Old 12-06-2010, 05:02 PM   #16
danedg
Horizontally Opposed
Oddometer: 6,726
...maybe we otta chug on over to Namby Pamby Land, and try to find you some self CONFIDENCE...and a real piece of PIPE!!!!!!
The tire iron is for CARS!!!!!
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 12-06-2010, 05:11 PM   #17
Beater OP
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,522
I love that commercial. One of the funniest things I ever seen ...
http://www.youtube.com/watch?v=JhlWddAXSRA
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 12-06-2010, 05:17 PM   #18
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,644
Originally Posted by danedg View Post
when you grind the socket down it'll get cherry red...dunk it in water real quick and it'll retemper {harden} the alloy..
Ya know, I've read a lot about the advantages of using oil instead of water; introducing carbon into the steel, yadayada, but I've never done it.
crazydrummerdude is offline   Reply With Quote
Old 12-06-2010, 06:21 PM   #19
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,608
I think Greta will get G/Sified. Thoughts?
trade it for a dr650? Nobody should put themselves through the torture of owning TWO airheads
I don't know anything about lifting the back end of a twin shock. I don't know of any builds that'd help either. It'd be a trial and error process trying to get shocks.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 12-06-2010, 06:45 PM   #20
Beater OP
Beater's Avatar
Oddometer: 3,522
I'm a glutton for punishment.
I really wouldn't do much lifting and such ... I think I'd really just upgrade the forks and rear shocks ... and change the final drive to a 37:11. That would gear me down a bit. I'm not looking to to go big ... just wanna cruise the trails and such.
Old 12-06-2010, 06:50 PM   #21
danedg
Oddometer: 6,726
...but first, we have to figure out a way to get yer nuts off
Old 12-06-2010, 06:52 PM   #22
fishkens
Further...
Oddometer: 5,149
Nice work, Beather. We knew you could do it!
when you grind the socket down it'll get cherry red...dunk it in water real quick and it'll retemper {harden} the alloy...
Alloy? They make big ass 36 mm sockets out of aluminium? I never knew.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 12-06-2010, 06:54 PM   #23
Beater OP
Beater's Avatar
Oddometer: 3,522
I'm not going to respond to that.
Old 12-06-2010, 07:44 PM   #24
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 994
Oh man, dont get Flatulator started again...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 12-06-2010, 07:46 PM   #25
Jasper ST4
Guest
Oddometer: n/a
With a name like Beater, I'd a thought he got it figured out.
Old 12-06-2010, 08:03 PM   #26
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,608
Old 12-06-2010, 08:17 PM   #27
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,712
you can put a torch on it, might blister the paint...heat gun works pretty good
next time you'll put neverseize on the bastard.....you won't have this problem
+1. Apply heat to the nut. Then, put the socket on the nut and give it a good whack with a hammer. Apply an impact driver to it until loose. Repeat Kroil, heat and impact driver cycle until you're done.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 12-06-2010, 08:19 PM   #28
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,712
Alloys are a blend of two metals, neither one of which has to be aluminum.
Steel is an alloy.
IMHO.
Old 12-06-2010, 08:23 PM   #29
P B G
Oddometer: 10,001
I have a flat spanner that works great for it. I believe it comes from a Porsche 356 tool kit to do the generator belt nut.
Either way its fully flat, and the handle has a hole for a 1/2" breaker bar.
They're like 20 bucks.
Oh and big bonus, no offset.
By this I mean if you use a 36mm socket, you have 1-2" from the bolt to where the leverage is applied, that offset makes wrestling everything into place then applying the high torque required quite difficult.
With a tool like this the torque is on plane w/ the nut, so it doesn't twist or roll around.
Old 12-06-2010, 08:28 PM   #30
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Originally Posted by MacRunch View Post
Pick up a heavy piece of pipe at least 3 ft long. Place it over your breaker bar and just wrench away. It's all about leverage. I believe I read one time that Matt Parkhill uses an old airhead fork slider tube to extend the breaker bar.
A fork tube, not a slider.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Times are GMT -7.   It's 03:16 AM.
