Old 12-30-2010, 03:54 AM   #1
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 926
Upgrade piston, camshaft and carburator for XR650L
Guys,
I would like to increase torque and power on my Xr650L (already got airfilter+jetting, headers and muffler FMF, upgraded sprockets). I have been advised to replace my camshaft with an aftermarket one as it should increase performance. Apparently this modification is well established for the 600R and the aftermarket camshaft is the same.
Does anyone have any experience about it?
Moreover I have been advice to upgrade the carburetor as the original one is "depression" type and could be better.
Finally I have seen that there is a huge amount of aftermarket piston for this bike varying from 100 to 103mm. Any comment about these? Is it whorthet to install it? will the bike be reliable?
Many thanks&ciao
Nic
Explore Alps Off Road: www.over2000riders.com
2012 Ducati Multistrada 1200
2008 KTM LC8 990 ADV S
2003 KTM LC8 950 ADV
Trips:Europe,Africa,Asia
Dr LC8 is offline   Reply With Quote
Old 12-30-2010, 12:39 PM   #2
cyclewizard
cyclewizard's Avatar
Oddometer: 4,811
Yes,the bike will be reliable if you upgrade to a larger piston, me I like the 105mm 710cc and 106mm 724cc kit for the tq. and power it delivers.
I think this is by far the best mod for the money.
But any high compression piston will give you a boost in performance weather it be 100mm or 108mm just not as much with the smaller forging.
For the cam I would get a mild one or use the OEM cam for reliability, it actually works quite well as long as the compression is kept between 8.3.1 and 9.5.1. If you go to a 10.5.1 piston than you need to bleed off more cylinder pressure or use a higher octane fuel.
High lift cams with lots of duration and steep ramp angles tend to wear the valve train out sooner but how much on a XRL650 is yet to be determined mileage wise. Not to many people run a steep cam on the street but me hehe. The cam is the last thing I would do because it can transfer your power band to another location and it may not be what you're looking for.
Need more info on what you're trying to do.
For the carb you can use one from an XR650R that works very well and is on the cheap, 50 to 100 dollars for that mod, jetting is 65s pilot b53e or b53f needle two clips down or a b53d all the way down and a 165 main jet or more on the main if you have many mod's done to your motor.
Pumper carbs are the hot ticket for the 650L but they're pricey, 400 to 500 dollars but well worth it in my book,another one of the better mod's for the money. You can look for a used one but there hard to find.
Exhaust, they all seem to work well on the L because the OEM one is so restrictive.
Head porting, you really only need this if you want every last bit of power out of your motor, it does make a difference on the dyno.
Stainless valves with a 3 angle cut 60/45/30 is the way to go to finish off the head work.
The first thing I would do is add an exhaust and pumper carb or a XR650R carb if your lacking on funds and see if that will satisfy your needs and go from there, I see you already have an exhaust.
The pumper carb transforms the L into another bike coming from the stock CV carb.
Add all the mod's together and you have one very mean L.......
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard screwed with this post 12-30-2010 at 03:16 PM
cyclewizard is offline   Reply With Quote
Old 01-01-2011, 03:07 PM   #3
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 926
Many thanks,
this is very interestings and helpful.
Ciao
Nic
Old 01-01-2011, 04:54 PM   #4
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,280
What cyclewizard said.........but consider changing the 2nd gear to the NX650 second gear,,it closes the 1st-2nd gear gap.........makes it a lot better in the woods.......and even in the city it is really nice.The gap moves to 2nd-3rd but since you are moving at a decent speed it`s not noticeable..
B
techforlife is offline   Reply With Quote
Old 01-01-2011, 05:34 PM   #5
cyclewizard
Oddometer: 4,811
B
Thanks Brian for bringing that to his attention, makes for better wheelies.
C-dub......
Old 01-04-2011, 11:46 AM   #6
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 926
Guys
I usually ride my bike into the Sahara desert where I hardly use the 1st gear...I also start with the 2nd. To make the bike "shorther" I replaced my front sproket with one with one theet less and increased the rear by three.
I do have an old NX650 park in the garage but I don't feel I want to cannibalize her...yet!
