02-14-2012, 03:47 PM
#61 |
Oddometer: 7,989
Your correct with the 102.4mm piston with the OE sleeve.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
12-31-2012, 11:08 AM
#62 | |
Oddometer: 4
Xr650l upgrade piston camshaft etc
To Nic from Manchester / Roma .
Hello to everyone I have just joined this excellent forum in London. Very interesting reading here all the various engine mods available .Love the 105mm piston, XR carb,idea. Nic First question.Where did you get your XR650L from? I was not aware that they were available in England. Did you have it imported from the States? 2. Re:NX650 Dominator gear ratio modifications .I had a 1997 NX650 from new and sold it with only 8000 miles on it. I hated the overdrive 5th gear with the big gap down to 4th but maybe it works out on your XR650L bikes. . 3 JE.10.5:1 piston,stage two White Bros cam , Jagg oil cooler ,Arrow straight through exhaust, stronger clutch springs, 42 rear aluminium sprocket, 15 front sprocket, carb mods,52 slow jet, 158 main, standard drilled out carb and dino jet needle. Drilled out air box etc. lowered 40mm front and rear although I am 5.11. 4 It pulled like a train once it hit the cam at about 4000 rpm and could cruise at 80 all day at about 4000 to 4500 but I hated the big gap between 4th and overdrive 5th gear.. 5. I sold it because it was a top heavy moose of a bike(170kg /374lbs dry ) and I always wanted an XR650L with all the engine mods. 6 I assume that I would have to import one. 7 .Hey ,thanks for listening ,.Bye the way ,.the jagg oil cooler mounted at the side is essential even here in England in the summer to keep the oil temp down when cruising at 80 to 90 mph.Drops the temp by about 30 degree . Quote:
12-31-2012, 11:19 AM
#63 | |
Oddometer: 4
Re : 105 mm piston weight.
To Cycle Wizzard or colleagues,
How much heavier is a 105mm JE Piston than a 100mm Je piston? Just thinking about effect on revs but would not want any more that 5500 revs as would be a road bike . Quote:
12-31-2012, 11:20 AM
#64 | |
Oddometer: 4
How much heavier is a 105mm JE Piston than a 100mm Je piston? Just thinking about effect on revs but would not want any more that 5500 revs as would be a road bike . Rich NX650boy.London. Quote:
12-31-2012, 11:23 AM
#65 | |
Oddometer: 4
How much heavier is a 105mm JE Piston than a 100mm Je piston? Just thinking about effect on revs but would not want any more that 5500 revs as would be a road bike . Do you need to machine the engine casing or use a special sleeve for the 105mm piston.? Rich NX650boy.London. Quote:
