03-22-2012, 11:00 PM
#151 |
Oddometer: 1,025
The tool in use
What's stopping you ?
04-11-2012, 06:33 PM
#152 |
Oddometer: 1,025
Testimonials
Thanks to all of you who liked the tool, and said so:
Just tried this today and it worked really well. I have a KTM 990 Adventure and filling up its dual tanks is always a hassle. Its easy to have gas spray back if you don't get the correct combination of nozzle angle/gas flow and vapor boot pull back. The tool was easy to slip on and gave plenty of visibility when fueling up, especially since I now can now do it one handed. I keep the tool in my glove box. Well worth 5 bucks. A metal version might be nice. __________________________________________________ ________________________________________________ Mine showed up right away, mailed fast. Only tried 2 gas stations so far but it fits right. Made the Chevron a lot easier and nicer to be able to see into the tank when topping off. And with my ST1100, I stick it under the fuel door so i don't have to dig it out of a pocket when I fill up. A little spot of velcro might hold it in place for other bikes... __________________________________________________ _________________________________________________ Anti Vapor recovery tool Yepper, happy camper here. Works great. I also used it on my gas can. Good Luck __________________________________________________ _________________________________________________ I received my order. Thanks for the quick service. This gizmo is so light, it would only need a small piece of velcro to stick it to something. Also, it would be easy to drill a hole for a lanyard of some type. I say leave it as is, inexpensive and simple, and let user make their own mods if needed. If you decide to make a metal version, I'd suggest experimenting with the shape of the slot - there might be a way to make it double as a bottle opener. __________________________________________________ _________________________________________________ Thanks Alex, I got mine today. It only took 13 days to get here due to Canadian customs and the great mail system. I'll let you know how I like it sometime in the spring. Cheers __________________________________________________ _________________________________________________ Okay, I finally got around to trying this thing, awesome. I like the hole design over the Aerostich version, it is less likely to fall off the nozzle. Held the vapor thing back perfectly. Heavy construction yet lightweight. At this time I can't think of any needed improvements. You should mass produce these babies with ads for cycle shops,mags, etc. Much better than keyrings. Let me know if you want someone walk these around the SF bay area. __________________________________________________ _________________________________________________ I used mine today for the first time...works GREAT! I had put it in my wallet next to my credit card so I'd remember to use it. It also fits perfectly in the little pocket on the right forearm of my 'stich. Two thumps up! __________________________________________________ _________________________________________________ I got my tool today. I haven't had a chance to try it out yet. Its the size of a credit card and about 4 cards thick. I haven't tried it out yet, but I am impressed by the design. I'm hoping I'll need some gas this weekend to try it out on. I learned last weekend how much of a pain it is to fill a tank on a GS with the nozzle's foreskin, so hopefully this will make it easier. __________________________________________________ _________________________________________________ I have used mine a few times now, works great. __________________________________________________ _________________________________________________ Works great with our "advanced" California nozzles. Thanks for coming up with these Kai Ju. __________________________________________________ _________________________________________________ I used mine on my airhead which has always been a problem when trying to top-up. Wished I'd had one o these 30 years ago... __________________________________________________ _________________________________________________ I reviewed this tool a month ago. Originally only tried it on an old pump and the nozzle didn't allow it to lock in place. Now that it has been over a month, I have used this tool a bunch. It works fantastic on all modern pumps. I use it everytime I fill up now. __________________________________________________ _________________________________________________ I bought one of these for my fly & ride from Seattle to SE AZ, it worked perfectly. At my last gas stop in California I filled up and then watched a herd of Harleys across the lot doing the same thing. They were having issues holding the pump sleeve back so I went over and popped this tool on their pump and told them to go at it. They were completely amazed and wanted to know where I got it. Karma being the rule I gave them mine so now I'll have to buy another if I end up going back through CA. Great tool and highly recommended. __________________________________________________ _________________________________________________ Great for your gas can fill ups! I use this product when I fuel up