Old 12-15-2010, 07:54 PM   #1
Ben Carufel OP
Boxer Addict
Ben Carufel's Avatar
Oddometer: 699
Airhead Guys: IN/LB Torque Wrench, or FT/LB?
I have a Craftsman FT/LB 1/2" drive torque wrench that's probably 8 years old or so. I might as well get it calibrated, but in any event it only goes down to 20 FT/LB.
This has been fine for all of my car tinkering over the years (I subscribe to the idea of "Use torque appropriate to the size of the fastener", as well as the idea of using a 1/4" ratchet where appropriate so as not to over-torque the small stuff), but since I'm likely on the verge of tearing my R65 completely apart I thought I might start with a new smaller-drive torque wrench.
So, in your opinion, would it be better to get an IN/LB model or a FT/LB model that goes down to, say, 5 FT/LB?
And further, 1/4" or 3/8" drive?
Ben Carufel
'02 BMW R1150GSA - '72 BMW R60/5
Recovering BMW Addict...
Ben Carufel is offline   Reply With Quote
Old 12-15-2010, 08:32 PM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,625
Why not get a 3/8" with in-lb.. you'll be all versatile n' stuff!
BTW, I have both of both (and Nm) and none in 1/4".
crazydrummerdude is offline   Reply With Quote
Old 12-15-2010, 08:41 PM   #3
Harry Backer
Ran when parked!
Harry Backer's Avatar
Oddometer: 373
I have the 3/8 craftsman and the 1/4 in inch pounds but dont use the 1/4 much at all.
Motorcycle = Mind eraser
78 R100/7 / 70 CL350 / 71 CB350
94 Duc 900ss / 63 Suzuki 80 K10
Harry Backer is offline   Reply With Quote
Old 12-15-2010, 08:56 PM   #4
fishkens
Further...
Oddometer: 5,148
3/8" Craftsman clicker is my only torque wrench. Covers my airhead needs perfectly well.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 12-15-2010, 10:15 PM   #5
Country Doc
Wanderer
Oddometer: 2,732
There are a few places on an airhead where a small-drive in-lb torque wrench is useful. Necessary? Probably not. But nice to have.
Oil sump bolts, advance mechanism nut, etc. come to mind. There are others that I can't remember at present.
If you start working on anything more modern, you'll find more and more need for an in-lb torque wrench, as lots of fasteners on modern bikes in my experience are torqued to less than 10 ft-lbs, which is hard for any ft-lb wrench to nail accurately.
dc
Country Doc is offline   Reply With Quote
Old 12-15-2010, 10:18 PM   #6
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,972
I ride an Oilhead, but I have 2 different sizes of 3/8" drive Craftsman torque wrenches that cover everything I need.
Support the AMA.
Waco is offline   Reply With Quote
Old 12-16-2010, 06:34 AM   #7
Jasper ST4
Guest
Oddometer: n/a
What's wrong with a "good grunt" "half a grunt" or a "quarter grunt"?
Seriously though, I only use mine on the jugs and swingarm. So far I've been lucky on everything else.
Old 12-16-2010, 07:28 AM   #8
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
click type torque wrenches are only accurate from 15 or 20% from teh bottom of their lower range to the top.
i.e., a 0 - 100 Ft-Lb tool is only accurate above 15 or 20 Ft-lb.
This is due to the nature of the internal spring and pawl (i think that's what it's called) mechanism.
Beams are accurate as they're based on stress over a given length of a solid beam of material, but you have to know how to use them well and have a steady hand.
whatever torque you're after, get a tool with an acceptable range for it.
datchew is offline   Reply With Quote
Old 12-16-2010, 08:44 AM   #9
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Because most don't have the "feel" for that.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 12-16-2010, 08:54 AM   #10
melville
melville's Avatar
Oddometer: 1,459
Same here. One is 10-75 ft-lbs, one is ??-300 in-lbs. Everything on the motor and most of the chassis is handled by these two, VW or BMW. My 1/2" drive torque wrench is for big chassis stuff like lug nuts, fork top nuts, and swingarm pivot locknuts.
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Old 12-16-2010, 10:15 AM   #11
mykill
odd
mykill's Avatar
Oddometer: 1,166
Both!
You can never have enough tools. 1/2 for big stuff and 3/8 inch lbs for smaller stuff. Always best to use the tools in the middle of the useable range rather than either extreme. Some are lucky enough to have a calibrated wrist, mine varies with mood. I have no interest in doing an airhead oil pan without a torque wrench.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 12-16-2010, 05:08 PM   #12
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,782
I'm sure some will disagree, but I am a strong proponent for using torque wrenches for rod caps, main bolts, cylinder heads, ETC. however, I pretty much never use them on small bolts. This seems counter intuitive, but try torquing clutch spring bolts on a Japanese bike with a torque wrench (calibrated or not) to the factory spec. I guarantee you will break at least one. or try a Chevy oil pan gasket, before it clicks you will split the gasket! I find "slightly" better results using a beam/pointer type wrench, on small stuff, but still....
BTW, I have worked most of my life a a mechanic of one sort or another, Motorcycle, Automotive, Bicycle, engine builder (thousands), so I'm not a total noob!
I'm also really into road bicycles, and started buying a lot of carbon fiber parts. To preserve these expensive parts from damage of over torquing, I bought a new very expensive in. lb. torque wrench. I don't know why, but some things just don't seem able to be properly torqued?!? I could hear the carbon parts making crunching sounds, and they were visibly damaged, before even getting close to the torque spec. I'm talking $300 handlebars here! There are some things I simply will not use a torque wrench on. IMHO
Old 12-16-2010, 05:30 PM   #13
Jasper ST4
Guest
Oddometer: n/a
That's it in a nutshell. Wrenching is an artform that requires some intuition and feel.
Old 12-16-2010, 06:52 PM   #14
The Raven
The Raven's Avatar
Oddometer: 4,811
I have a Craftsman Ft-lb clicker and a SnapOn NM Torque-o-Meter. I only had one set of driveshaft bolts come loose and they were tightened using a Harbor Freight POS and I have a chunk out of my transmission case output because if it
The Raven is offline   Reply With Quote
Old 12-17-2010, 12:27 AM   #15
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Interesting. In the 25 years I've been wrenching on BMW bikes, I have never used a torque wrench on the driveshaft bolts.
Just new stretch bolts and loctite (alcohol to clean the flange threads of oil) and a 10" long SnapOn box wrench.
Never lost a driveshaft.
I use a torque in most other places, having 4 different ones that will cover from 1 inch pound to 250 foot pounds.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Times are GMT -7.   It's 05:21 PM.
