Old 12-19-2010, 01:44 PM   #16
fishkens
Further...
Oddometer: 5,147
Originally Posted by Jacubird View Post
Has anyone thought about (or done) the conversion to the oilhead type paralevel setup? It seems to me a fairly simple process. The only difficult parts would be adapting that style driveshaft to the airhead tranny, plus adapting to the later style rear disk brake setup.
This looks like an oilhead paralever on an airhead...
http://www.roemerteam.de/inhalte/bmw/bmw.html
"Suspension optimization"
http://www.roemerteam.de/inhalte/bmw/bmw_tuning.html
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 12-20-2010, 04:55 PM   #17
Jacubird OP
Oddometer: 33
It looks like the original R100GS rear end, too
Maybe this is the solution to the driveshaft problem. Anyone tried it?
Jacubird is offline   Reply With Quote
Old 12-21-2010, 09:18 AM   #18
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
it's not a straight bolt on. see ricky's thread.
http://www.advrider.com/forums/showthread.php?t=204897
bmwblake is offline   Reply With Quote
Old 12-21-2010, 03:03 PM   #19
fishkens
Further...
Oddometer: 5,147
Wow. Wow. Wow.
That thread and the embedded thread on the Golem ReBirth are terrific. Fascinating people working on interesting projects and telling great stories about 'em. Although the lack of denouement is sadly disappointing.
And no, that doesn't look like a bolt-on at all.
Old 05-24-2011, 09:03 AM   #20
jackd
Oddometer: 3,037
Any update on these Beemershop driveshafts?
Old 05-24-2011, 03:44 PM   #21
jackd
Oddometer: 3,037
I went out and bought one anyway.
jackd screwed with this post 05-24-2011 at 07:22 PM
Old 05-26-2011, 10:25 PM   #22
darklight79
scaffold builder
Oddometer: 418
Talked with ted porter guys a month or so ago .. had the unit in stock on the shelf ... hmm country of origin taiwan fyi .. I know think global ....They do warranty the thing for a bit 600 dollars ... still rolling quarters ..oh and by the way is an ace socket 1 1/16 inch the same as a quality 27 mm ?
darklight79 is offline   Reply With Quote
Old 08-19-2011, 09:50 AM   #23
gildo
Oddometer: 3
Originally Posted by Rob Farmer View Post
There's a fully rebuildable option available for less than the price of a new standard one.
http://www.bmwboxersupplies.com/prod...roducts_id/336
I have been eyeing this from Motorworks ( 396) for a little while as I've had to replace the original bearings twice and have only 87000 mls on the bike. At the moment I have a little play on the rear UJ and am not using the bike as the first time the bearings went they took out the shaft drive and the shaft casing in no time before I realised... (very expensive!) and I learnt the lesson. Admittedly, the second set got worn after only about 15000 mls but also a year of bike work on very rough african terrain.
Obviously, the prospect of re-greasing every 5000 mls (or is it km?) is not appealing so i am also considering a rebuilt original one (at 240 from Motorworks)
Question: Does anybody know if
1 - play in the rear bevel could lead to premature wear/damage on the UJ bearings (I assume it will create some knocking..)
2 - out of phase segments of the shaft due to the rubber being strained with time has the same effect of causing premature wear in the bearings
...if so, I guess I'll go for the rebuildable one as an original might again only last me a short time since the rubber is not usually replaced I think (??)
thanks,
g
gildo is offline   Reply With Quote
Old 08-19-2011, 06:35 PM   #24
brittrunyon
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 493
I installed a shaft from Ted Porter
http://www.beemershop.com/catalog/pr...52eb087aa94fdd so far so good.........
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon is offline   Reply With Quote
Old 08-19-2011, 07:38 PM   #25
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,001
My '92 R100GSPD is down for a frame-up overhaul at the moment. Converting the swingarm and final drive to 1150GS equipment is part of the planned modifications.
Just sourced an 1150 driveshaft over the weekend, so the only part still missing is an adapter to fit the oilhead driveshaft to the airhead transmission output flange. Well, that and fabricating a suitable rear shock mounting point...
HPN sells an adapter but it's quite expensive. I might try fabricating my own using parts from an old driveshaft and an 1150 oilhead transmission output shaft. Or find someone who can machine a suitably splined stub shaft.
I suspect Bruno would be able to handle that machining chore.
Old 08-19-2011, 08:23 PM   #26
jackd
Oddometer: 3,037
The re-buildable shaft that I purchased a few months ago, as mentioned above, is providing good service. I'm glad I went that route instead of re-building my original unit.
Old 09-17-2013, 11:11 AM   #27
globalt38
Swimmin W/Waterwings
globalt38's Avatar
Oddometer: 693
Curious
It's been 2 years - how's it doing/holding up? Are they still available? (the BMWBoxersupplies link shows it as NA (or at least disapeared from their site at this time).
'94 R100GSPD
You can have my Airhead when you pry it from my cold dead fingers!
I only subscribe to the Girl on an old motorcycle: Post your pics! thread for the comments!
globalt38 is offline   Reply With Quote
Old 09-17-2013, 12:48 PM   #28
Rhinorear
Member Team Tarded
Rhinorear's Avatar
Oddometer: 256
Glad to see someone else found the same thing missing on the site. I was just wondering if it was just me.
I figure I'm on borrowed time in that I've got nearly 130,000 miles on the original........yes the original drive line.
Match that....huh....huh! Anybody......Anybody!
Protect Your Right to Arm Bears
'09 Husky SM610
'08 Buell 1125R
'06 KTM 525 EXC EL TRACTOR
'94 BMW R100GS PD
'80 CT110
'72 GT380
Yamaha R1 350
ET AL
RIFF RAffer
l
Rhinorear is offline   Reply With Quote
Old 09-17-2013, 01:07 PM   #29
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,234
Version 2 has now just been released with uprated (German) U joints. Bulldust in Aussie has some
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 09-17-2013, 01:12 PM   #30
darklight79
scaffold builder
Oddometer: 418
Jeez
I ll never have piece of mind now in addition to my non clip trans. Which runs fine I can worry whether my u joints r substandard. My replacement running 12 miles aok. Time for a 1150
Times are GMT -7.   It's 04:18 PM.
