Old 02-14-2011, 07:57 PM   #76
Brauhausbier OP
Focused
Brauhausbier's Avatar
Oddometer: 1,367
Originally Posted by wibby View Post
well duh
still I'd be replacing bearing while I had the chance
cheap insurance
Thanks Wib!
I did replace the countershaft case seal and the gear shift seal on the left side case.
Brauhausbier is offline   Reply With Quote
Old 02-14-2011, 07:59 PM   #77
Brauhausbier OP
Focused
Oddometer: 1,367
Originally Posted by Luke View Post
Disagree. The XR bearings are big, expensive, and reliable.
I'll second that!
Thanks so much Luke! I'll give you a buzz when the top end is ready to bolt together!
Old 02-14-2011, 08:02 PM   #78
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,549
Depends where you get them
Peterman got all my bottom end bearings and seals on the KDX for right at $50
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 02-18-2011, 08:01 PM   #79
Brauhausbier OP
Focused
Oddometer: 1,367
New parts are trickling in this week
Received the new 100mm cylinder sleeve yesterday from XR's Only and delivered that to Basiley's High Performance http://www.baisley.com/ at lunch today. The cylinder and head had been cleaned and polished and looked brand new. Looks like they will get the cyclinder re-sleeved this next week.
Also received the new HotCam Stage 1, and new rockers
Plan is to get the head together the first week of March.
Cheers!
Old 02-18-2011, 08:44 PM   #80
rorybellows
lost in the sauce
Oddometer: 404
im gonna be watchin this...
rorybellows is offline   Reply With Quote
Old 02-21-2011, 04:56 PM   #81
earwig
Crowbar of Embrayage
earwig's Avatar
Oddometer: 4,726
Wow!
You've been busy.
Looks like it's coming along well.
earwig is offline   Reply With Quote
Old 02-21-2011, 05:02 PM   #82
Brauhausbier OP
Focused
Oddometer: 1,367
Originally Posted by earwig View Post
Wow!
You've been busy.
Thanks Eric! Really great to see you and Debbie this Saturday.
Old 02-21-2011, 05:43 PM   #83
Blakebird
r-u-n-n-o-f-t
Blakebird's Avatar
Oddometer: 15,978
Which rockers did you get?
If you got the ebay ones, the adjusting screw will be too long, so use the originals (don't toss 'em!)
looking good, btw!
IBA #11735 . 1968-present
Blakebird is offline   Reply With Quote
Old 02-21-2011, 06:45 PM   #84
uranys
Oddometer: 188
Just curious why you decided to get a new cam? Were you concerned the new rockers wouldn't like the old cam?
Sorry if I missed it, but did you go for the big fins?
+1 on that, I've got three motors and never had a bearing fail.
Looks like it's going to be one clean & mean machine when your done.
uranys is offline   Reply With Quote
Old 02-22-2011, 09:08 AM   #85
Brauhausbier OP
Focused
Oddometer: 1,367
looking good, btw!
Thanks Blake
I did get the Ebay rocker arms, and remembered about those pins. Easy enough, I just swapped out those long pins for the OE's. Great price and look to be just as good as OE. Fast shipping too from Florida!
No time for wrenching this week. I'm off for a four day on Mt Hood tommorrow for what looks like a huge powder weekend!
Old 02-22-2011, 09:12 AM   #86
Brauhausbier OP
Focused
Oddometer: 1,367
Thanks for the bump!
I went with a new cam since a couple of the lobes on the existing hot cam were lighly scored. Luke gave them his once over and suggested the same.
I'm not electing to do the big fins. One less thing to do right now.
This job I have is getting in the way of any wrenching time
Old 03-06-2011, 09:52 PM   #87
Brauhausbier OP
Focused
Oddometer: 1,367
Many thank you's this week!
Thank you Radioman for the tire changes on your sweet machine this last Weds eve.
Thank you Luke for loaning your bearing puller kit. Could not have pulled the wheel bearings without it.
Thank you Steve for the help Saturday with the wheel bearing replacement front/rear.
Steve on the "Pittsburgh" bearing puller
New Maxxis IT's/ Bearings/Seals/Front Rotor
Adding new bits to the rear swing arm
Finally, the first part to be bolted to the frame...a miracle to finally get to this point
Setting the rear swing arm into position
Rebuilt rear shock and linkage installed and torqued to spec
The XR project is finally starting to take shape
Triple Clamp installed/New IMS 4.7 gal tank
Should get the re-sleeved cylinder back mid week and hopefully have the top end finished very soon
Old 03-06-2011, 11:32 PM   #88
flyjosh
Stave It Off!!!
flyjosh's Avatar
Oddometer: 249
Sweet. Looking good. It's gonna be the best XR out there.
Joshua, the Inuit hater
2001 KLR650...I think I got the slow one.
1972 F6 (gone)
flyjosh is offline   Reply With Quote
Old 03-07-2011, 08:50 AM   #89
mcma111
mcma111's Avatar
Oddometer: 12,068
Air Box
You should have installed the air box before the shock.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-07-2011, 09:18 AM   #90
Brauhausbier OP
Focused
Oddometer: 1,367
Thank you Steve!
Thanks for catching that before it really became a serious pain in the ass.
Times are GMT -7.   It's 02:45 PM.
