Old 10-30-2011, 07:50 PM   #1171
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by ben2go View Post
Cool mod.I use all thread and jam nuts to make my side stands adjustable...
that method does not work well with these long extensions, too much weight out on the end, the OEM spring has a tough time holding it in the retracted position.
jdrocks is online now   Reply With Quote
Old 10-31-2011, 05:16 PM   #1172
jdrocks OP
Gravel Runner
Oddometer: 4,582
joints welded and smoothed, prime and paint.
Old 11-01-2011, 07:01 AM   #1173
pjm204
Oddometer: 2,019
That is one purty sidestand
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 11-01-2011, 07:33 AM   #1174
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,845
Looks factory original.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 11-01-2011, 07:43 AM   #1175
jdrocks OP
Gravel Runner
Oddometer: 4,582
thanks, you better find one, you're going to need it.
Old 11-01-2011, 07:45 AM   #1176
jdrocks OP
Gravel Runner
Oddometer: 4,582
almost. if you take the trouble to smooth the welded joints, the extension isn't quite so noticeable.
Old 11-01-2011, 10:24 AM   #1177
jdrocks OP
Gravel Runner
Oddometer: 4,582
there's a story here. as a matter of fact, more than one.
Old 11-01-2011, 11:50 AM   #1178
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,845
Ok.Lets hear it or them.
Old 11-01-2011, 02:09 PM   #1179
jdrocks OP
Gravel Runner
Oddometer: 4,582
eventually...
it starts like this "Once upon a time..."
Old 11-01-2011, 02:29 PM   #1180
jdrocks OP
Gravel Runner
Oddometer: 4,582
new KLR side stand mounted on the rat...
a couple of additional notes-
if you get the KLR sidestand, get the KLR spring also. the KLR spring is shorter than the Versys/ER6 spring and does a good job holding this longer side stand in the up position.
i always ziptie the side stand spring to the side stand so it can't be lost if something hits or snags it.
remember, when removing or installing the side stand, don't try to remove or install the spring by itself. instead, remove or install the stand and spring at the same time. save yourself some aggravation, you won't mess up the spring either.
for reference, the KLR side stand for this bike was extended 85mm. you still need to check your own setup.
Old 11-01-2011, 07:34 PM   #1181
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,845
eventually...
Old 11-01-2011, 09:02 PM   #1182
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,795
Cool as story about master links. We're waiting...
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 11-02-2011, 07:09 AM   #1183
pjm204
Oddometer: 2,019
That's the truth. My KTM 640 wheel arrived yesterday, or so I heard. My brother called and said "your cannon all-in-one printer arrived" Since I didn't order a cannon printer, I can only assume it is the last piece of my bike puzzle. Sadly it snowed this weekend, causing my power to be lost and me to not really be able to work on the ninja build. I changed the tires on the vstrom which was more important since I needed to ride it 70 miles the next day.
Old 11-02-2011, 11:11 AM   #1184
jdrocks OP
Gravel Runner
Oddometer: 4,582
Originally Posted by MTrider16 View Post
...story about master links...
you're a smart guy, i'm sure you can see the story line.
Old 11-02-2011, 11:51 AM   #1185
pjm204
Oddometer: 2,019
I'm guessing that is a clip type, clip fell off, chain snapped and broken some stuff? Good guess?
Times are GMT -7.   It's 05:02 PM.
