Old 04-01-2011, 06:08 PM   #196
Brauhausbier OP
Focused
Brauhausbier's Avatar
Oddometer: 1,367
Originally Posted by canyncarvr View Post
..just following along...but that was the piston it ran into I presume?
Valves can run into cylinders, but that is usually part of stuffing oversized valves in a head.
If you didn't know this engine was an interference design, you do now!
Good to hear you're back on track.
Thanks for following along
What I belive was happening is this:
- The cam chain was off the drive gear and so tight it was moving by friction alone on the inside of the cam drive gear spline
- as we kicked the bike to try to make it start, the cam chain turned but slipped since it was only spinning on the spline.
- Totally out of timing, the intake valves ran into the piston
I'm sure this happened the first couple of kicks and no wonder why it wouldn't fire. Bent Valves. Lesson learned. It's been a very educational week about 4 stroke motor building
At least I didn't give in and bring it to shop! Kept the faith
Brauhausbier is offline   Reply With Quote
Old 04-01-2011, 07:31 PM   #197
mcma111
mcma111's Avatar
Oddometer: 12,068
Life
Live 'n Learn
It's all a process.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2011, 08:55 AM   #198
elsalvadorklr
southern xr rider
Oddometer: 4,154
keep the faith! you can do it! jajaj
EDIT.. look like a bunch of us will have these powercore 4's on. please report...
elsalvadorklr is offline   Reply With Quote
Old 04-02-2011, 07:44 PM   #199
creaky
creaky's Avatar
Oddometer: 186
Fellas, I have to throw in my $.02 here...I read in previous posts about the cam being 180 off. It is not possible to get the cam 180 off in the XR600 engine because it is a wasted spark engine, that is, the spark occurs on every revolution of the crankshaft. The cam lobes should be facing down when installing the cam cover so that there is no pressure on the rocker arms to overcome when tightening the cover screws.
'98 BMW F650
'96 XR400
'98 Moto Guzzi V11
"Once you go over the hill, you start picking up speed!"
creaky is online now   Reply With Quote
Old 04-02-2011, 10:03 PM   #200
Brauhausbier OP
Focused
Oddometer: 1,367
Top End Day - Redux
Okay...back at it
Cleaned up all the head surfaces with Lacquer Thinner - great tip from mcma111
Pic of the OE Intakes valves back on the head after swapping out the bent KB's I destroyed. Nice job of cleaning those up by the boyz at Baisley's!
Getting all the head surfaces cleaned up
Lost the cam chain off the drive gear while getting the head on - same thing that happened when I did the top end the first time. Pulled the Right side cover to properly re-set the cam chain on the drive gear. Really the only way to do it right. This is where I messed up on the first go around. Exact same scenario. Doing it right this time.
Cam Chain on drive gear
Set HotCam at TDC - Lobes are down, marks on the cam gear are at 9, 12, and 3 O'clock. Tensioner is in. Cam chain is on the drive gear
All in!
Used Permatex Non-Hardbinding Sealant to seal up the valve cover tight. Put a thin layer on all surfaces including both sides of the valve gasket to make a sealant "sandwich" - another great tip from mcma111. Used rubber bands to hold up the sub rockers for assembly - thanks for the tip mcma111
Whew - all together - set valves for HotCam at 0.15mm intake/ 0.20mm exhaust
New problem - my choke spring is toast. Tried for over 2 hours to cut, mangle, rewind, and no go. Can't buy one off any OEM supplier. Anyone happen to have a choke spring for the Kehein 38mm OE Carb?? Works ok manually, but would be nice to have some spring action in the choke.
I'm cleaning up the sealant on the head tomorrow and will get the carb back in and give her a test fire tomorrow! Wish me luck
Old 04-02-2011, 10:06 PM   #201
mcma111
mcma111's Avatar
Oddometer: 12,068
Luck
Your done. Starts in first handful of kicks. Good Luck.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2011, 10:09 PM   #202
Brauhausbier OP
Focused
Oddometer: 1,367
Thanks so much for all our help mcma111!
I picked up a 16 penny nail today to replace the resistor in the spark plug boot! I'm on that tomorrow morning That's a killer mod and thanks for everything Steve!
Old 04-02-2011, 11:37 PM   #203
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,978
jeebuz...after all you've been thru with this, I sure hope you like the bike once it's running
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 04-02-2011, 11:54 PM   #204
Brauhausbier OP
Focused
Oddometer: 1,367
Thanks Blake. Been working on this rebuild for 4 months now...and my birthday is tomorrow too.
It would be nice present to hear that motor come to life
I'm thinking about that FCR off the CRF450 as a possible mod?
Too much work for the cheap price, or pay the $600 for the Sudco kit?
Pissed my choke spring is toast on the OE Keihin
Old 04-02-2011, 11:54 PM   #205
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,212
Maybe brass mo betta?
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 04-03-2011, 12:28 AM   #206
DRZ400SM1981
One meaty Adventurer
DRZ400SM1981's Avatar
Oddometer: 53
Looking good, but 16 penny?
Brauhausbier,
Happy almost Birthday! Bikes looking great. Hopefully just a day away from starting her up. If Steve's says it's good, it should be.
Look on Ebay for an FCR. I've been looking for a week or so and you can get and FCR from a CRF450 and the throttle assemble for around $225. Get a NOSS Adapter and jets and your in for around $300. A lot better than $600 and only a little bit of leg work.
And what is the mod with the 16 penny nail? Never heard of that one.
DRZ400SM1981 is offline   Reply With Quote
Old 04-03-2011, 12:53 AM   #207
Brauhausbier OP
Focused
Oddometer: 1,367
Originally Posted by DRZ400SM1981 View Post
Brauhausbier,
Mcma111 told me about this one:
Uncrew the spark plug brass in the spark plug boot.
There is a spring and resistor back behind the brass spark plug cap.
Cut a 16 Penny Nail, or bearing rod (same diameter) to that resistor length and bolt her back up. Better spark with a direct electrical path (resistor removed). Sweet and cheap mod! The best kind
Thanks for the tips on the FCR from the CRF450! I might just have to do that one
Old 04-03-2011, 01:41 AM   #208
Ladybug0048
Bug Sister
Ladybug0048's Avatar
Location: Spokane Valley, WA (the dry side of the mountains)
Oddometer: 10,947
Happy Birthday and I hope your birthday wish comes about. Vrrrrrooooooooooommmmmmmm (I didn't know how to spell the sound an XR makes )
Ladybug0048 is offline   Reply With Quote
Old 04-03-2011, 01:57 AM   #209
Brauhausbier OP
Focused
Oddometer: 1,367
Thanks Ladybug! I need to get some sleep Cheers!
Old 04-03-2011, 05:31 AM   #210
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,978
Happy Birthday, BHB... and I hope you hear the bike run on your birthday.
You know that people are going to be asking you questions about these bikes now....you've learned more than many of us have on this one build
Times are GMT -7.   It's 02:43 PM.
