Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 06-25-2013, 06:25 AM   #5356
sevenpointsixtwo
Newb Extraordinaire
sevenpointsixtwo's Avatar
Oddometer: 199
Originally Posted by ArchRider View Post
How did you prep the plastic? Did you sand it all the way down? I have the same bubbling problem with my Girlie (I think we all do) and I was thinking about painting her. But I'd have to get the decals off which would probably leave an indentation in the paint and then I'd have to sand anyway.
I'd also have to figure out how to get Rustoleum to mix up some Roulette Green
On the tank, I did sand it all the way down. The bubbling was so bad that I could just peel the graphics off and then sand down to the white primer layer. On the fairing plastics, I peeled the graphics off with a razor blade and then sanded the clear coat to smooth it out a bit. If you look really closely, there's a bit of an indent.
I wasn't too worried about it coming out "perfect", as it's meant to be a rough-and-tumble aesthetic
Good luck if you go for it!
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
sevenpointsixtwo is offline   Reply With Quote
Old 06-25-2013, 06:48 AM   #5357
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,870
No we don't. I think it's probably your high Ethanol fuel over the pond.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger is offline   Reply With Quote
Old 06-25-2013, 07:33 AM   #5358
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,264
Thanks to the Corn lobby
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 06-25-2013, 08:12 AM   #5359
rrr70
Oddometer: 173
My friend's Ducati tank expanded to the point that it was impossible to operate locking latch by the ignition switch. It also was sticking about 3/4" on each side over the mounting points.
rrr70 is offline   Reply With Quote
Old 06-25-2013, 10:22 AM   #5360
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 352
Unfortunately, it's only going to get worse unless people educate themselves and take some action. The EPA is pushing forward with higher Ethanol content despite lack of testing or even other damage such as fuel tank swelling. I remember not so long ago, no one even believed in "gas tank swelling". I know this only applies to those in the US, but I suspect other areas have similar issues as governments try to make enemies of oil producing states. If non-ethanol (E0) is available to you where you are, use it, tell your friends to use it, it's worth whatever the additional cost. Your Tiger will thank you.
http://www.americanmotorcyclist.com/...ueslegislation
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is online now   Reply With Quote
Old 06-25-2013, 01:36 PM   #5361
sevenpointsixtwo
Newb Extraordinaire
Oddometer: 199
Yep, I can't get the front tank mount bolt in, so I left it off. The fairing mounts are absolute beasts to get in and out, not to mention the risk of spinning the captured nuts in the tank if they get too tight. Great engineering, Triumph!
-Sevenpointsixtwo
1998 Tiger 900
2000 DRZ400E
Old 06-25-2013, 05:29 PM   #5362
Earthscape
Earthscape's Avatar
Oddometer: 352
Probably shouldn't blame Triumph. When they designed the bike, Ethanol didn't exist as a fuel that might ever be used in the bike. They had no way to know in advance how the material would react.
For the captured nuts in the tank, go to your local hardware store and get some neoprene washers of about the correct diameter, and double or tripple them under each bolt. They don't compress as easily as the stock rubber washers, and will help to keep the bolt from bottoming in the captured nuts, which is what causes them to get stuck and spin. For the tank swelling, the only option is to let the tank sit dry in a low-humidity area for a few months. Hours after you put Ethanol back in, it will swell again. Yeah, that sucks.
Old 06-26-2013, 10:14 PM   #5363
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,336
Had a nice little ride over to Dust 2 Dawson and up the road to Inuvik. The weather was perfect and road dry the entire way. Aside from the 2 to 3 inches of pea gravel between the ferries, I was limited to 60mph strictly due to fuel management. Made the 255 mile stretch on only the fuel tank.
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is online now   Reply With Quote
Old 06-28-2013, 08:57 AM   #5364
hatschky
hatschky's Avatar
Oddometer: 32
Slovenia
hatschky is online now   Reply With Quote
Old 06-28-2013, 06:48 PM   #5365
Misadventure-Brad
Misadventure-Brad's Avatar
Oddometer: 33
Originally Posted by lmychajluk View Post
Just a quick snap I took in my driveway this morning. I got that Wolfie tail bag mounted up last week and really like it. I usually just run with the Hoops around town, but I have the Monarch Pass bags and the OEM 50L as well for when I need the extra capacity.
The Wolfman Rainier tank bag fits perfect, btw.. in case you've been thinking of adding it to round out your set. Very pleased with mine!
Misadventure-Brad is offline   Reply With Quote
Old 06-29-2013, 05:49 AM   #5366
PBee
_
PBee's Avatar
Oddometer: 9,231
QUORN SCHNITZEL CLUB Est 2011.
When in the FLINDERS RANGES SA stay at the
ANGORICHINA VILLAGE
PBee is offline   Reply With Quote
Old 06-29-2013, 08:16 PM   #5367
PBee
_
PBee's Avatar
Oddometer: 9,231
Originally Posted by yrunotriding View Post
Err ummm, sorry I thought this was a picture thread.
I'd remove it for ya but you've quoted it.
ANGORICHINA VILLAGE
Old 06-30-2013, 09:27 AM   #5368
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,870
Originally Posted by PBee View Post
Old Retired Person, born 1926????
Old 06-30-2013, 01:13 PM   #5369
Nortonrocks77
Nortonrocks77's Avatar
Oddometer: 21
Thumb
That is a nice looking set up.
Nortonrocks77 is offline   Reply With Quote
Old 07-01-2013, 03:42 AM   #5370
PBee
_
PBee's Avatar
Oddometer: 9,231
More bike.
ANGORICHINA VILLAGE
Times are GMT -7.   It's 09:24 AM.
