Old 12-22-2010, 07:00 PM   #1
Skowinski OP
Deuterostome
Skowinski's Avatar
Location: Wandering In The Desert But Receiving No Wisdom
Oddometer: 5,429
Happy Trails PD Crash Bars KLR650 Mounting Problem?
Just got a set of new Happy Trails Paris-Dakar nerf bars, and ran into a problem when mounting them. The left side upper mount does not even come close to lining up with the hole through the frame. Even with pushing and pulling everything as far as it will go it's still a good 4-5 mm off. Did I get an odd set of these, or is this a common problem?
Looks like even if I hillbilly things upwards by filing, grinding, etc, the upper part of the mount will interfere with the protective housing that the cables run through above it in this picture. And, once you get them installed, do you have to remove the left one to get the radiator cap off??
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 12-22-2010, 08:24 PM   #2
250senuf
250senuf's Avatar
Oddometer: 2,319
Talk to Happy Trails before you start cutting or grinding anything, you'll make them non-returnable.
250senuf is offline   Reply With Quote
Old 03-23-2011, 01:37 PM   #3
mmitchell57
Vulcan Halfbreed
mmitchell57's Avatar
Oddometer: 2,193
What did you do to resolve the issue? I've run into the same thing. I haven't gone through and loosen everything up a whole bunch yet, but I supposed it'll be something to that extent. I'll report back if I don't hear back by the time I find an answer.
Projects - www.Goomra.com
1969 CB350 - Restoration Project
1962 Ford Fairlane 500 - Restoration / DD project
mmitchell57 is offline   Reply With Quote
Old 03-23-2011, 06:56 PM   #4
OFA
Adventure Obsession
OFA's Avatar
Oddometer: 118
Mine where installed when I bought the bike
Mine were installed by the previous owner and when I looked closely,( after the grin wore off and I actually started looking at the bike). Anyway, they are installed with two holes. they must have drilled another if there is a factory one there. One if the bolts goes right through the frame serial number tag. Weird.
Just want to ride.
OFA is offline   Reply With Quote
Old 03-23-2011, 07:11 PM   #5
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
You are right. There is a hole on both sides. On the brake side of the bike there is a hole underneath the VIN sticker that you can poke open with a screw driver. There is a hole on the drive side of the bike that's in open view. You can't see it in the picture above so it can be a bit misleading. I've started a post over here to document that escapades. I've included an upgraded diagram of the OP's picture. I went ahead and emailed HT about the fitment issue. I hope to hear back sometime tomorrow.
Old 03-23-2011, 07:15 PM   #6
Mw650
Bob
Mw650's Avatar
Oddometer: 1,854
Dont bother calling them, they'll tell ya that their jigs for makeing them are fine. Trust me I called several years ago when I had the exact same problem. Pissed me off to where I will never get anything from them again.
But as to mounting that side you got two choices, first would be mount the upper part first them use your foot to puch down and put the bolt thru the the bottom mount. Choice two....put it in a vice and bend it till it lines up but that will probably crack the powder coat. I did the second after my bars started rusting a little.
Third choice would be to sell them to someone and get the sw motech bars.
KLR - Kills Little Rodents
Mw650 screwed with this post 03-23-2011 at 08:51 PM
Mw650 is offline   Reply With Quote
Old 03-23-2011, 08:08 PM   #7
El Brad
Leave it long on top
El Brad's Avatar
Oddometer: 446
Bluhduh Typical of Happy Trails stuff.
Every Happy Trails item that I have bought I have had to cut, grind, bend,
drill, modify in some way to make fit. Have had fit problems with crash bars and pannier racks. The last set of pannier racks that I bought for my wifes new Super Sherpa fit terrible and took alot of tweaking to get to fit.
Not just fit problems but stuff welded out of square and looked bad once installed. I just keep buying there stuff becouse of price and I have the tools and ability to make them fit. So, to answer your question you will just have to bend them around a bit and enlarge or redrill holes to make fit, maybe get some longer bolts to help pull things into place as you tighten.
" THE TRUTH IS, IF WE HADN'T DECIDED
TO BE YOUNG FOREVER, WE'D BE OLD "
El Brad is offline   Reply With Quote
Old 03-23-2011, 08:15 PM   #8
guns_equal_freedom
Oddometer: 5,517
Junk.
When you crash the forces will be transmitted to that thin head brace gusset and it will bend.
Buy the Acerbis tank, that's the best set of crash bars you can buy.
guns_equal_freedom is offline   Reply With Quote
Old 03-23-2011, 08:46 PM   #9
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
Huh.... Not exactly what I was wanting to hear. Well, I'll hopefully have a positive response from HT tomorrow. If not I may have to get freaky with the nerf bars.
Old 03-23-2011, 08:46 PM   #10
mmitchell57
Vulcan Halfbreed
Oddometer: 2,193
Originally Posted by guns_equal_freedom View Post
Junk.
Well, if the nerf bars go to shit, i'll probably go that route.
Old 12-17-2012, 05:48 PM   #11
SouprrDave
SouprrDave's Avatar
Oddometer: 29
I just picked up the nerf bar and skid plate combo deal that HT was running before Thanksgiving that included free shipping in the continental US for my 1997 KLR 650 and everything fit perfectly. Fortunately for me, it looks like they fixed whatever problem you all have experienced.
I just looked at their website and it looks like they extended the sale to the end of the year.
And no, I don't work for HT and I'm not being compensated by HT.
"And in the end, it's not the years in your life that count. It's the life in your years."
'04 BMW R1150RT, '04 HD XL1200C (for sale), '97 Kaw KLR650, '74 Suzuki GT185 (for sale)
SouprrDave is offline   Reply With Quote
Times are GMT -7.   It's 12:40 AM.
