Old 12-15-2010, 08:10 PM   #1
Cyclops Motorsports OP
Cyclops Motorsports's Avatar
Oddometer: 946
BMW Accelerator modules
The Team here at Cyclops is happy to announce that we are the US distributor for the Sol2 BMW Accelerator module
https://www.cyclopsadventuresports.c...tegories&id=98
Dont forget your discount code ADV
Available for all BMW twins from the 650 to the 1200
This is no snake oil device... research the threads in the equipment section here on ADV rider.
Some advantages are
smoother quicker, throttle response
The famous boxer surge should dissipate
Smoother cruising and a generally better running motor.
Some report better fuel mileage
Inexpensive tuning tool
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is offline   Reply With Quote
Old 12-16-2010, 06:21 AM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,987
how well does it fix the snatchy throttle?
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 12-16-2010, 08:00 AM   #3
Oddometer: 946
From what I understand, it will make the low speed transition much more smooth, Many have purchased to help smooth out the off idle throttle response while off roading.
I hope that is what you are referring to??
Old 12-16-2010, 11:00 AM   #4
Motorfiets
Motorfiets's Avatar
Oddometer: 2,987
ok I'll bite... how much?
Ben
My Photo's
Old 12-16-2010, 11:45 AM   #5
GeckoRider
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 413
Aim your browser to his website and your question will be answered.
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, throttle Rocker, Airhawk seatpad, Pivot Pegs, Renthal grips, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
Wishing for farkles; If/when I can ride offroad better- suspension, rims.
GeckoRider is offline   Reply With Quote
Old 12-16-2010, 01:16 PM   #6
Oddometer: 946
Thanks Gecko..
They retail for 114.95 you save 12% On any Cyclops product by using the "ADV" code
Old 12-16-2010, 07:07 PM   #7
1P8RIOT
1P8RIOT's Avatar
Oddometer: 330
Will you be at the Long Beach Mororcycle Show this weekend(12/18/10)?
A ship in a port is safe but that is not what ships are built for. - Mom
I DIDN'T BUILD IT TO DECORATE THE GARAGE. - me
'84 Harley FXR 250,000 miles and counting.
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Old 12-17-2010, 09:03 AM   #8
Oddometer: 946
Im afraid we wont.. We did the INT MC shows years ago, but as a mostly off road based company,we found it did not work so great for us.
As we venture more into the ADV bike market that may change.
Old 12-18-2010, 04:41 PM   #9
1P8RIOT
1P8RIOT's Avatar
Oddometer: 330
No problem, I'll just go to your website
Old 01-03-2011, 09:26 AM   #10
Oddometer: 946
Thanks guys for all the input and orders for the Accelerator.
please continue to provide your feed back.
Old 01-17-2011, 02:15 PM   #11
Motorfiets
Motorfiets's Avatar
Oddometer: 2,987
how does this compare with the booster plug?
Ben
My Photo's
Old 01-17-2011, 07:30 PM   #12
SCflyer
SCflyer's Avatar
Oddometer: 1,322
Long term question... (To other inmates...I'm not knocking the product! especially since I've not used one...so no ok) Just asking.
I have read all the reviews and more postitive than not for a relatively inexpensive mod that seems to work. I also understand it gives an alternate temp reading to get the desired result so this may not be all true...but I asked a BMW tech about this and he said yes it should work except over time the computer will learn that something isn't quite right as original and compensate so it will end up negating the booster intent. Maybe singing the bavarian party line since we were at the dealership but seemed straight up.
Anyone have any longterm usage input?
And C Motorsports... were I to get one do you only have the longer version or can you get the shorter one?
Thanks and continued luck with the sales.
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 01-18-2011, 09:12 AM   #13
Oddometer: 946
I have read all the reviews and more positive than not for a relatively inexpensive mod that seems to work. I also understand it gives an alternate temp reading to get the desired result so this may not be all true...but I asked a BMW tech about this and he said yes it should work except over time the computer will learn that something isn't quite right as original and compensate so it will end up negating the booster intent. Maybe singing the bavarian party line since we were at the dealership but seemed straight up.
I cant really speak much about the computer learning that the device is in the system, Ill ask some of the riders that have had the device installed for some time. I cant really see that happening, but???
Our SA conterpart has done considerable testing on both the long and short models, He has come to the conclusion that the longer version works best in all conditions.
The Long version is all we import to the US.
Old 01-18-2011, 10:00 AM   #14
Schlowy
Oddometer: 6
Good day to you all , my name is Schlowy of "Schlowy Custom Motorcycles "
we are the Distributer in South Africa ,to answer the issue above,
the engine management receive the Temp input from the sensor in the air box
this input is then change the amount of fuel send to the engine ,our device simply make the reading "wrong" or "false" by make the air Temp to "appear " colder, as a result the amount of fuel send at any given time of this reading is increase ,the engine management do not have the "tools" or the "intelligence" to "get used" to this input since if it is correct then the original input could be affected as well...
as for the short or long version - according to our and independent testing (bike magazines and other Motorcycle mechanics ) we find out that the longer version work and respond better (5- 7 hp in low and mid range) and 6 - 13% better fuel economy
hope I clarify the above
Schlowy is offline   Reply With Quote
Old 01-18-2011, 12:19 PM   #15
SCflyer
SCflyer's Avatar
Oddometer: 1,322
CM and Shlowy - Thanks for the responses. Always nice to have an actual manufacturer of the product chime in.
Times are GMT -7.   It's 11:18 AM.
