Old 11-04-2013, 07:28 PM   #2161
jdrocks OP
Gravel Runner
Oddometer: 4,583
next up was to clean up the sprocket carrier, and mount a new sprocket. i'm using an SV650 rear wheel, and the SV uses a 525 chain while the Versys/ER6 uses a 520. 520 sprockets are readily available for the SV carrier, and i stayed with the stock gearing...46 tooth.
Driven racing steel sprocket.
OEM 45 tooth 525 sprocket on left, new 520 sprocket mounted on carrier right.
jdrocks is offline   Reply With Quote
Old 11-04-2013, 07:37 PM   #2162
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,795
Originally Posted by jdrocks View Post
yeah, that medium-fast sport touring crowd.
Fixed it for you.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 11-04-2013, 07:39 PM   #2163
jdrocks OP
Gravel Runner
Oddometer: 4,583
cleaned up the SV wheel, bearings felt a little rough, better change them, except the new SV bearings turned out to be for some other wheel. i'll do it later, at least the wheel was straight and cheap.
rotor side, i be stylin' now.
sprocket side, man, that lightened sprocket should be worth 5 mph.
Old 11-04-2013, 08:04 PM   #2164
jdrocks OP
Gravel Runner
Oddometer: 4,583
i had a new Full Bore rear, that will get mounted for now.
Old 11-04-2013, 08:08 PM   #2165
jdrocks OP
Gravel Runner
Oddometer: 4,583
Originally Posted by MTrider16 View Post
Fixed it for you.
David
as long as you're only medium, ya can catch up to me at the next fuel stop.
i did put a tape on the bar end, lower than i thought, only 54" off the floor.
Old 11-04-2013, 08:15 PM   #2166
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,795
This is a step up from the "slower than snails routine".
Old 11-05-2013, 08:39 AM   #2167
fasteddiecopeman
Oddometer: 120
Father Edward, if i rode it with that strut, plan on saying a prayer for me, i'd break something in less than a km.
Dave - SOMEHOW, I would NOT consider you a "Hardly" rider, especially not a hard-tailer....
fasteddiecopeman is offline   Reply With Quote
Old 11-05-2013, 02:50 PM   #2168
jdrocks OP
Gravel Runner
Oddometer: 4,583
that's right around the corner if ya slow down any more.
Old 11-05-2013, 02:52 PM   #2169
jdrocks OP
Gravel Runner
Oddometer: 4,583
hey, ya crazy Canuck, the only word ya got right in that statement was hardly.
Old 11-05-2013, 03:07 PM   #2170
jdrocks OP
Gravel Runner
Oddometer: 4,583
another comment on front wheel spacers...
the DL1000 wheel uses a 20mm axle, so obviously the spacers have a 20mm ID.
OEM DL1000 front wheel spacer right, ER6 rear wheel spacer left.
the DL spacer is 27mm OA length, 28mm diameter on the barrel, while the ER6 spacer is 17mm in length, and also has a 28mm diameter barrel. while i recommend a pair of DL spacers, there are obviously some other possibilities if you have some 20x28x? spacers in the parts bin.
Old 11-05-2013, 03:46 PM   #2171
jdrocks OP
Gravel Runner
Oddometer: 4,583
the 2009-11 ER6 pull style adjusters, end caps, and side plates are specific to the swingarm and do not fit the earlier 2006-08 ER6 swingarm. all pieces are left/right only, and it's a very nice setup overall. the late model ER6 axle is 345mm, while the earlier version is 320mm, so the axles are not interchangeable either.
Old 11-05-2013, 06:15 PM   #2172
jdrocks OP
Gravel Runner
Oddometer: 4,583
rear Full Bore mounted on the SV wheel, then onto the bike. if considering an SV rear, remember to buy a late model wheel that uses a 20mm axle, the first gen SV rear used a 17mm.
Old 11-05-2013, 06:27 PM   #2173
jdrocks OP
Gravel Runner
Oddometer: 4,583
every scooter needs a scooter motor, and this time around my parts bike had the all black cop motor, man, that's sweet. i wouldn't have turned away from a parts bike without it if the price was right, but i worked a little harder to make a deal for the black one. by the time the dust settled, the 2300 mile motor was free.
now i have to get it all cleaned up for the install.
Old 11-06-2013, 09:44 AM   #2174
jdrocks OP
Gravel Runner
Oddometer: 4,583
the last time i dropped the cop motor in the Versys frame i had a helper, so i just used a common automotive floor jack. no helper this time, so i used a moto lift, and it's the better way to do the job anyway. motor slides right in, jack it up, slide the bolt into the upper rear motor mount, and you're good, motor can't fall out. it helps to have a pair of drift pins to get things lined up.
Old 11-06-2013, 02:54 PM   #2175
L.B.S.
Oddometer: 1,468
Darth Versydious model?
L.B.S. is offline   Reply With Quote
Times are GMT -7.   It's 03:14 PM.
