Old 12-08-2010, 06:05 AM   #1
genka OP
SUV hater
genka's Avatar
Oddometer: 935
Wicked Vario Cases Modifications
I want to see how you modified Vario cases. Straps to prevent stuff from falling out? External loops? Reinforcements? Lights? Something else?
genka is online now   Reply With Quote
Old 12-08-2010, 06:38 AM   #2
DenniSMC
The M is silent...
DenniSMC's Avatar
Oddometer: 4,582
Send a message via AIM to DenniSMC
I am doing mine now. I put footman loops on the doors. And ROK 12"s in them. I use the stock mouting points under the seat for the other halves. The drawback is you need to unclip the straps to open the doors. But I only put my tent and small duffy on them. So its no big deal.
For inside I bought liners from Feebay. $65 and no worries. Just pull the bag out and dig around in it. Then put in back in.
Motorcyclist? Maybe... Traveler? Definitely... Adventurer? Not so much. Scooter trash FOREVER!!!!!!
A shameless plug of my Control Riding III Video- The KLR650
DenniSMC is online now   Reply With Quote
Old 12-09-2010, 06:24 AM   #3
genka OP
SUV hater
genka's Avatar
Oddometer: 935
Only a single reply! I guess everyone like their Varios the way they are...
Old 12-09-2010, 06:39 AM   #4
mb90535im
'05 R1200 GS
mb90535im's Avatar
Oddometer: 4,070
I use my Varios all the time and when traveling backing forth between home and weekend cabin typically add the BMW Vario liner bags. Haven't felt the urge to farkle them any further at this point.
I do disassemble and clean them a time or two a year depending on how much dust they see.
"Dang man I'm impressed." - Willy-B
"Are you OK? ... Are you sure you're OK?" - Honcho
"Disturbing and funny, all at the same time." - MrTwisty
mb90535im is offline   Reply With Quote
Old 12-09-2010, 06:47 AM   #5
DenniSMC
The M is silent...
DenniSMC's Avatar
Oddometer: 4,582
I think most are afraid to try anything with them. Mechanically its real easy to screw them up. Even what I am doing might not be strong enough to strap things down tightly.
My first idea was to sell my bags and buy something else that is meant for what I have planned. But I am one of those poor BMW owners. To spent 1500-2000 on luggage is insane in my finacial situation would be selfish and careless. I would have to give myself a huge kick in my own ass if I spent that money like that. For what? A few more liters of storage? Vario 37-45 liters is not bad. The Tourtech stuff is only a liter more. I know they are stronger. And I would like them. But I already have these. SO I will use them until they are beat to crap. Hopefully the Footman thing works out. It would be a shame if it just ripped the cover off the door. I assume if i just strap things down tight enough it should be ok.
Old 12-09-2010, 07:14 AM   #6
Lensgrinder
Oddometer: 1,018
I added a 12v power supply to my top case so I could recharge my laptop and cell phone while I was riding. It worked great on my trip to Alaska and back. It plugged in under the passenger seat in the socket provided.
Pain is Temporary, but Quitting Lasts Forever!
2012 R1200GSA
2009 F650GS (Wife's)
1987 Husqvarna WR 430
Lensgrinder is online now   Reply With Quote
Old 12-09-2010, 08:11 AM   #7
Z50Pilot
Sparky
Z50Pilot's Avatar
Oddometer: 235
power supply
+1 I have an SAE connector under the seat and can disconnect it when I remove the top case (which is almost never).
I also carry a couple of straps in the top case, in case something breaks and I need to strap a bag on/closed.
PJ
Never lend a friend your Pacific Coast. Unless you like scratches and want a beer annuity
Z50Pilot is offline   Reply With Quote
Old 12-09-2010, 11:24 AM   #8
DenniSMC
The M is silent...
DenniSMC's Avatar
Oddometer: 4,582
I got one bag this morning. But my ROK straps are not here. But here is the way it looks.
