Old 01-23-2011, 06:38 PM   #46
beechum1 OP
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
Originally Posted by flatfender View Post
Here's an xls gear ratio calculator, you can play around with the numbers to give you an idea of how much difference a gear swap will make.
http://www.4strokes.com/tech/gearing_calc.xls
I have that, I'm still trying to figure out what this means. I have the basic understanding of how a gear box works, but when the teeth and the ratios.... ugh.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 01-23-2011, 06:52 PM   #47
flatfender
flatfender's Avatar
Oddometer: 776
Plug in these numbers for the XR-L
Primary Drive Ratio
2.029
1st Gear Ratio
2.666
2nd Gear Ratio
1.647
3rd Gear Ratio
1.250
4th Gear Ratio
1.000
5th Gear Ratio
0.840
1998 XR650L Dualsport
flatfender is offline   Reply With Quote
Old 01-23-2011, 06:57 PM   #48
beechum1 OP
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
Primary Drive Ratio
2.029
1st Gear Ratio
2.666
2nd Gear Ratio
1.647
3rd Gear Ratio
1.250
4th Gear Ratio
1.000
5th Gear Ratio
0.840
thanks, got that info too, but what I mean is... what do those number mean. it doesn't seem to me that, for every rev of engine, the rear wheel goes 2.029 revs, nor the reflexive....
Old 01-23-2011, 10:29 PM   #49
mcma111
mcma111's Avatar
Oddometer: 11,874
NX650 2nd Gear
Just got an e-mail from cheapcycleparts. My 2 NX650 second gears are on their way. FINALLY!!!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-23-2011, 10:31 PM   #50
flatfender
flatfender's Avatar
Oddometer: 776
Best thing to do with that xls doc is to plug in all your info and save it. Then when you open it you can add numbers and play around a little and when you close it select 'do not save', then when you open it again it will back to square one.
These are the numbers that concern gear ratios. Plug in the XR-L transmission gearing and your sprocket and tire size. At the very bottom you can plug in the different rpms you want to know about. Max power tells you where red-line is and min tells you the lowest speed before you need to down shift. I put in 4,400 for max rpm because that is a good rpm for highway speeds.
Now when you want to make a change in gearing you can see how it effects your ride. Plug in 14/48T sprockets and see how much your highway speed (blue box) drops staying at the comfortable 4,400 rpms. You can also see what the first gear ratio is for an XR600R and maybe you have decided that is a good ratio for an off road oriented XR-L. Since the two bikes have different primary drive and first gear ratios just plug in those numbers to see what sprocket set you need to run to have an XR600R first gear. Let's say you bought a tach and find that 3,900 rpms is the highest rpm your bike will cruise at before vibration gets bad, but you want to be able to still do 70 at this rpm. Plug in 3,900 down at the bottom and plug in different sprocket sets until you get the numbers you want. Just play around and have fun.
Values (Enter)Total RatioMin. SpeedMax. SpeedSpeed at Max Power
Primary Drive Ratio2.029Gear(MPH)(MPH)(MPH)
1st Gear Ratio2.66616.2281st 02234
2nd Gear Ratio1.64710.0252nd163655
3rd Gear Ratio1.2507.6093rd214772
4th Gear Ratio1.0006.0874th275990
5th Gear Ratio0.8405.1135th3270108
Front Sprocket (Teeth)15
Rear Sprocket (Teeth)45
Wheel Rim Size (Inches)18
Tire Width (MM)130
Tire Depth (%)90
Engine Minimum RPM2,000
Engine Maximum RPM4,400
Maximum Power RPM6,750
Old 01-23-2011, 10:32 PM   #51
flatfender
flatfender's Avatar
Oddometer: 776
How long did it take?
Old 01-23-2011, 10:42 PM   #52
mcma111
mcma111's Avatar
Oddometer: 11,874
NX650 2nd Gear
I ordered them November 27th.
They should be here Monday or Tuesday.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-18-2011, 04:35 PM   #53
rallybug
Local Yokel
rallybug's Avatar
Oddometer: 8,099
Originally Posted by Ghost_Mutant View Post
Research away, we need all the help we can get to find a cheaper source
I wonder if it's really true that the NX650 Dominator and the FMX650 bikes are European only. That's why I started looking at Honda dealers in the Orient.
I haven't given up finding another parts source just yet.
NX650 was a one-year only bike in the US too - 1988, with leftovers for 1989 registration.
Another European option is CMS in Holland
The picture attached to http://www.cmsnl.com/honda-nx650-198...ist/E++14.html shows 21-teeth, I think
Ben
My Ride Reports
rallybug is offline   Reply With Quote
Old 02-20-2011, 12:27 PM   #54
beechum1 OP
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
The 01 Mar is approaching. I had mentioned somewhere a target date of about then to make the purchase. Who's in and out? and do we want to wait a bit more for the group buy?
Old 02-20-2011, 03:04 PM   #55
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,064
All this stuff fits in the XL600 right?
Carter Pewterschmidt is offline   Reply With Quote
Old 02-22-2011, 08:52 AM   #56
tjrockit
One day closer...
tjrockit's Avatar
Oddometer: 1,211
I'm still on the fence. Let me know when you plan to make a purchase and if I'm ready at that time, I'll jump in.
Thanks for being flexible.
2007 Honda XR650L
Dirt Roads within a 100 mile radius of Austin, TX
*** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.***
tjrockit is offline   Reply With Quote
Old 02-23-2011, 10:03 PM   #57
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
I'm in for one.
I also vote to wait a bit more to see if any of the other searches reveal a cheaper source. I have struck out thus far in my aimless net browsing.
Anyone else care to report in?
Carter, the answer is yes,........ or it had better be since I've acquired a used XRL tranny to swap into my XR.
Ghost_Mutant is offline   Reply With Quote
Old 02-23-2011, 10:15 PM   #58
TourPros
Local wherever I go
TourPros's Avatar
Oddometer: 2,044
Yo
SO is there an update on the 23491-MW2-780 5th gear mod? I have cases cracked and I am doing the 2nd gear mod thanks to MCMA111 in San Francisco. But I would also really like the 5th gear mod for Highway use. Did anyone find where to get one?
Hell I've been thrown into better places and got friends I ain't even used yet.
Hug those you love often And turn life up !!!
I really like what your are trying to do. I'm just not sure about how you are trying to do it. It's been a pressure working with you and the pleasure was all yours. If you need me I'll call ya..
TourPros is offline   Reply With Quote
Old 02-23-2011, 10:31 PM   #59
beechum1 OP
Grimace Soup
beechum1's Avatar
Oddometer: 8,222
a guy PM'd me says he's working with a friend of his to find the 5th a little cheaper. He said he'll post up when he gets the news.
Old 02-23-2011, 10:37 PM   #60
TourPros
Local wherever I go
TourPros's Avatar
Oddometer: 2,044
Current
What is the cost now and can be gotten here in the states?
Times are GMT -7.   It's 06:23 AM.
