Old 02-01-2011, 06:51 PM   #1
MZRider OP
Neo-Luddite
Oddometer: 713
Shimming Airhead wheel bearings
Here's the situation: I'm working on a customer's '76 R90/6 and one of the previous owners has discarded the shims (#2 in the attached diagram) necessary to obtain the correct preload of the wheel bearings. My question is: without any shims whatsoever, how do I determine what thickness of shim I need? Should I buy all the sizes available, swap them in until I find the correct one and then return the remainder (if I can)? Is there an easier way that I'm not thinking of (short of taking the wheels to Bob's and letting them do it)?
I did spend a few minutes this evening on the lathe and turned out a shim which proved to be too wide, it's possible that I could carefully trim a .001" or so at a time off until it's the correct thickness. But, I'm worried that they need to harder than the steel stock I'm using.
Your helpful suggestions would be appreciated.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is offline   Reply With Quote
Old 02-01-2011, 07:57 PM   #2
pommie john
pommie john's Avatar
Oddometer: 1,455
If you can make them in a lathe but you're worried about hardness, I'd play around until you make one just the right size, then buy one that size from the shop. ( and a couple either side, just in case something settles).
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 02-01-2011, 08:11 PM   #3
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,368
I don't think the shims are very hard. Duane Ausherman makes and sells small shims to use with the BMW shim, or "wedding band", that he punches out of various thicknesses of shim stock. They are pretty handy to have around. If you aren't in a big hurry you could order some:
http://w6rec.com/duane/bmw/wheel_bearing/index.htm
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 02-01-2011, 08:18 PM   #4
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,050
Yep, what they said. Although after grinding/welding/modifying/fabricating some Ducati inner spacers in the past (I know, different bearings but same purpose and similar torques to preload properly), they did not appear to be hardened. So I would suspect at the preload/torque/clamping forces needed for the airheads, that mild steel spacers of the proper wall thickness would be fine.
But if in doubt, I'd go with finding the correct length with a series of lathe cuts and trial fits. Then buy the corresponding OEM spacer (+ or - one size either way.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 02-02-2011, 06:01 AM   #5
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,708
Woody's Wheel works sells sealed bearings to do w/o the shimming if the bearings. Might want to give that a shot
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-02-2011, 08:00 AM   #6
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
to shim or not to shim?????
if you have the expertise and the torque wrenches for ft/lbs and inch/lbs and are doing the wheel install as well as the tapered bearing pre-load..you have a good chance for a good outcome....
it is dependent on accurate bearing pre-load ,,,[circa 9 inch lbs drag at 28ft/lbs for the front and 32ft/lbs on the rear....]
the pickle is that the wheel installer must be able to torque the axle nut to the same value as the person who set up the tapered bearings for this system to work,,,,
i have repaired countless fried tapered bearing set-ups caused more often by over-tightening the axle nuts,,leading to excessive crush,,overheating and seizure/spun races....how many of us have torque wrenches in our tool-kits after all???
[ i was my own victim on my first BMW,,a R75/6,,didn't know anything about torquing axles,,,i went 1,500 miles before the front wheel locked up at 80 in the fast lane of the pennsylvania turnpike...i
that story is chronicled elsewhere in the forum...
not having access to tapered bearings ,,i realized i could convert to sealed ball bearings with a custom spacer,,,,the motorcycle shop to which i had been towed,,,let me use their tools and lathe,,,they stayed behind,,fed me and put me up for the night,,,i've never forgotten the gesture and have reciprocated ever since...]
i had many miles to cogitate over better ways,,,,i put another 60,000 trouble free miles on those ball bearings before i sold it....
the next modification was to the oem way of setting the shims up,,,seeing as to how Harleys use a similar technique and actually had IMHO excessive end-play[ circa .003-.016 as their spec ],,i tightened up the Harley spec to .001-.003'' and all the BMW's to .000''at 50 ft/lbs...i figured that should cover the bases,,and it has...
my track record= .0000 failures,,,,thousands of miles of worry free riding....the harleys handling went from the never ending feeling like you were riding on marbles to precise handling and the BMWs didn't lose any handling while enhancing the safety and longevity of the tapered bearing.
the beauty of the sealed ball-bearing set-up is the ease and lower$$$ of maintenance,,,
OBTW,,i haven't forgotten how to do it the oem way,,it does require an extensive collection of shims or access to them...and the aforementioned torque wrenches for this set-up to work ,,,,truth be told i'm a KISS kind of guy
w
PS,,,it is simpler to get in the ball park by starting out with a longer shim,,tighten things up and then measure the end-play with a dial indicator,,then ya can measure what's in there and adjust accordingly,,OBTW ya don't need the BMW spacer shim & shim holder ,,it is a lot simpler to make a new solid spacer that can be cut down to spec in a lathe,,,trying to make bmw shim replicas is frought with not getting the cuts parallel,,then ya have even worse problems.
