Old 12-21-2010, 05:28 AM   #16
jwolf OP
Wolfie
jwolf's Avatar
Location: Vincennes, IN 75 miles Southeast of Moonshine
Oddometer: 408
Originally Posted by jwolf View Post
Lets try again they say they have fixed it.
it worked...
Wolfie
OD green Victorinox KLR 650
Jwolf@vinu.edu
Http://159.218.3.3
Vincennes IN
jwolf is offline   Reply With Quote
Old 12-21-2010, 11:14 AM   #17
motorat
TBD
motorat's Avatar
Oddometer: 927
what jetting and how many turns out?
to ignore the facts does not change the facts
motorat is offline   Reply With Quote
Old 12-21-2010, 02:34 PM   #18
jwolf OP
Wolfie
jwolf's Avatar
Oddometer: 408
I have stock jetting but I have done the carb mod including drilling the slide, shimming the needle and drilling out the EPA plug, and setting the low idle needle to 1.75 turns out.
It is not back firing at all so I don't think it is too lean.
Wolfie
Jwolf@vinu.edu
Http://159.218.3.3
Vincennes IN
Old 03-20-2011, 05:10 AM   #19
Moezilla
Velocity Joint
Moezilla's Avatar
Oddometer: 189
Don't know how long the packing last haven't had it that long.
Last one I had I packed with the stainless steel pack and never replaced it again as long as i owned the bike.
Now that you've had it installed a while, would you care to report back if you're still happy with the Lexx, how it's holding up, etc.
________________________________________________
You own a KLR and a BMW? You must really be a tight-ass...
Mechanic at the BMW dealer
Moezilla is online now   Reply With Quote
Old 03-20-2011, 06:05 AM   #20
XDragRacer
Oddometer: 3,184
And after all, loud pipes DO save lives!
Please, no explanation/justification/refutation; I jest! Enjoy your sonorous, melifulous exhaust note in good health.
The stock Briggs & Stratton-reminiscent sound's o.k. with me; glad you found what you like.
XDragRacer is offline   Reply With Quote
Old 03-21-2011, 05:05 AM   #21
jwolf OP
Wolfie
jwolf's Avatar
Oddometer: 408
No problems yet, but, it's been winter, and most trip have been short trips to work and back.
Wolfie
Jwolf@vinu.edu
Http://159.218.3.3
Vincennes IN
Old 12-10-2011, 04:33 PM   #22
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Oldish thread, I know, but you definately can hit the lexx with the brake caliper on a KLR. Punched a real nice hole in mine with the bleeder screw. Dont have any pictures handy, have to get one later.
KG6BWS is offline   Reply With Quote
Old 12-10-2011, 06:07 PM   #23
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,959
This is the first I've heard of this exhaust, so I'm interested in hearing more...
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 12-10-2011, 06:47 PM   #24
KG6BWS
KG6BWS's Avatar
Oddometer: 895
I really like it. Sounds good, without being obnoxiously loud. Done a number of long rides without it bothering me in the least. Fairly light, although I dont recall the weight. Looks pretty good too.
Taking it to a buddies house next week. Get the hole in the bottom patched and repack it. Didnt have my rear shock setup right and bottomed it real hard. Punched a hole in it with the bleeder screw on the caliper. Surprisingly enough, the bleeder screw was just fine.
Where i bought mine:
http://www.rockymountainatvmc.com/pr...FamilyId=19536
Old 12-10-2011, 06:48 PM   #25
willys
willys's Avatar
Oddometer: 2,904
I have 2 coming in the spring. One for my bike and other for a buddies. I finally broke down and decided to try a slip-on to see if there was any difference between my low buck modded can and it. Besides weight. I have heard them and they are very close to the modded low buck can, so not too loud. This is the first I have heard about them getting hit by the brake caliper. What did it take to get it to hit the claiper?
willys is offline   Reply With Quote
Old 12-10-2011, 07:15 PM   #26
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Not taking the time to properly set my preload.
Of course playin in the desert while it was loaded for a trip didnt help matters eaither.
Think Ive got the spring set up now. Once i get it fixed, gonna play around and see if it happens again.
Old 12-10-2011, 08:56 PM   #27
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,959
...What did it take to get it to hit the caliper?
Probably something like this:
-DustyRags
Old 12-10-2011, 09:53 PM   #28
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Load it like this...
Then do this...
And that is you how punch hole in the muffler.
Old 12-11-2011, 07:30 AM   #29
willys
willys's Avatar
Oddometer: 2,904
OK, so I only do one of those silly things, so mine should be good to go.....lol
Nope no jumping for me......not intentionally any way.
Old 12-12-2011, 04:20 AM   #30
willys
willys's Avatar
Oddometer: 2,904
Just a thought? Does the LEXX can use the same type of gasket at the midway joint to seal the two sections as the stocker? OR do they have their own gasket?
Times are GMT -7.   It's 07:52 AM.
