02-08-2012, 08:25 PM
#181 | |
Oddometer: 164
Here's the starting drill I've used on thumpers all the way back to my 1987 Husqvarna 510 (which is the granddady to the '98 you're looking at). Turn on the gas and pull in the decompressor. Kick the engine through 10 times with the throttle closed. Turn on the choke and slowly kick the lever through until it comes to a sudden stop against the compression of the engine. This is called "finding top dead center". Pull in the decompressor and kick the lever another inch or so. Release the decompressor, bring the lever all the way to the top and kick like your life depends on it. It should start. If it doesn't, kick it a few times with decompressor in, find top dead center again, go just past with the lever, and give the kicker another big boot. If it still doesn't start, it might be flooded so you'll want to turn off the choke, pull in the decompressor, kick 10 times and start all over again. If it still doesn't start, you've got something else wrong. Like was said earlier, could be valve adjustment or stator. My '97 FC600 wouldn't start with the stock Delorto carb. I tried a Delorto from a '95 FE501 and it would start but it was very difficult. I installed an Edelbrock pumper carb and the starting did not improve but it ran much better once it was going. Then I installed a Keihin FCR carb. The starting still didn't improve but it ran AWESOME once it was going. There's a procedure for testing the stator. I can't remember what it is but you can find it on the UHE websight. My stator was suspect so I swapped to the stator from the 501. Now it'll start so easily that I can get her going with my arm! Incidentally, with my starting procedure, I've never found the auto decompressors to be of any use. I've removed the one from the 600. However, on my 501, I suffered from a broken decompressor lever for a while. This caused me to spend a little time getting the auto decompressor adjusted properly. The 501 became quite easy to start after that, despite still having the Delorto carb.
04 GO!!!!, 08 KTM 250 SXF (now a 300, now for sale), '07 Beta Rev 3 Frankenberg (98 600 motor, 00 boingers and plastic, 03 frame) '08 Husaberg FE550 (superior V to R bike), '68 Yamaha DT1 '72 Bultaco Alpina 250 (Mom's old bike) |
02-08-2012, 08:32 PM
#182 | |
Oddometer: 164
There are several great sources of parts. The two that immediately come to mind are Motoxotica (I think they're in Vacaville or thereabouts) and Bozarth's Offroad in Portland. Taffmeister on the husaberg.org websight has a lot of parts for the old bikes as well.
02-08-2012, 09:38 PM
#183 |
Location: San Luis Obispohwait.....Fresno..how'd that happen
Oddometer: 42
Thank you for the responses especially about how to kick start the beast. I am somewhat skeptical about making the purchase though... this is pretty much a straight up race bike correct? Does anyone know what the service intervals are for the valves and oil change? Is the Valve adjustment just a simple screw type adjuster or shims? So this bike has been ridden on the street a good amount form what it sounds like. How long lasting should the motor be?
There is no gain without risk. |
02-08-2012, 09:48 PM
#184 |
Oddometer: 1,663
Due to the 2 ring piston and loose clearances they contaminate oil quickly. You'll use alot of clutch too, easier than the trhottle to control the drive. Oil change is at +/- 5 hrs
After I fitted new valve seat real early on, its hardly ever neede a valve adjustment. Screw adjusters. Using the 1/6 - 1/8 turn method its a 10 min job. Be a fun project, but needs patience. Still as fast as most things out there, but it is a race bike, and even with the balancer on the estart motor, they have some vibes. Lots of street use may cause gearbox issues if no cush hub. They do have a tough gearbox and clutch though. Changes sweetly too. A good clean tidy one might be worth something in years to come too. And the 98 had most of the bugs out. Only real issues are SEM stators and roller followers need replacing from time to time. Later followers can be fitted and problem solved too. Plasitcs are getting hard to get, especially the fluro ones, which fade a age quickly, even in the dark. Steve |
02-09-2012, 01:20 AM
#185 |
Oddometer: 417
After around 6 years of owning Husabergs, it's still the only bike I get excited just thinking about!
Started with the 450 and loved it.....whether it loves me is often another matter ![]() Checkout the front fender ![]() ![]() Misery! ![]() So, after a few years the old 450 had taking a bit of punishment and I found an almost new 550.....let's see if that's any better ![]() ![]() It's an awsome bike, that's for sure ![]() ![]() I had a slight er...misjudgement here and remembered Husabergs don't like being upside down in the middle of nowhere as the oil drains into the airbox and chokes the carb. Flushed the carb by pouring petrol through the intake and eventually it started with no harm done, despite clouds of smoke!! ![]()
02-09-2012, 10:34 AM
#186 |
Gerry with a G
Oddometer: 96
2006 FE450 Dualsport
I finished converting this last year... Used OEM parts to convert to DS. Also found a aux. under saddle fuel tank and had James Renazco build a saddle for it. Keeping the thread alive!
02-09-2012, 06:42 PM
#187 |
Jason McDaniel
Oddometer: 68
I've got a 2003 FE 650e. I understand that the wheels were the same as all the later 'Bergs. Is that right? Or are they compatible up to 2008? Or what?
Jason McDaniel |
02-10-2012, 01:22 AM
#188 |
Oddometer: 48
Are those Bergs (FE450, 550, 650) comparable to KTM RFS or more to LC4,? Mainly weight and maintenance!
02-10-2012, 01:27 AM
#189 |
Oddometer: 15
Hey guys, just dropping in to say hi. My XR440 let me down on sunday for the last time, come tuesday I rode away from the shop on an 08 FE650E with 3000k's on it. What a bike, I'm in love. One question for you guys, been eyeing off the fan kit and tried doing a search but the search on this site sucks. Are they worth getting, i tend to do a fair bit of slow work when I go with my mates 4wd and am worried about the lack of airflow.
02-10-2012, 04:02 AM
#190 |
Beard Bros Racing
Oddometer: 10,159
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8"If you french fry when you shoulda pizza'd,your gona have a bad time".
02-10-2012, 06:48 AM
#191 | |
Oddometer: 370
http://www.husaberg.org/forum/viewto...=8106&start=15 |
02-10-2012, 07:32 AM
#192 |
Oddometer: 1,627
The RFS bikes. KTM, from what I understand, used the 'berg engine to design the RFS engine. I've also heard that an RFS head gasket will actually interchange with the earlier 'berg engine.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
02-10-2012, 03:26 PM
#193 |
Beard Bros Racing
Oddometer: 10,159
Ok,,ill pimp the thread,and post a daylight shot of the 08.
02-10-2012, 11:48 PM
#194 | |
Oddometer: 512
http://www.sharetrails.org/ http://www.americansandassociation.org/ "Yeah, well, you know, that's just, like, your opinion, man"-THE DUDE |
02-13-2012, 09:40 AM
#195 | |
Oddometer: 281
new Husaberg owner
Went from a DR650 to the WR250R The WRR was better than the DR650 at everything but power. Hopefully the FE450 will be as good with the power I want. I'll know as soon as the wether breaks. |
