Old 01-30-2011, 09:36 PM   #61
rcerrie
rcerrie's Avatar
Oddometer: 12
Nice, getting there!!!
rcerrie is offline   Reply With Quote
Old 01-31-2011, 12:33 PM   #62
artimious7@yahoo.com
Artimious7
Oddometer: 13
Looking good!!
_______________________________
08 Honda CRF450r
98 Honda XR600r
97 Honda CR500 Hillclimber w/NOS
GSXR 1100 Hillclimber (in 08 Honda 450r trim)
artimious7@yahoo.com is offline   Reply With Quote
Old 01-31-2011, 12:51 PM   #63
Brauhausbier OP
Searching for IPA
Brauhausbier's Avatar
Oddometer: 1,356
Originally Posted by artimious7@yahoo.com View Post
Looking good!!
Thanks so much for the props!!
Hope this week to get the engine fully cleaned up and get my newly bored cyclinder back from Rb Designs this weds!
Just got my big parts order in from OEMcycle today
Now just gearing up for the case split on Feb 12th.
Should have all those parts early next week.
Brauhausbier is offline   Reply With Quote
Old 02-01-2011, 08:55 PM   #64
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,241
Send a message via Yahoo to wibby
I bought a caliper on CL
Dunno what was all over it but nothing would take it off
Here it is after soaking a day in Berryman's
I ended up using a wire wheel
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 02-02-2011, 09:02 AM   #65
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Thanks for that tip on Berryman's Wibby!
I have this whole next weekend to work on my XR! I will run out and pick up some Berryman's chem dip. I als wanted to soak the carb too in a good Chem Dip. Will do!
Old 02-13-2011, 10:55 AM   #66
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Finally an update on the motor progress over the past two weekends. Finally have some forward momentum going
Using wire brushes and 2.5% Phosphoric Acid the case cleaned up nicely
Spent an afternoon cleaning up the case last weekend.
Old 02-13-2011, 11:18 AM   #67
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Yesterday with the invaluable help from my friend Luke (this is his ADV screen name too), we split the cases to replace the countershaft. In my short 11 year motorcycling career, this is my first case split What an experience!
Here we go:
Right Cover Off
Clutch Basket Next
Used an air gun to remove the 27mm nut behind the clutch basket. That worked well.
Removed the kickstarter, oil pump, ignition sensor, etc to strip out the right side components completely.
Next up was the case split. This took some time and a lot of elbow grease. Definitely the most difficult task in the whole process was this center case separation.
Here we go.
I made a case splitter using two 4' lengths of 2x2 an used a chunk of 2x4 to make fulcrum and applied the pressure on opposite sides of the case through the cylinder opening:
The start of some separation
Finally got the case pins separated
The propane torch is coming in handy trying to loosen up the case pins
Success
The crankshaft and transmission look good for a 17 year old XR
The new countershaft
Look how crisp the splines are
The old splines (just for reference)
Old 02-13-2011, 11:49 AM   #68
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
The transmission is out
Fun times - getting all the old gaskets off - much faster with two working
The side cases are looking cleaned up and ready for reassembly
New countershaft installed and transmission reassembled
Ready to reassemble the cases
Reassemble Right Side Case Components (Clutch Plates all above spec)
New Ricky Stator
Right case cleaned up and ready for installation
Bottom end is completely finished!
Wow..a 10 hour marathon on the bottom end rebuild but we did it in just one day!
I'm greatly indebted to Luke for his assistance and knowledge
Luke, please enjoy the 4 cases of tasty beer from my employer Widmer Brewing and again a Big Thank You!
Brauhausbier screwed with this post 02-13-2011 at 11:56 AM
Old 02-14-2011, 12:22 PM   #69
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,098
Looks great Eric. I can see the scientist in your method of operation. Looks like PO let the cs sprocket nut get lose.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 02-14-2011, 05:18 PM   #70
sector
Oddometer: 2,819
Wow! Impressive work!!
09 KTM 105 XC
07 Yamaha XT225 - Std Color
07 BMW F650 GS - Black
Checkout the Barnacle Bistro, Gold Beach, OR http://www.barnaclebistro.com
sector is offline   Reply With Quote
Old 02-14-2011, 06:25 PM   #71
Brauhausbier OP
Searching for IPA
Oddometer: 1,356
Thanks Sector and CP! Hopefully I''ll get the cylinder head together by the end of the month! Got a new sleeve coming for the cylinder and the head is at a fantastic local moto cylinder head shop called Baisley Performance www.baisley.com just down the street from us! These guys have been just fantastic! New KB valves, new OE valve springs, and new gaskets. Plus, the Baisley guys will bead blast the head and cylinder + polish. I can't say enough about Bailsely..absolutely A+
Old 02-14-2011, 06:34 PM   #72
wibby
wibby's Avatar
Oddometer: 10,241
Did not see or or hear you mention bearings and crank seals
Woulda been a good time
'05 DL650
'92 KDX200
Old 02-14-2011, 06:37 PM   #73
mcma111
mcma111's Avatar
Oddometer: 7,986
It's not a 2 stroke...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-14-2011, 06:42 PM   #74
wibby
wibby's Avatar
Oddometer: 10,241
well duh
still I'd be replacing bearing while I had the chance
cheap insurance
'05 DL650
'92 KDX200
Old 02-14-2011, 06:54 PM   #75
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,749
well duh
cheap insurance
Disagree. The XR bearings are big, expensive, and reliable.
Luke is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