I know its not rocket science. But those blank spots looked like they were waiting for Footman loops.
I put fender washers on the inside. As long as you don't try to animal the straps down with anything heavy, they should be ok. I only plan to put a tent, duffel or small gas can there. It should be ok.
Old 12-09-2010, 12:37 PM   #9
JethroDog
dogs bark
JethroDog's Avatar
Oddometer: 168
I think the mod that the Vario side cases really need are an additional brace for stability. These cases essentially attach at the top and side and allow too much "wobble". I've thought about attaching a brace between the two cases at the bottom rear corners to reduce the sag and take the wobble out. There is a big difference between the way the bags hang on the bike empty and then loaded/extended. I've not ridden with the Varios off road, but I think the plastic side attachment point would eventaully fatigue and fail.
Jethro
'09 R1200GS
'83 R100RT
JethroDog is offline   Reply With Quote
Old 12-09-2010, 01:05 PM   #10
DenniSMC
The M is silent...
DenniSMC's Avatar
Oddometer: 4,582
Mine Offroad did surprisingly well. But I agree. They will not last forever. I give mine 3 years tops.
Old 12-09-2010, 01:09 PM   #11
Juvat
Juvat's Avatar
Oddometer: 695
I consider my Varios to be a commute only option for hauling my stuff. I really like the expandability feature but I realize it's plastic and would probably not hold up consistently to a more serious ride. You have spurred me into thinking about some kind of netting install to keep the junk in place when I open the cases.
Juvat is offline   Reply With Quote
Old 12-10-2010, 07:54 AM   #12
LaurelPerryOnLand
Oddometer: 2,422
To keep varios from opening...
I've drilled both the latch and the corresponding 'square piece' that sticks out from the case with a small 1/8" hole and inserted a "R-clip". While normally these latches will not open...taking a spill or extremely rough roads might (and does) unlatch them and the cases can go flying if the mushroom bolt is not properly adjusted.
Also...not pictured...I've drilled a hole through the back of the case (nearest the center of the bike) and continue through the vario mounting bracket. Then, I inserted a 1/4" diameter x 1 1/2" ? length clevis pin (the ones with variable hole lengths) with another R-clip. Put washers on both the outside of the vario mount and the inside of the case. This setup positively keeps the cases from falling off if the 'mushroom' bolt is not, or becomes improperly adjusted.
Photobucket
Most importantly...keep the 'mushroom' bolt properly adjusted. Seems important enough for BMW to have issued the bulletin below.
Photobucket
BTW...this stuff is GREAT for keeping the cases looking NEW! It's CLEAR acrylic that remains CLEAR! Clean first and apply with sponge or soft cloth.
Photobucket
Also..do yourself a favor and before each ride or at a gas stop...try to LIFT upwards on the cases to insure that they're properly secured.
Takes only a moment and can save you $466.95, per MAX BMW!
LaurelPerryOnLand screwed with this post 12-24-2010 at 07:59 PM
LaurelPerryOnLand is offline   Reply With Quote
Old 12-10-2010, 11:08 AM   #13
genka OP
SUV hater
genka's Avatar
Oddometer: 935
DenniSMC, nice loops! I think they will hold. Plastic cases are not that bad. This summer I had a spill on my Moto Guzzi, the affected case ended up with some serious rash and loose hardware, but wasn't affected functionally. And those Aprilia sourced cases look much flimsier than Varios.
Since we are talking about caring for the cases, I found a thread about cleaning the expansion mechanism: http://www.advrider.com/forums/showt...51#post7282851
Old 12-13-2010, 10:01 PM   #14
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,338
I added Bungee Buddies. I positioned them so the cases can be expanded/contracted without interference. Makes it easy to carry and lash something across the pillion.
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney is offline   Reply With Quote
Old 12-14-2010, 03:11 AM   #15
DenniSMC
The M is silent...
DenniSMC's Avatar
Oddometer: 4,582
How do they attach?
Times are GMT -7.   It's 04:32 PM.