PPS,,you should really ask these questions over here,,,
http://www.advrider.com/forums/showthread.php?t=145899
i
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 02-02-2011 at 08:32 AM
Old 02-02-2011, 09:12 AM   #7
supershaft
because I can
Oddometer: 9,116
I like your PS woody.
I shim wheels with the axle in a vise and a easily made spacer so the the axle nut loads the bearings. I use a torque wrench to tighten the nut to spec but that is only to insure that the axle is tight enough that being any tighter won't effect bearing adjustment. I adjust the preload by feel. If done right, that bearing spacer stack will not crush with any reasonable amount of torque put on it. I have been around airheads for a long time and if properly set up wheel bearings depended on torquing them to the exact torque that they were set up at BMW would have gone out of business a long time ago for making bikes that won't roll. The axle nut is not the bearing adjuster. That is the whole essence of the adjustable stack! With the stack adjusted right, the axle nut can from then on be tightened enough to way too much and not effect the bearing adjustment at all. The axle nuts have been over tightened by hand all the time for decades. That is when they are adjusted right to start with.
All that being said. I would convert tapered bearings to sealed ball bearing in an instant!
supershaft screwed with this post 02-02-2011 at 09:49 AM
Old 02-02-2011, 09:39 AM   #8
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,671
Start with a 6.8mm shim. Virtually all the shims I've fitted have been somewhere round there.
You just need something like this to get the torque right http://www.uni-max.co.uk/torque-scre...nm-28pc-set/d/ along with an adapter to allow a wheel nut sized socket to fit and a 2.3" long tube to to fit over the spindle and allow the nut to pull down on the bearing. The acceptable range for the torque is 1.5 to 4.5 N/m. Ideally 3N/m
This is my set up
Pre set torque drivers were 99p each on ebay, the hand adjustable driver was 10 again on ebay.
Calibrated gauge to set up the pre set drivers though to be honest I hardly ever use them since I picked up the hand adjustable one.
The whole set up came to less than having the dealer fit and torque a set of wheels bearings and shims for me.
Here's BMW's explanation
Rob Farmer screwed with this post 02-02-2011 at 10:06 AM
Rob Farmer is offline   Reply With Quote
Old 02-02-2011, 09:54 AM   #9
R12Battletub
nooblet
Oddometer: 314
Cycleworks sells a kit with a bunch of very thin shims in it. They are used in conjunction with the "tube" spacer to get things to the right spec; no need to buy a pile of the tubes in various sizes.
R12Battletub is offline   Reply With Quote
Old 02-02-2011, 10:55 AM   #10
El Hombre
Oddometer: 1,536
w
i
I was wondering about dumping the tapered bearings and going to ball. Four 6203 bearings are on order. I have the lathe and measuring tools to make a custom spacer. I looked at your thread, you mentioned the spacer is .010" longer than the hub flanges are apart. Any particular reason for that?
El Hombre is offline   Reply With Quote
Old 02-02-2011, 11:07 AM   #11
gplane
Brush With Destiny
gplane's Avatar
Oddometer: 901
Duane
Read Duane's article. Well worth the time. I don't know if Duane still sells the shims, but I think Cycle Works or Bench Mark Works does.
gplane is offline   Reply With Quote
Old 02-02-2011, 11:27 AM   #12
supershaft
because I can
Oddometer: 9,116
Dealerships still sell most of them I believe.
From reading that article myself and reading what others get from that article, I think it gets people treating the axle nut as if it were a bearing adjuster. He says it doesn't but then it does. He says that his article doesn't say to do that but then he recommends running the axle nut loose or it will bind the bearings. Not if they are adjusted right! IMO, he is setting up people that tighten axle nuts like they should be tightened for bearing failure. It's self fulfilling if you think about it.
supershaft screwed with this post 02-02-2011 at 12:04 PM
Old 02-02-2011, 11:50 AM   #13
woody's wheel works
Built to Last
Oddometer: 3,426
why the extra length of spacer for ball-bearing install...
sure is elhombre et al,,,
we want that extra length to insure that the inner races will not be compressed /bind against the outer races...when tightening the axle
hence the rule of thumb in the industry is to make the inner spacer .010'' longer when made of steel and .020'' longer when made of aluminum[usually 6061-T6]
woody
woody's wheel works screwed with this post 02-02-2011 at 01:13 PM
Old 02-02-2011, 12:19 PM   #14
nella
nella's Avatar
Oddometer: 403
I haven't had any problem making these shims out of mild steel on a lathe.
Scott
nella is offline   Reply With Quote
Old 02-02-2011, 12:38 PM   #15
El Hombre
Oddometer: 1,536
woody
Thanks for the quick reply, I thought it might have something to do with pinching the bearings. Have you noticed any difference in the name brand SKF, etc. and the cheaper ones? I ordered two of the SKF for the back wheel, and going to try two of the cheaper ones up front.
Times are GMT -7.   It's 07:46 PM.
