12-31-2004, 12:14 PM
#1 |
We Ain't Left Yet!!
Oddometer: 1,176
I need some help with my tachometer. I have an 87 BMW R80 with an electronic tach. It just recently started to Bounce/Wave after I ride for a while 83k miles. It is an intermittent problem. This is the dumb part. Any suggestions?
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything. -- Charles Kuralt I never plan a ride, just the destination and that's always subject to change. |
12-31-2004, 01:53 PM
#2 |
de-nOObed!
Oddometer: 5,050
Charging problem?
www.possu.smugmug.com |
12-31-2004, 02:21 PM
#3 |
GS Dork
Oddometer: 5,299
Check the battery connections and all of the ground wires for corrosion. Better yet, remove them all includignt he battery cables, clean thoer contact faces with 600 grip wet/dry sand paper and re-fasten them with dielectric grease (found at most hardware stores). Do the same with your fuses, the few that there are. These models of tach are very sensitive to poor grounding.
Hope this helps. Cheers, Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"." HST-RIP "Woof, woof woof woof ...woof woof!!!!!!!!!" Cricket the Dog-RIP |
12-31-2004, 05:05 PM
#4 | |
Oddometer: 277
Some Hall Sensor info here, it's for oilheads but it should help. http://users.rcn.com/dehager/ Google ??? BMW Hall Sensors, there is a site that talks about airheads. |
12-31-2004, 06:40 PM
#5 |
Mod-U-Later
Oddometer: 13,506
Also check your coil (both primary and secondary), and spark plug wires for opens. Sometimes the tach will begin to fail in just this way as well (you're at about the mileage where they can begin to wear out), in which case replacement/repair is necessary. This also applies to the speedo.
JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
01-03-2005, 03:45 PM
#6 |
Traveller
Oddometer: 6,593
On some of the airheads the ground for teh tacho was through the handle bars - and thus through the steering head bearings. Not a good idea. Suggest you run a new ground wire from the tacho back to the main ground point - On my G/S that is under the fuel tank on the main frame. Not the battery ...
If your hall effect sensors were failing you'd feel the power loss. Sp I don't think that is your problem.
Regards Frank Warner motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S http://www.geocities.com/fwarner_au/ |
01-03-2005, 06:06 PM
#7 |
We Ain't Left Yet!!
Oddometer: 1,176
thanks for the input!
I spent my new years with a wire brush and grease, with all the suggestions I'm sure I'm headed in the right direction.
THANKS!
