12-25-2010, 06:07 PM
#16 | |
Oddometer: 1,028
Excessive?
I can't imagine you are getting much benefit from this new oil - particularly as you state it is clean when you dump it. But - if it is working for you, it's hard to argue.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 |
12-26-2010, 05:11 AM
#17 | |
Oddometer: 1,354
![]() I will agree that after 15K the oil does look pretty good. My Toyota Tacoma has that 100K tranny oil, we'll see how it goes......
Roger '07 Wee Strom '06 FJR (For Sale) COG 5903 |
12-26-2010, 06:14 AM
#18 | |
Spudly Adventurer
Oddometer: 3,254
Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. Cogswell screwed with this post 12-26-2010 at 07:58 AM |
12-26-2010, 07:02 AM
#19 | |
Oddometer: 31,097
My 2007 Passat was initially spec'd as "fill for life", which has since been changed to a 40k-mile service interval. |
12-26-2010, 07:42 AM
#20 |
Wrench Rider
Oddometer: 712
What trans doesn't have a filter...??
Honda Pilot certainly has one, as does the Element... And anyone who thinks there's such a thing as "Life-Time Fill", will find out the truth at about 150K. What a croc... |
12-26-2010, 08:01 AM
#21 | |
Spudly Adventurer
Oddometer: 3,254
I do agree lifetime fill is. ![]() Mike
Cogswell Rides To Big Bend See my airhead project here Time Warp Vintage Motorcycle Club The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED. |
12-26-2010, 10:58 AM
#22 |
Oddometer: 1,546
approaching 250k miles on our civic. it does not have a changable filter. I've been draining the sump every 40k and refilling with synthetic atf since new. it shifts up and down without issues.
alot of first gen TL, odessey and other V6 honda had failures. honda would pay even if out of warranty. a co-worker got reimbursed for a SECOND transmission change at 150k miles. first one failed at 80k.
Alan 2011 KTM RC8R 2012 BMW S1000RR 2000 Kawasaki ZRX1100 |
12-26-2010, 11:16 AM
#23 | |
Caught & Released
Oddometer: 981
And by 1st Gen Odyssey, I assume that does NOT include the '95-'98 years, which I believe were 4cyl, non-sliding doors, etc? But most of all, I wonder if Honda attributes any of the failures to machine flush & fill services.
Guano11 Time flies like an arrow. Fruit flies like a banana. |
12-26-2010, 11:31 AM
#24 |
Oddometer: 2,036
I recently did my 04 Odyssey,,the going advice among the do-it-yourselfers is just drain it...(about 3 quarts but measure it) replace the 3 then drive around and repeat the process. Yes, It leaves some of the old stuff in there but after looking at what came out (looked pretty good) I'm not worried...the van has 155k on it.
Sent from my Radio Shack TRS-80 using a keyboard and electricity. |
12-27-2010, 09:30 AM
#25 |
The Bold Deceiver
I changed all the fluids, except the rear dif in my '06 Ridgeline this summer ~40k mark. I waited until the computer told me that it was time, bought all the fluids at Pep Boys (except the tranny fluid which I could only find from Honda).
It was ridiculously easy to drain and fill, took maybe 30 minutes. That included me taking the tire off and trying to figure out how to use the pump I bought to make it easier to fill the case. I think the tranny shifts smoother now, but that could just be in my head. I'll wait until the computer tells me it's time and then change them again. I recall it taking all 4 qts of fluid when I did the change. I would have been bent if I had left over fluid since I also recall the stuff to be ungawdly expensive. I also think there may have been a magnet on the drain bolt that was covered in a small amount of metal with the consistency of grease. I wiped that off of course. It seems a pretty common thing from my limited experience in changing other fluids. My very limited experience with transmissions is that some of them last and last even if they are mistreated. Other people do preventative maintenance and have nothing but trouble. I'm trying to find a balance between the 2 and hope that it keeps the gremlins at bay. Knowing it was 96 bux in labor makes me feel pretty good about doing it myself. Honda really puts everything where it should be (drain and fill holes, filters, ect). I wish Subaru and BMW would do the same. |
12-27-2010, 09:44 AM
#26 | |
Oddometer: 1,354
'91 Civic, '91 Accord, '98 CRV, '04 Pilot, '05 Civic, those are the only ones I can speak for but I'd assume most other Hond's are similar? Magnetic drain plug and I believe an internal, non-replaceable filter but no filter like I'm used to on "old-school" Ameican cars.
12-27-2010, 03:29 PM
#27 |
my butt hurts
Oddometer: 332
I've got a civic that I've had since new and has 140k on it now. since it only holds 6 quarts of tranny fluid and only 3 come out at a time, I've just changed it every other oil change. cheap insurance but in the end it's still the luck of the draw.
I don't know where I'm going, not sure where I've been. -john denver 99 dr350 78 r80 |
12-27-2010, 07:04 PM
#28 |
Wrench Rider
Oddometer: 712
Honda Pilot trans filter location
Here's a photo of the filter location in a Honda Pilot;
it is a pleated paper type: the filter cover is shown inside the red circle. http://www.piloteers.org/forums/atta...t-picture1.jpg And here's a pic of the old filter removed: http://www.piloteers.org/forums/atta...old-filter.jpg I did not take these pics, but found them on the 'net..... |
02-13-2011, 08:13 PM
#29 |
Caught & Released
Oddometer: 981
Not my intent to resurrect this thread unecessarily, but a coworker claims to have once worked in a repair shop that had a transmission flush & fill machine.
Contrary to how I thought it worked, he said the machine itself does no pumping whatsoever, and that the pressure to exchange the fluid is provided the transmission itself. The machine just has 2 reservoirs, one for the old fluid it takes in, the other for the fresh fluid it gives up. It's not even plugged into an outlet! Can anyone confirm or deny that's how they work? And if so, how would a machine flush & fill subject a tranny to more pressure than it's accustomed to?
02-13-2011, 08:42 PM
#30 | |
Wrench Rider
Oddometer: 712
necessary if the vehicle is running as it's own pump does the work.... No "machine" needed at all; just a piece of hose and a bucket work just fine.... Old fluid pumps out into the bucket while you pour in new fluid.... |
