Old 12-09-2010, 10:59 AM   #1
MORT666 OP
MORT666's Avatar
Oddometer: 214
Cry dead engine
Help required please.Just got out into the garage after 3 weeks of -3c to- 7.5c to have a look at my 950 Adventure which died.Took the bash plate down check the pump points ok no power,check the connector no power o yes fuse ok is there a relay. HELP.
MORT666 is offline   Reply With Quote
Old 12-09-2010, 11:02 AM   #2
kirb
should be out riding
kirb's Avatar
Oddometer: 1,802
Let's start with the easy stuff- Battery? Crank over? Dash light up? Tries to fire at all? Fuses in glovebox OK?
More info please.
A Ducati, some Guzzi, a KTM, and a Excelsior...Indian in resto.
kirb is online now   Reply With Quote
Old 12-09-2010, 11:20 AM   #3
MORT666 OP
MORT666's Avatar
Oddometer: 214
Dash lights / fuse/ battery/ all ok no power at the fuel pump.?
Old 12-09-2010, 11:30 AM   #4
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,401
IIRC I had these symptoms when my starter relay burned out. Two relays are listed as starter relays; it was the main relay down by the engine, not the smaller relay behind the headlight.
The repair manual tells you how to test them.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 12-09-2010, 01:13 PM   #5
MORT666 OP
MORT666's Avatar
Oddometer: 214
Did the starter work though?
Old 12-09-2010, 01:15 PM   #6
MortimerSickle
Semi-Adventurer
Oddometer: 12,401
Not until I changed the relay.
Is yours working?
G.H.W.S. 1878-1962
Old 12-09-2010, 01:18 PM   #7
MortimerSickle
Semi-Adventurer
Oddometer: 12,401
If you are looking for a relay for just the fuel pump, it is also behind the headlight (See pg. 7-7 in the repair manual.)
G.H.W.S. 1878-1962
Old 12-09-2010, 01:54 PM   #8
MORT666 OP
MORT666's Avatar
Oddometer: 214
Thanks i will look behind the headlight,i haven't a manual.
Old 12-09-2010, 02:33 PM   #9
MortimerSickle
Semi-Adventurer
Oddometer: 12,401
This is what you are looking for.
You don't need to take out the headlight, just remove the side cover.
There is another relay just like it right next to it, inboard. That one is the auxiliary starter relay.
Here is how to test it:
From LC8 Manual:
Checking the fuel pump relay
– Dismount the fuel pump relay 3.
NOTE: black/blue, blue/gray, yellow/black and brown cable colors
– Connect the fuel pump relay to a 12 V battery as shown, making sure
you hear the relay switch (nonrecurring "click").
NOTE: the 12 V battery must be connected to the two terminals to
which the blue/gray and brown cable colors are connected when the
plug is connected.
– Use an ohmmeter to measure the continuity between the terminals
A and B.
Reading: max. 1 Ω OK
Reading: ∞ Ω defective
You really should get a manual. It is an invaluable resource.
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 12-09-2010 at 02:41 PM
Old 12-09-2010, 09:57 PM   #10
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,434
Please charge the battery first!
3 weeks is to much.
BMW R1200GSA 2014
Member #68,893
Above all stop pandering to posts from morons like Venteuri who can't even spell Venturi properly.
Venteuri is offline   Reply With Quote
Old 12-09-2010, 10:44 PM   #11
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 847
i think your a bit too quick pronouncing your engine death. here is an example of dead engines
Cheers
Guy
04 KTM ADV 950S GO!!!!!
09 KTM 690 ENDURO R
nomad guy is offline   Reply With Quote
Old 12-10-2010, 11:07 AM   #12
MORT666 OP
MORT666's Avatar
Oddometer: 214
Had a second look at the fuel pump points and yes they are bunt out.
Times are GMT -7.   It's 05:33 PM.
