Old 11-09-2010, 12:20 AM   #121
bmwktmbill
Traveler
Oddometer: 5,190
Originally Posted by explodingmouse
I dont understand what all the fuss is about , my 03 is the easiest bike to kickstart that I have ever had !
You must be 7 feet(3 meters) tall and do ballet and yoga when not playing football.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-09-2010, 07:47 AM   #122
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,841
kick it standing on the left side with your right foot while the bike is leaning toward you.. easy
wrk2surf is offline   Reply With Quote
Old 11-10-2010, 09:26 PM   #123
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,238
no you don't get it.
When my 03 was new, if I didn't use the manual decomp lever to get it a little past TDC then all my 200lbs was nearly worthless. Even when thrown into the air and snapped down on the kicker the mutha wouldn't budget sometimes.
Now, six years later, with about 20K on the clock, I have little trouble kicking her through and don't often bother with my whole routine. And she still starts easy 'nuff, even if she's easier to kick through.
My guess is still diminished compression - its physics right?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-10-2010, 09:49 PM   #124
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,195
It sounds like your automatic decomp finally started working. I couldn't kick mine through when the auto-decomp broke. Once I fixed it, the bike kicked like it should ... and that was with a fresh piston.
Luke is offline   Reply With Quote
Old 11-11-2010, 12:36 AM   #125
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,600
There's not a shitshow in hell that I could kick that through TDC-C from a standstill. I can literally jump up and down on the kickstart and she don't budge. 625cc @ 11.5:1 CR beats <150lbs.
I've been kicking mine for a couple of years - someday I'm gonna have to cough up the $500 to replace the start gears/clutch. But I can start it per the book, standing on LHS using right foot, or straddling the bike using left foot... but only using the manual decomp to ease past TDC-C to start the kick.
Losing compression makes the bike harder to start because you don't have such good combustion. Valve recession can use up all the clearance and cause a poor seal. Meat, as an extreme test, pull your manual decomp, hold it in, and try and start the bike... report back here. I guarantee it won't make it easier
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 11-11-2010, 05:07 AM   #126
Coastie3202
King of the Mountain
Coastie3202's Avatar
Oddometer: 859
It is so nice to see so many who still know and enjoy the art of kick starting a big bore bike. I am 55 years old and still enjoy the process as I fire up the XR650R. In motorcycles I prefer simplicity, air cooling, kick starting, and chain or belt drive on my road bikes. Ahhhhh, life on the trails and roads as it should be.
I want to live in a world where common sense and courtesy trump entitlement...a world where chickens can cross the road without having their motivation questioned.
Coastie3202 is offline   Reply With Quote
Old 11-11-2010, 05:12 AM   #127
explodingmouse
Oddometer: 222
Im only 5,8 and 80kg , like said before , stand on left side of bike , kick with right ,when mines been runnin longer than 5 mins kick with left sitting on bike , no probs.
explodingmouse is offline   Reply With Quote
Old 11-11-2010, 05:14 AM   #128
BHW
BHW's Avatar
Oddometer: 4,135
I'm the recent new owner of an XR650R. I'm probably gonna need to buy new pants in the near future....my waist size is going down and my right thigh is getting huge. I told my riding buddies that I need to buy a manual transmission truck now to get some kind of workout for my left leg.
I've read all of the instructions for starting the BRP. I've tried them all. What I've noticed so far is that the choke is as useful as a screen door on a submarine. Has no effect whatsoever. I prefer to not use it at all.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 11-11-2010, 07:02 AM   #129
meat popsicle OP
Ignostic
Oddometer: 14,238
Hey Luke,
shouldn't I hear clacking if the auto-decomp is... actuated?
I didn't know it could activate during kick-starting. I know it accuates when the engine slows down, but doesn't it need a bit of RPMs to even open up? Maybe I don't know the auto-decomp; does it start off open, and then only close once the RPMs rise above (what was it?) 1500?
Old 11-11-2010, 07:05 AM   #130
meat popsicle OP
Ignostic
Oddometer: 14,238
Hey warewolf,
well my bike's still pretty easy to start so maybe the comp is good.
I don't like the idea of using the manual decomp to help start the bike; maybe if I was in BFE and couldn't get her started. But just resting my finger on the lever during running I can feel the cam lobes turning - it can't be good for the mechanism!
Old 11-11-2010, 07:15 AM   #131
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,949
Hey Luke,
Spring forces the lobe into the exhaust valve (rocker bearing?), keeping it open a smidge (technical term).
Motor spins up a bit and the weight opposite the lobe overcomes the spring pressure and pulls the lobe off the exhaust valve.
Kicking it over isn't gonna spin it fast enough to de-activate the mechanism.
I don't always hear a clack but I believe my mechanism is working just peachy.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 11-12-2010, 07:28 AM   #132
meat popsicle OP
Ignostic
Oddometer: 14,238
Dang if I don't learn somethin' every day - But if the auto-decomp was open when starting wouldn't that make it (easier to kick through but) harder to start?
My auto-decomp seems to be working fine: when the RPMs drop too low the clacking begins and then disappears when the RPMs rise again.
Old 11-12-2010, 10:11 AM   #133
bmwktmbill
Traveler
Oddometer: 5,190
Guys,
When I think of all the motorcycles I have kick started going back to 1963 when I was 18 years old and bought a Harley Hummer, it makes me dizzy. I had Ducati and Aermacchi singles, god knows how many 2 stroke racers, all with weak ignitions, BMW twins that kicked horizonal to the centerline of the machine, a Ducati bevel drive that kicked down around and under(that was a honey). The only reason I am alive is that I never could start my street machine when I was drunk so I slept beside it.
Shit after you couldn't kick any more you tried push starting by pushing like hell, jumping on and slamming your ass on the seat as you dropped the clutch. The machine would fall over and you laid on the ground with tears in your eyes.
Ever get pulled behind a car on your motorcycle? Oh yah, still got the scars?
Yada yada.
All that said the KTM 640 is the worst, meanest, hardest motherfucker yet.
After all I have been through I stand by it.
I put mine on the centerstand...And stand on something to gain a little height even though it's lowered...course the battery is dead, I have a switch to turn the headlights off...I try not to touch the choke or I do then wish I hadn't...still kick kick kick and then for no good reason it starts, why is never certain, always has though...for no good reason!!!
I live in fear.
bill
Bill Shockley
Old 11-12-2010, 05:31 PM   #134
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
I have other left kick bikes. Rotax Powered ATK's so I'm used to using the wrong foot.
But I had to kick start the orange Fiat (actually its black but who cares) one day. It was easier then I figured it would be.
Just pus the kicker down without decomp and you can feel TDC.
Now just let it return and give it one firm kick, still no decomp, it fired right up.
Had to do the same thing the next morning.
Half Choke, two kicks and it was running.
Easier to start than the TT600 mill. Mostly because the TT is geared to give you one stroke per kick it feels like.
I'm 6' tall but I have some girth. Kicking it is not an issue.
Now if I could ride it instead of friggen working on it.
Just like owning a Fiat, ride it today and work on it tomorrow. Just like my brothers Spider.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 02-03-2011, 11:14 PM   #135
wrk2surf
wrk2surf's Avatar
Oddometer: 6,841
arise old friend for LOW594
Times are GMT -7.   It's 09:37 PM.
