 AM.