my Rotopax gas container, and it works great! No more overfilling the gas can, I can see inside the neck of the can to judge when to stop the flow. Thanks for a handy and useful product. __________________________________________________ _________________________________________________ Ordered two more. Can never have too many Xmas stocking stuffers. __________________________________________________ _________________________________________________ Just used mine again an hour ago, this thing just plain works. __________________________________________________ _________________________________________________ I lost one and my life is incomplete without all three. PM sent to acquire another one of this life-affirming miracle product. __________________________________________________ _________________________________________________ Well I finally got a chance to use the Vapour tool..........we took a trip to NorCal and it was needed there. I drilled a small hole in mine, attached one of those retractable key ring thingies to the tool and a pocket on the AeroStich..........and it worked great!! All the guys I travelled with wanted one. Do yourself a favour and get one or two. Cheers __________________ Just did a ride thru California on my K1600GT. Your tool worked fantastic. My suggestion, especially in California......Don't leave home with out it. Thanks again __________________________________________________ _________________________________________________ Just got mine today and tried it out. Worked great!! Thanks for making a great inexpensive product. __________________________________________________ _________________________________________________ Looks like a great idea for the CARB nozzles we have to deal with in California. I'd like to get one or more and sent a PM. Thanks __________________________________________________ _________________________________________________ I bought ten of these little wonders as gifts for my riding buddies, think I should buy some more, great tool super price Thanks again __________________________________________________ _________________________________________________ Got It! Thanks a lot....great product and cheap! __________________________________________________ _________________________________________________ Been using this Nozzle Tool, and it helps alot! I like thats its plastic cause if you bump the tank during fill-ups, it won't scratch it. Great tool, and great idea. __________________________________________________ _________________________________________________ I got one of these gadgets and tried it for the first time yesterday. It's dead simple and works great. If you live where you have to deal with EFN nozzles do yourself a favor and have Kai Ju send one to you. __________________________________________________ _________________________________________________ just used mine, like I do every time I get gas, awesome. __________________________________________________ _________________________________________________ You just saved yourself from reading eleven pages. If the above comments don't make you want one, or several, of these I don't know what else will. Belly up to the bar and spend some money, would you ? . Kai Ju screwed with this post 04-11-2012 at 06:45 PM |
04-11-2012, 08:35 PM
#153 |
Oddometer: 114
Hey, that reminds me, I left my pocket open and lost mine recently, so will be ordering another one.
04-11-2012, 09:19 PM
#154 | |
Oddometer: 824
That works great. Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
04-11-2012, 10:00 PM
#155 |
Oddometer: 1,025
Hole in One
If you want a hole in yours, let me know when you order the tool.
05-06-2012, 09:51 PM
#156 |
Oddometer: 1
I'd like one of these Vapor tools for my flying motorcycle
Hello,
I am a motorcycle rider (KLR 650) but usually ride mostly my flying motorcycle. I have a collapsable extra fuel tank from Turtle Pac that can't be filled by one person without this tool. So please send me one ASAP (you can email me at borarbora at digitalputty dot com) so I can give you my address & send you the $5 payment. Much of what you guys do here is what we do on our flying motorcycles , especially when we go long cross-country.Last year, we flew from the San Juan Islands of Seattle all the way to San Diego by way of the coast. If you'd like to see some of the movies we made (they're spectacular), they are here: http://www.youtube.com/watch?v=ob8oh...=plpp_play_all or here http://www.youtube.com/user/henry253 This summer we are flying them in Idaho & Wyoming, and next summer we will probably do a combination motorcycle / flying motorcycle (trike) adventure tour of Alaska. I can fit the trike and my KLR in the back of my toy hauler, so it is very cool that way. Love doing both. If any of you would like information about triking, I'd be more than happy to give it (I am just a private individual enthusiast, no sales of anything). Looking forward to talking with you guys soon about how to gear up for Alaska, David |
05-07-2012, 07:58 AM
#157 |
Oddometer: 1,025
Flying Motorcycle
That is really cool stuff. I think everybody would love to fly and your version seems to come pretty close to the motorcyle equivalent of flying.
