Old 03-01-2012, 10:00 AM   #211
Multisurface Rider
Calvin
Multisurface Rider's Avatar
Oddometer: 383
05 FE450 for sale
Guys check out my add in the flea market. Thanks
http://advrider.com/forums/showthread.php?t=768958
Multisurface Rider is offline   Reply With Quote
Old 03-01-2012, 02:10 PM   #212
Bushmechanic
Bushmechanic's Avatar
Oddometer: 44
you could try an easy sleeve to repair that shaft
2008 Husaberg 700F 104kgs all fluids no fuel
frame build http://www.husaberg.org/forum/viewtopic.php?f=8&t=13268
engine http://www.husaberg.org/forum/viewtopic.php?f=5&t=12131
Bushmechanic is offline   Reply With Quote
Old 03-01-2012, 02:16 PM   #213
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 10,143
Easy sleeve?Sounds kinky.
Is that like a Helicoil?
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
AWM is offline   Reply With Quote
Old 03-01-2012, 03:25 PM   #214
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,406
speedi sleeve
http://www.skf.com/portal/skf/home/p...&newlink=4_5_3
kenny61 is offline   Reply With Quote
Old 03-01-2012, 03:33 PM   #215
Bushmechanic
Oddometer: 44
ha kinky like a shake weight
http://www.youtube.com/watch?v=dtvnan20XvQ
Ive never used on for a berg so I don't know if there is one the right size,
need to make sure the shaft is really really clean and smooth and also need to make sure the balancer shaft doesn't move toward the piston when you hit it or you would have to pry it back out when you are finished, not hard to do.
Old 03-01-2012, 03:41 PM   #216
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 10,143
Old 03-01-2012, 04:28 PM   #217
GlennR
Dodgin' the Ditches
GlennR's Avatar
Oddometer: 1,156
Originally Posted by kenny61 View Post
Those are great to know about.
free/online Motorcycle Repair Course-
GlennR is offline   Reply With Quote
Old 03-01-2012, 05:24 PM   #218
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,406
Dont get $$$$ shock when you need one. Think I paid around $40 to fix rear axle on my truck
Old 03-01-2012, 05:34 PM   #219
GlennR
Dodgin' the Ditches
GlennR's Avatar
Oddometer: 1,156
Seems like a lot for a "fancy piece of tube", except when you think about the costs of the parts and labor of what it saves you.
Old 03-01-2012, 07:15 PM   #220
Multisurface Rider
Calvin
Oddometer: 383
Thanks for the sugestions about an speedi-sleeve, I will look in to it to see if I can get one the size I need.
Old 03-02-2012, 06:06 AM   #221
kenny61
I'm Going Racing!!!
kenny61's Avatar
Oddometer: 18,406
catalog with dimensions
http://pdf.directindustry.com/pdf/ch...-66677-_9.html
Old 03-02-2012, 06:53 AM   #222
Multisurface Rider
Calvin
Oddometer: 383
Has anyone here ever used this on the balancer shaft?
Old 03-02-2012, 08:00 AM   #223
Multisurface Rider
Calvin
Oddometer: 383
I just measured my shaft and it is small .397 in., their min size is .472. I thought I would be out of luck but I called them anyway to see if they may have produced something smaller in the past. They do say this: "Depending on production quantities, non-standard sizes can be produced."
I called and was informed that it would cost a small fortune to have it made for me.
Out Of Luck.
I am thinking about rebuilding the bike, just not excited about doing it.
Thanks for the info.
Old 03-02-2012, 08:14 AM   #224
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 771
Calvin
you have a very good bike there that needs to be refreashed. I would look at it this way ( and i just did with my 550 )
you can have a basically new motor for around $1800. it can even be a 550 or 650 if you want for the same price. Upgraded parts to the 08 standard will be used and you have a bike that should be good for another 250 hours.
so you put $2200 in the bike and have a great ride that is as or more dependable and handels better than most out there.
seems like a lot of $$ until you think of buying a new bike at $8-10 k
Ride the DEZ
05 FE 550 Husaberg plated
09 KTM 690
bobzilla is offline   Reply With Quote
Old 03-02-2012, 08:16 AM   #225
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 10,143
[QUOTE=Multisurface Rider;18117567]I just measured my shaft and it is small .397 in., their min size is .472.
Dude!
No i wont say it,,,i wont!Kenny cant make me.
I think it helps to laugh when rebuilding your motor.
Times are GMT -7.   It's 04:14 AM.