Ciao
Nic
Old 01-04-2011, 01:11 PM   #7
BikePilot
BikePilot's Avatar
Oddometer: 11,253
Riding in the desert may tax a modified XR650L's cooling ability. I'd suggest a "big fin" head (cooling fins are welded up so that they are much longer) and oil cooler (the XR400R cooler is probably the most durable).
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 01-04-2011, 01:51 PM   #8
cyclewizard
Oddometer: 4,811
It's hard to beat the XR400 cooler for it's strength and durability.
And they're cheap compared to some of the other coolers on the market.
And for the big fin head, it's a must have for extreme hot weather riding.
100 bucks for the cooler and 300 bucks for a big fin head.
C-dub......
Old 01-04-2011, 02:21 PM   #9
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
are you excluding the JAGG cooler from your comparison. I ask because of GSMark's Oil Cooler build. http://www.advrider.com/forums/showthread.php?t=500646
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 01-04-2011, 02:32 PM   #10
cyclewizard
Oddometer: 4,811
GSMark's cooler looks great....
C-dub......
Old 01-04-2011, 03:13 PM   #11
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 926
Hi Cyclewizard,
thanks for all your explanations.
First of all the option of a better camshaft was suggested by my trusted mechanic. He is the most expert in XR in Rome...but beeing european he is not so familiar with the XRL model. I guess he was making his calculations on the XR600R compressio which I guess is 10.5:1 if not higher.
To summarize my bike has already a full exhaust FMF system, jetting, airfilter, wider airbox air conduit and 48 rear and 13 front sprokets.
So, starting from here, if you would suggest some mods what would you do:
1) 101mmm 10.5:1 piston?
2) XR650R carb?
3)Camshaft?
How much more in terms of power would these mods add?
Which piston would you go for?
Any idea of pricess?
Pardon my English...
Ciao
Nic
Old 01-04-2011, 03:47 PM   #12
techforlife
CDI REPAIR
Oddometer: 4,280
Originally Posted by Dr LC8 View Post
Hi Cyclewizard,
2) XR650R carb?
3)Camshaft?
Ciao
Nic
Put a FCR pumper carb on it,,,,,,and do the NX650 2nd gear mod........
Let`s face it,if you put a high compression piston in and a cam you are not going to gain much in horsepower..you might gain 5 or so....unless you go completely crazy with 105mm,porting,cam,carb.......
A good pumper carb will wake the bike up the most,without killing the engine life...
You can get more power from the engine,but you are going to spend a ton of money, and engine life can suffer,the main problem with trying to get alot of power from these engines is they are air cooled.....high power means high heat.......and the XRL can`t get rid of more heat than a little over stock........
Everyone wants these bikes to run like a new Husky or CRF or something but still be reliable,,it`s not gonna happen..........and the newer bikes have something like 12-1 compression or more.........and being water cooled they can take that for awhile longer........
If you want a fast bike,buy a fast bike.......these bikes can be fun,and have decent power ....but they definately have their limits..
If you put a 10.5-1 piston in it,you better be aware that it can spark knock/detonate badly.....
I`m sure CW can tell you what kind of money it`ll cost to get any real power increase........and the possible problems that can come from it too........he`s been at this longer than i...follow his suggestions on pistons and carb jetting and get a real good machine shop to do the work...
B
techforlife screwed with this post 01-04-2011 at 03:58 PM
Old 01-04-2011, 04:14 PM   #13
cyclewizard
Oddometer: 4,811
B
Hi brian, are you having problems with your HC piston spark knocking?
How about power, did it help you there or couldn't you tell the difference?
Have you thought about putting the stock one back in?
C-dub......
Old 01-04-2011, 04:17 PM   #14
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,223
DR LC8, BTW: http://www.advrider.com/forums/showthread.php?t=114834.
all of your questions should be just about answered. "This in addition to your normal class load should turn your brain to tapioca in no time."
Old 01-04-2011, 04:53 PM   #15
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 926
...so all in all...
Better carburettor (xr650r can do the job), nx 2nd gear and I'll get the most out of it?
I might go with it.
Is there any chance to increase the compression by lowering the head?
Your help guys is first class
Nic
P.S. All I would like is to get as much as an XR600r...
Times are GMT -7.   It's 05:15 AM.
