Old 02-10-2011, 04:41 PM   #31
outfit
outfit's Avatar
Oddometer: 661
I'm not intentionally pissing on you're parade, but how did that steering damper work out fitted to the lower fork tube? I wouldn't have thought very well as one end'll move up&down with the fork tube whilst the other end will stay fixed. Just wondering if I got it wrong?
outfit is offline   Reply With Quote
Old 02-11-2011, 02:42 AM   #32
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
Outfit, it really worked well with the weak front springs, but I had the same concerns.
cleatusj is offline   Reply With Quote
Old 02-12-2011, 02:26 AM   #33
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,771
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 02-12-2011, 08:45 PM   #34
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
Got a little more done on the links and should have pic after some more work tomorrow. My wife's back pain put off our trip to the Llano eagle nest.
Old 02-13-2011, 02:54 PM   #35
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
The links are on the Goose minus caliper mounts, fender and threading the pivot bolts. Here is a left and right pic as promised.
Old 02-13-2011, 03:10 PM   #36
EvilClown
EvilClown's Avatar
Oddometer: 16,771
...and just like that there's a leading link front end!
~Augustine of Hippo
Old 02-14-2011, 02:59 AM   #37
NitroMax
NitroMax's Avatar
Oddometer: 684
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Old 02-14-2011, 07:33 PM   #38
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
Acquired a 9/16"x12 die to thread the shortened 350 Honda swing arm bolts. I was able to use the collars and bushings, for my pivots, that go with these bolts and will change the grease Zerks.
cleatusj screwed with this post 02-14-2011 at 07:45 PM
Old 02-15-2011, 03:41 AM   #39
brstar
brstar's Avatar
Oddometer: 463
Thumb Impressed
Seriously impressed here. I can see a job well done as well.
What did you use for the pipe bit at the triple trees?
Oh and the pivots. Any pics of the bits involved?
I wonder what sort of engineering hoops I would have to pass through here in Oz? You need permits for any sort of mods as far as I know here.
Cheer Bruce.
brstar is offline   Reply With Quote
Old 02-15-2011, 10:25 AM   #40
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
Bruce, I used an extra set of stock fork tubes that started to show rust and I cut the stock CB350 Honda bushings from the swing arm and welded them to the bottom of the tubes. The only info I used to design was posted in this forum in the Auzzi builds by looking at all the search results for "leading links". There are no other pic's as this happened over the weekend.
Old 02-16-2011, 08:17 AM   #41
icebox
Oddometer: 1,078
Cool
Really starting to shape up. Work and a set of tubes is what has me stalled on a similar project , actually one 36 MM tube is what I am looking for. Will be following to see how the spring rates work out.
icebox is offline   Reply With Quote
Old 02-20-2011, 04:04 PM   #42
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
I got around to mounting the calipers, damper and a fender.
I then took it out for a 30 mile test run. The spring rate seems about right but will try it with one click of preload next time. I do need to make a 1/8" adjustment to move the calipers out to take pressure off the outside pad.
Other than those small changes I'm real happy with the way it handles.
Old 02-21-2011, 09:31 AM   #43
NitroMax
NitroMax's Avatar
Oddometer: 684
Good thing you can't see my jealous face
Old 02-22-2011, 05:07 AM   #44
brstar
brstar's Avatar
Oddometer: 463
Thumb Leading forks
Thanks and I like the looks so far. Very neat.
Cheers Bruce
Old 02-26-2011, 02:31 PM   #45
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,221
Just got back from a very short ride down the block and she said it might not be too safe for her neck if her head moved around as much as it did without a helmet. She has so little neck strength anyways. She commented on how much smoother it was than she thought it would be.
Times are GMT -7.   It's 01:57 AM.
