Old 12-09-2010, 11:06 AM   #1
Bill Harris OP
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,151
Old Airhead instrument lamps
Old-style /5 speedo/tach combo. For the dial illumination (not the warning lights) it uses small hard-to-find bulbs that, of late, are prone to burning out too quickly. Not a big deal to replace, but I have to pull the fairing and wiggle up through all the wiring spaghetti to get to them.
What I'm thinking of doing is "upgrading" these bulbs with white LED lamps. I could use the original bulb holders and incorporate the LEDs (and dropping resistors) into them on a permanent basis. I can look around and get "warm tone" white LEDs that would mimic the color tone of the incandescents.
One thing I never have liked about the stock /5 instrument illumination is that it is not bright enough. I would like to increase the instrument brightness in the process and wonder if anyone has done this LED conversion on a /5 speedo and how it worked out brightness-wise. There are different "brightness levels" available in the LED lamps and knowing what works will cut down on the trail-and-error R&D process.
'73 R60/5 Toaster
Old 12-10-2010, 11:00 AM   #2
dotdash
scarecrow n hometown
dotdash's Avatar
Oddometer: 57
I went here http://www.superbrightleds.com and got some bulbs for my /5.
(on the top menu select car bulbs, BA9s bulbs)
IIRC, all the ones in the bucket are BA7s (on the same page) with the exception of the charge light and the turn signal indicator. I've heard you shouldn't use an LED for the charge light. The BA7s only come in one brightness, just match the color with the indicator's lens color. They're only .89
I swapped mine over- it looks nice in the garage, but I haven't given it a real night ride as it's snowing in Chicago. I don't expect it to be noticeably brighter. The multi-led BA9's have issues fitting in the original bulb holders. They also have a brake/tail light that is a drop-in.
going ninety miles an hour down a dead end street
dotdash is offline   Reply With Quote
Old 12-10-2010, 08:31 PM   #3
fishkens
Further...
Oddometer: 5,149
I'm 99.9% that the OP knows this but yes, you're correct, you can't simply replace the alt/charge lamp with an LED. The lamp (or a resistor) is needed to enable the alternator.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 12-10-2010, 09:46 PM   #4
Bill Harris OP
Oddometer: 8,151
I checked the instrument lamps and they are BA7's (actually I found my stash of BA7 bulbs, a box of about 8).
SuperBright LEDs has drop-in replacements for the BA7 bulbs, and at $1.49 each I can't even think of modifying the sockets myself to accept LEDs. At 6200 mcd brightness they would be pretty darn bright, but as "cool white", they'll have that typical white LED bluish tint. For the price, I'll give them a try.
The spec page for the BA7 lamps is at:
http://www.superbrightleds.com/cgi-b...ecs%2Fba7s.htm
I wouldn't even bother replacing the warning lamps with LEDs-- I can't remember that last time I had one burn out.
'73 R60/5 Toaster
Old 12-11-2010, 07:55 AM   #5
dr650dave
dr650dave's Avatar
Oddometer: 39
Is there a tutorial anywhere to do this?
1978 R100/7
dr650dave is offline   Reply With Quote
Old 12-11-2010, 12:13 PM   #6
Bill Harris OP
Oddometer: 8,151
As an alternative to the BA-7 plug-and-play LED replacement, SuperbrightLEDs has an 8mm dia LED lamp that has a much wider (less directional) viewing angle and an output of some 9000 mcd (half again as much). The BMW lamp socket could be adapted to take the LED lamp.
http://www.superbrightleds.com/cgi-b...-360_specs.htm
'73 R60/5 Toaster
Old 05-05-2014, 09:18 PM   #7
benthic
glutton 4 punishment
benthic's Avatar
Oddometer: 397
Bill, this is a very old thread, but came up in the search I was doing - did you ever make the swap? did the BA-7's improve the /5 speedo illumination?
Spencer
1978 BMW R80/7
"all we need is time and courage." - Renner
"A lightened flywheel on your bike is like me getting into Spandex and putting on track shoes to walk the dog." - M
www.blindfishz.com
benthic is offline   Reply With Quote
Old 05-05-2014, 09:37 PM   #8
Thorazine
Likes exhaust fumes
Thorazine's Avatar
Location: Smoggy Valley, east of Smog City, Southern Calif.
Oddometer: 843
I love thread resurrections like these--sorta like a progress report crossed with Stump the Chumps on Click and Clack. Bill, I'd like to know too. How'd it go?
Bones aren't important; we like motorcycles.-- My boy D @ 4 y/o
* Posts submitted under the moniker Thorazine are for entertainment purposes only, and may include exaggerations, prevarications or bald-faced lies. -- Thorazine - '74 R90/6
Thorazine is offline   Reply With Quote
Old 05-05-2014, 09:59 PM   #9
Bill Harris OP
Oddometer: 8,151
The straight BA7 replacements didn't work well for instrument internal lighting. LEDs are directional so you had a couple of intensely bright spots giving uneven illumination. Those 8mm 360 degree LEDs did the trick. They adapted nicely to the BMW bulb holder and provides uber-bright even illumination. It's a novel concept-- it consists of a central LED with UV output surrounded by a phosphor that emits light when excited by the UV. Think of it as a solid-state fluorescent lamp.
Let me pull together some photos of the project...
--Bill
'73 R60/5 Toaster
Old 05-06-2014, 05:45 AM   #10
Screaming Chicken
Screaming Chicken's Avatar
Oddometer: 596
Not a /5 so slightly offtopic, but this is what happened after I stuck a LED ba9s in my GS. The difference is quite pronounced, I'd say:
Didn't do them both at once because the other (cheap, chinese) LED was a dud, even after changing the polarity.
'92 R100GSPD
Two Bings to rule them all, Two Bings to ride them,
Two Bings to bring it all and in the twisties grind them.
In the land of Bavaria, where the boxers ride...
(Gandalf the oil-stained)
Screaming Chicken is offline   Reply With Quote
Old 05-06-2014, 06:21 AM   #11
Bill Harris OP
Oddometer: 8,151
That is quite pronounced. OTOH, on my /5, it was a meh.
I guess "check yours and see" is the moral.
--Bill
'73 R60/5 Toaster
Old 04-13-2015, 02:14 PM   #12
Aircoolio
Aircoolio's Avatar
Oddometer: 9
--Bill
This sounds great! If you don't mind my asking, how does one adapt them in? Is a resistor required?
Edit:
Nevermind, answered my own question by finding it in another thread:
http://www.advrider.com/forums/showp...4&postcount=16
Aircoolio screwed with this post 04-13-2015 at 02:39 PM
Aircoolio is offline   Reply With Quote
Times are GMT -7.   It's 09:47 PM.
