Old 03-31-2011, 10:07 AM   #1
DRZ Charlie OP
Old & beat up
DRZ Charlie's Avatar
Oddometer: 11,081
Convert a .gpx file for viewing in Google Maps - How To
The following is a tutorial on how to convert .gpx files into .kml files for viewing in Google Maps.
1. Save your .gpx file where you can find (I place it on my desktop for ease of retrieval)
2. In your webrowser type: www.gpsvisulizer.com
3. When GPSVisualizer opens find the box that says "Get Started Now"
4. Next, minimize the window and drag the .gpx file (from your desktop) into the "Get Started Now" box at the window that says "Upload a GPS file" (you may alternately browse to it). You will note that the file name is now in this window.
5. Choose your output type. You want "Google Maps" which is also the default in this window.
6. Click "Go"
7. The file will now be converted and GpsVisualizer will open the original .gpx file in Google Maps.
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat
My SPOT - No tracks = not riding | Mapsource Tutorial | Rides
DRZ Charlie screwed with this post 03-31-2011 at 11:08 AM
DRZ Charlie is offline   Reply With Quote
Old 03-31-2011, 06:10 PM   #2
SnowMule
SnowMule's Avatar
Oddometer: 16,051
Google Maps can also load the information out of a GPX file that's online...
I have a file, "20100822.gpx", on rootdir of my webserver...
http://wildcat.homeunix.net/20100822.gpx
copy that URL and paste it in teh google maps search field:
http://maps.google.com/maps?q=http:%...2F20100822.gpx
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 04-05-2011, 06:05 AM   #3
DRZ Charlie OP
Old & beat up
Oddometer: 11,081
Thanks ShowMule I like that.
Old 04-12-2011, 10:12 AM   #4
WERA456
WERA456's Avatar
Location: North Ga. (The site of the first major gold rush)
Oddometer: 178
So now how can I get it from gpsviualizer (google maps) into just google maps. I would like to be able to save it to "my maps" so I can come back and get it later. Also if I could get it into regular google maps then I could drag and edit the route.
WERA456 is offline   Reply With Quote
Old 04-12-2011, 06:06 PM   #5
abhibeckert
abhibeckert's Avatar
Oddometer: 1,422
This is all I do:
* go to maps.google.com
* log in with my google account (if i'm not already logged in)
* click "my maps" on the left
* click "create new map"
* click "import"
* it says to choose a KML/KMZ/GeoRSS file, but a .gpx file works perfectly too
* select your gpx file, and press "upload"
* done!
Here's a test gpx import I created just now: http://maps.google.com/maps/ms?ie=UT...25b9e62f6e6e1a
abhibeckert is offline   Reply With Quote
Old 04-12-2011, 06:07 PM   #6
DRZ Charlie OP
Old & beat up
Oddometer: 11,081
Originally Posted by abhibeckert View Post
This is all I do:
* click "import"
* done!
Good stuff.
Old 05-23-2011, 10:41 AM   #7
Visian
Look out!
Visian's Avatar
Oddometer: 1,519
I've tried both the abhibeckert and SnowMule methods above and all i get is a lot of blue waypoints (?) on a google map... no line showing the roads that connect.
What am I doing wrong?
on edit: for clarification, it looks like abhibeckert created a track, exported a GPX and then generated a google map. I am using Routes... could this be the difference?
for a variety of reasons, I don't want to use a 3rd party site.
Go soothingly through the grease mud, as there lurks the skid demon.
________________________________________________
'86 R80 G/SPD+ || '00 1150 GS || '06 HP2e || '67 Trail 90
Visian screwed with this post 05-23-2011 at 11:02 AM
Visian is offline   Reply With Quote
Old 05-23-2011, 11:23 AM   #8
SnowMule
SnowMule's Avatar
Oddometer: 16,051
Routes are a list of major points (the waypoints you're seeing) that are connected using data from the mapset. You would put in two waypoints, like the bank and the store, then generate a route from the bank to the store. The receiver/computer/whatever would use the street information in the mapset to get a left-turn, right-turn, go-straight, turn-here path to follow. Routes are highly dependent on the receiver's ability to generate a path and the map information available.
Tracks are a large list of minor points that are connected to each other. No information from a mapset is used to generate or display these. As a result, nearly any GPS can use these. My old GPS12 with no maps at all could use a track for navigation, provided it fits in teh limited 1024-point memory.
A lot of people use tracks as a route because it gets rid of any specifics to a mapset... mapset A may take you along the highway to the store, while mapset B will route you along side roads. A track is just a list of digital breadcrumbs to "pick up" as you head to the store, it won't have the voice-prompted turns that a route would have.
Old 05-23-2011, 11:58 AM   #9
mrprez
KJ4WMZ
Oddometer: 1,260
Send a message via Skype™ to mrprez
Very well explained. Answer me this. When you are creating a map in Google Maps and you use the "follow roads" or "snap to roads" what is that? A route or a track? Also, do you know a way to make it stop trying to route you a different way? Whenever I try to use it, the feature wants to try and find a "better" road to take.
mrprez is offline   Reply With Quote
Old 05-23-2011, 12:56 PM   #10
SnowMule
SnowMule's Avatar
Oddometer: 16,051
Google Maps would be a route... you've got Point A (Northglenn, on I-25) and point B (Idaho Springs, Point B), and Google's using its mapset go generate the I-25/I-76/I-70 route.
edit: okay, embed's broken.. click this
A track would look more like this, has a much higher resolution of points along the path you want to take. If you were to plot each of these points in a track connected by straight lines between points, you could follow that regardless of what (if any) mapset you had installed.
Linky
Old 05-23-2011, 01:35 PM   #11
mrprez
KJ4WMZ
Oddometer: 1,260
Here's what I'm doing. I made a mapset using the snap to road feature. Saved it as a KML file and uploaded to the iPhone using Accuterra. AT does not support routes, only tracks. When I view the track in AT, the track still follows the road, not point to point! Pretty cool but using the snap to road feature is a Major PITA.
Old 05-23-2011, 01:53 PM   #12
Visian
Look out!
Visian's Avatar
Oddometer: 1,519
good explanation, indeed. thanks. it's essentially like bit map vs. vector in the graphics world.
unfortunately, while one can create a route from a track, there appears no way to export a Track from a Route.
i've got a bunch of GPX routes of rides that others have provided. i'd like to turn into Google maps and provide direct links. there is not enough time to do it manually.
i tried communicating with the tech support guy at GPS Visualizer and he just spoke way over my head... we couldn't connect, conceptually, as to what i am trying to do.
Visian screwed with this post 05-23-2011 at 02:01 PM
Old 05-23-2011, 01:58 PM   #13
Steve W
Old Grouch
Steve W's Avatar
Oddometer: 541
The newest Mac BaseCamp Beta can do exactly that. It might not hurt to download and try the Windows version if you have not yet seen the light.
SW
Steve W is offline   Reply With Quote
Old 05-23-2011, 02:02 PM   #14
Visian
Look out!
Visian's Avatar
Oddometer: 1,519
ok, thanks.... Basecamp is what i am using. 3.1.4 (beta crap on Mac scares me....and i turned of Window last year *permanently* after yet another day wasted in Outlook hell. )
Old 05-23-2011, 04:54 PM   #15
Visian
Look out!
Visian's Avatar
Oddometer: 1,519
well, i have a current macbook pro with 8 gig of ram and the beta Basecamp just sits there locked up, so i reloaded the current distribution version.
any other ideas... i am
HTML code is Off
Times are GMT -7.   It's 10:15 PM.
