Old 06-01-2011, 09:34 AM   #271
taco
b00b t00b
Oddometer: 12
Some video from our first weekend
Great times riding at EFR last two weekends!!
http://www.youtube.com/watch?v=wVR1yd75XDI
taco is offline   Reply With Quote
Old 06-04-2011, 06:51 AM   #272
elsalvadorklr
southern xr rider
Oddometer: 4,154
Originally Posted by MortimerSickle View Post
A note on IMS tanks:
Beware of the fit around the compression release. I put on a used IMS 4 gal. and noticed that the release rubbed the tank when pulled. It may not have caused a problem, but I was afraid that on rough ground it might interfere, and keep the exhaust valve from seating.
The tank has a relief for the release, but it was not large enough. I heated the area, and enlarged the relief to cure the problem.
Because tank was used when I got it, it may have expanded with age, so if a new tank fits, it probably should periodically be checked for clearance.
Sorry to hijack your thread like this BHB, but Im almost done with my build but alas, I have this issue with my 4gal IMS tank...stupid me, I already filled her with gas....
sooo...what method did you use mortimer? to heat up and "expand" the cutout for the comp release?
it looked tight when fitting it but as soon as I put the seat and everything else on it rubs...
I tried bending the comp release arm a bit INWARD but it still rubs a bit...
can you grind material off? sand it? or dump the gas and torch it? sounds risky...
thanks guys
P.S. Im dealing with a no fire rebuild too on this end...
elsalvadorklr is offline   Reply With Quote
Old 06-04-2011, 09:19 AM   #273
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,212
Yes, I heated it, then pushed on the spot with my rag-covered thumb. The spot it was hitting was just at the edge of the existing relief, so I had to increase the area of the relief, as well as the depth of it.
...or dump the gas and torch it? sounds risky...
Nooo torchy!
I first rinsed the tank several times with hot water, then used an electric heat gun... outdoors... with the filler downwind, just in case.
But, plastic shrapnel shouldn't hurt as much as steel anyway.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 06-07-2011, 06:58 AM   #274
elsalvadorklr
southern xr rider
Oddometer: 4,154
well I didnt torch it, just filed off some plastic worked great...
THE BIKE RUNS BTW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! so happy, so thanks and cheers to you guys...
finally....its been a long roaaaaaaaaaaaaaaaaaaaaaad!
vid of the bike running coming up soon...
later!
Old 06-28-2011, 06:27 PM   #275
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,549
Ouch!!
WTF Eric?
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 06-29-2011, 04:43 AM   #276
Dino3310
Oddometer: 673
friggen ouch alright mate
Dino3310 is offline   Reply With Quote
Old 06-29-2011, 07:04 AM   #277
elsalvadorklr
southern xr rider
Oddometer: 4,154
I want to know how that happens....sorry bud...geeeeez
Old 06-29-2011, 02:58 PM   #278
Brauhausbier OP
Focused
Brauhausbier's Avatar
Oddometer: 1,367
Originally Posted by wibby View Post
Ouch!!
WTF Eric?
Looks like the culprit was a clogged oil screen from the bottom of the frame oil tank. Starved the oil flow severly.
Luckily I had a vance 100mm sleeve installed last go around by the talented Ron at RB Designs. I just picked up the newly milled sleeve from his shop today and am now running a 101mm JE piston. Plenty of sleeve left in case I screw this one up
I bought a complete rebuilt head off eBay that includes the rockers, OE cam, new valves, seats, and is ported with low hours. My old head was cooked and the head needs a new machined center journal, new cam, and new rockers. I'm going to rebuild this one later this year if I can help it
Installing the new top end today wish me some luck this time
Brauhausbier is offline   Reply With Quote
Old 06-29-2011, 04:16 PM   #279
brad21
Farting in a Fan
brad21's Avatar
Oddometer: 3,574
Use this code when opening a Smugmug account and get $5 off! HkVR4XuSGKW46
BRC Member #49252 JOIN TODAY! https://www.sharetrails.org/support/join-or-contribute
brad21 is online now   Reply With Quote
Old 06-29-2011, 04:19 PM   #280
mcma111
mcma111's Avatar
Oddometer: 12,068
Oil Screen
So what was the screen clogged with? Metal, rag material, loose sealant, a mouse???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 06-29-2011, 04:24 PM   #281
Brauhausbier OP
Focused
Oddometer: 1,367
Looks like some loose sealant had clogged up the oil screen. Maybe some other goo too left in the frame even after my attempt to clean it? Who knows?
Old 06-29-2011, 04:26 PM   #282
MortimerSickle
Semi-Adventurer
Oddometer: 12,212
Originally Posted by brad21 View Post
On the bright side, at least it didn't run an hour longer, leaving him to pack it out of Hells Canyon.
G.H.W.S. 1878-1962
Old 06-29-2011, 04:26 PM   #283
elsalvadorklr
southern xr rider
Oddometer: 4,154
man eric Im so sorry, I know how you feel...
oil strainer huh, mind some more details like what clogged it up?
if you have the chance or want to talk about it....
good luck man, youll be back on the road in no time!!!!!!!!!!!!!!!!!!
christian
edit I see everyone posted the same question at the same time, well good luck!
Old 06-29-2011, 04:34 PM   #284
Brauhausbier OP
Focused
Oddometer: 1,367
christian
Thanks for the good kharma Christian
I'm just waiting for Taco to show and we'll pop the cylinder over the new piston!
Time for a cold brew
Old 06-29-2011, 04:46 PM   #285
elsalvadorklr
southern xr rider
Oddometer: 4,154
nice nothing like a cold one...
Times are GMT -7.   It's 02:32 PM.
