Old 12-26-2010, 08:16 PM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,572
Question Airhead oil filter kit
Got my kit from Maxbmw, hinged. For an 81 RS with oil cooler. Filter has connected seal one end but not the other. No extra seal for other end.
Which way and how? Kit sez comes with 2 square o-rings. Not. Only one in the kit.
Wha's up?
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 12-27-2010, 04:40 AM   #2
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,603
The integrated seal end goes in first.
The second "square" o-ring is seated in the thermostat cover. You'll see where it goes.
The larger "round" section O-ring sits on the thermostat cover too. It surrounds the raised section.
Then the thermostat cover is carefully pressed into position, and tightened down.
You need to know if you should use a shim and/or a gasket.
Measure the canister depth and use Anton's guide.
http://www.largiader.com/tech/filters/
It's a good idea to test the ball and spring in the distal end of the filter canister. Just press it lightly to see if it is seated and is sprung.
boxerboy81 screwed with this post 12-27-2010 at 04:45 AM
boxerboy81 is online now   Reply With Quote
Old 12-27-2010, 06:47 AM   #3
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,572
Thanks, that clears it up. I have the -575 filter.
I'm also going to use the cover gasket and the shim.
Times are GMT -7.   It's 01:54 AM.
