Old 12-30-2010, 04:55 AM   #1
zakidos OP
Oddometer: 57
Rear wheel: 17" vs. 18"
Hi folks!
I'm planning to get a new rear wheel on my XT 660 Z Ténéré. The stock one (17 inch) has a bad bump in it and it's already quite rusty. So I'm gonna contact Thorsten from OTR and see what the costs are for a new Excel rim and Talon hub.
But I'm still not sure if I should get the 18" or stick to the 17" one. I'm not a rally driver, just a on- and offroad traveller. Any ideas?
Cheers, Mike
zakidos is offline   Reply With Quote
Old 12-30-2010, 05:37 AM   #2
rivercreep
Oddometer: 3,243
Not a bad idea as it can open up new oppertunities for tire selection for off road use.
If I had the cash and a reason (like your wheels bump) I'd do the same thing on my DR.
rivercreep is offline   Reply With Quote
Old 12-30-2010, 06:21 AM   #3
BikePilot
BikePilot's Avatar
Oddometer: 11,253
Definitely a lot more off road tires available in 18". Maybe more street tires in 17" (I haven't checked). I would be inclined to go with an 18 I think.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 12-30-2010, 06:36 AM   #4
DaBit
Oddometer: 345
Many decent 50/50 tyres available in 18" rear, much better offroad tyre selection available.
Even more road-biased and 50/50 tyres available in 17" rear, but very limited offroad selection.
I would only go 17" if you intend to use road-tyres-with-an-allroad-look like the Conti Trail Attack for example.
DaBit is offline   Reply With Quote
Old 12-30-2010, 09:21 AM   #5
zakidos OP
Oddometer: 57
I got the TKC80 and are very happy with it. So I'll never intend to use a road-only tyre. But the one concern I have, my whole bike is gonna be higher about 2cm because of the 18 inch rim. Maybe this is a killer criteria. I'm not sure yet. And of course, stupid Swiss regulations: It would be a lot harder to get the rim registered in the vehicle documentation.
Cheers!
Old 12-30-2010, 09:31 AM   #6
Fubars
What would Scoobydo?
Fubars's Avatar
Oddometer: 1,751
Look on ebay for a DR350S (*not* E model) rear wheel. Same hub w/cush drive. You'll have to change out the brake rotor, though.
Fubars is offline   Reply With Quote
Old 12-30-2010, 03:54 PM   #7
DaBit
Oddometer: 345
With tyre mounted it's not that much. About a centimeter at the rear axle, which translates to several millimeters at the saddle.
That would be a good reason to stick with 17".
Old 12-30-2010, 04:07 PM   #8
BikePilot
BikePilot's Avatar
Oddometer: 11,253
You can always alter ride height to compensate for changes in tire/wheel height. I doubt there's much difference in overall height from an 18 to a 17 as the 17 will normally have taller sidwalls. Can't help with the wacky swiss regs.
Old 12-30-2010, 04:52 PM   #9
abhibeckert
abhibeckert's Avatar
Oddometer: 1,615
I wonder how much it will effect your gearing? Clearly it'll make all your gears taller, but I have no idea how much.
Personally, I'd go for the 18" and work my way through the regulations. There are loads of good dirt tyres and plenty of good road tyres for 18", but not the other way around.
Then again, the only thing that matters is whether the tyres *you* want are available in your size. I know my favourite tyres are available in both 18" and 17", because the shop accidentally gave me a 17" one (which I only learned after 3 hours of back breaking effort to get the thing on with my inadequate tools! )
abhibeckert is offline   Reply With Quote
Old 01-02-2011, 03:08 AM   #10
zakidos OP
Oddometer: 57
Thank you guys for all the responses. I have to wait a couple of weeks from now to get the paperwork for the new wheel sorted out. But it looks like I'm going to go with the 18 inch rim.
Cheers
Old 01-02-2011, 03:48 AM   #11
Lankbrown
No Pain No Gain
Lankbrown's Avatar
Oddometer: 63
Sprocket size
I recon go for it. You will get a better tyre selection and it is slightly better on the bumps when using the bike off road. Only thing to be aware of is the sprocket ratio will have to be changed. For example the BMW Xchallenge runs a 18 inch rear wheel with a 15/47T combination. The F650 (same rotax motor) has a 17 inch rear wheel with a 16/47T combination.
Cheers
Lankbrown is offline   Reply With Quote
Old 01-02-2011, 04:02 AM   #12
zakidos OP
Oddometer: 57
The stock Ténéré has a 15/45T combination, I changed it to 15/48T. But with the new rim I guess I go with one tooth less in the front or take or go up to 50 tooth at the rear. Let's see ;-)
Old 01-02-2011, 12:28 PM   #13
JensEskildsen
Oddometer: 1,012
How much room do you have in the swingarm for the 18" ?
I often change gearing on my bike, i dont think a 18" rim woul dhave much room to spare with a knobby, making it impossible to go a couple of tooths up and down.
Worth to think about.
JensEskildsen is offline   Reply With Quote
Old 01-02-2011, 07:37 PM   #14
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,650
went from 17 to 18 on the 97 dr650.
feels & looks better to me. narrow tire WANTS to corner
profile looks like an xr650l now, sweet
no fitment issues with the shinko 705, 4.10x18
plugeye is offline   Reply With Quote
Old 01-03-2011, 01:24 AM   #15
switch
Romanian Trailbiker
switch's Avatar
Oddometer: 679
Cheers
Do be careful with an 18 incher on a bike devised for 17. It's going to be a bit more unstable if highly tilted.
No bikes right now :( Used to own the best dommie in Romania and a damn-good R1100GS. Modded the hell out of both before selling them. Looking to get another bike soon.
switch is offline   Reply With Quote
Times are GMT -7.   It's 02:18 PM.