I pm'd you the pay pal info. Let me and everybody else know how you like using the tool once you get a chance to use it. Cheers, Kai Ju |
05-23-2012, 06:16 PM
#158 |
Oddometer: 1,025
Post #152
Go to post # 152, immerse yourself in some light reading and wonder how you can survive without this cool tool.
Same price and deal as ever. I've been selling the tool since December of 2010 at the same price, who else can say that. Make yourself and me happy and buy a couple of these, would you ? 16,000 views, not quite that many sales. Kai Ju screwed with this post 05-26-2012 at 09:41 AM |
05-30-2012, 08:58 PM
#159 |
Full of it.
Excellent!
I used my VRNT tonight for the first time and it was great to have. I keep it in my jacket chest pocket where I keep my receipts and pen, so super handy. It was quick to put on, and then it allowed for controlled fueling, without the fear of splashing fuel by manually holding the foreskin back. Easy to remember to take with me as it is white. Super pleased with it. A winner.
John |
05-30-2012, 10:59 PM
#160 | |
Oddometer: 1,025
06-10-2012, 11:29 PM
#161 |
Oddometer: 4
Kai Ju, payment sent to you. Plz check your PM for shipping address information.
Thank you |
07-13-2012, 07:05 AM
#162 |
Oddometer: 1,025
Back to the top
Folks, there is no way that the market is saturated. How do I know ? I have EFN tools left
Here is another deal. One tool and one of the funnels for $12.00, shipped. Here is the info on the funnels: http://advrider.com/forums/showthread.php?t=796073 In addition I still have the five for $20.00 deal going on. If anybody wants a combination not listed here, pm me and we'll work something out. |
07-31-2012, 07:02 AM
#163 |
Oddometer: 1,025
Once more, with feeling
Fellow Inmates, do you have any idea what it's like to come up with something remotely funny/entertaining to get my thread to the top every now and then ?
This is harder then using the tool to hold that proboscis back, how about a little empathy ? You can express that empathy any numbers of ways, the prefered method being to buy one of these absolutely awesome tools. Take the time to peruse (1 a : to examine or consider with attention and in detail : study b : to look over or through in a casual or cursory manner 2 : read; especially : to read over in an attentive or leisurely manner ) this thread. Be entertained by my feeble attempts at humour and astounded by the reviews of the lucky customers that have seen the light and purchased this most elegant of refueling aids. ( See what I mean about trying to be funny, or just being trying ? ) Anyway, pm me if you want one, or two, or five.........or one of my awesome funnels. See above post for info on that item. |
08-07-2012, 08:05 AM
#164 |
Oddometer: 1,025
Well, that didn't work............
Ok, so I won't quit my day job just yet. But 18,000 views of this most awesome device and yet a severe lag in sales.
How can you not be overcome with the irresistable urge to plop dow a mere 5 bucks to be one of the lucky few ( and I mean few, at least lately) to own this simple, yet so effective device. Watch the video, read the endorsements, live a little, buy the tool. It's never been this easy to top off your tank, impress your friends, be the envy of your riding buddies. Ok, I can tell you've had enough. Anyway, same price as always. 1 for 5 or 5 for 20. |
08-29-2012, 09:23 AM
#165 |
Holeshot
Oddometer: 1
Worked great on my boat too!
Kai Ju,
I appreciate the nozzzel tool when filling my motorcycle BUT I LOVE THE TOOL WHEN FILLING THE 85 GALLON TANK ON MY BOAT!!! ![]() The boat is on a trailer so I stop by the same stations. Your tool allows me to better control the nozzel while allowing me to be a bit more mobile while filling. I now use all that energy for fighting those big fish.. You should've seen the one that got away!! Thanks for making it easy to order and for the quick shipping on every order. |
